D-Sonic custom Audio amps - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 150Likes
post #1831 of 1989 Old 04-06-2018, 09:30 AM
Marc Alexander's Avatar
Quoted: 5588 Post(s)
Liked: 5176
Originally Posted by David Varner View Post
Just learned something
There is no "American" or "European" XLR pinout. The AES adopted a standard of pin 2 = + (or "hot") and pin 3 = - (or "cold") back in 1992
I'm pretty sure Emotiva started all of this confusion. I can't believe Anthem put it in their manual!
Marc Alexander is online now
post #1832 of 1989 Old 04-06-2018, 09:39 AM
Liked: 5176
Yes It does just like reversing the + and - wires on speaker wires.
As long as all of your cables and equipment are the same kind of pin out you are fine. All my equipment is US and I do check the manual upon set up to see if it is the same as I use. I make my cables and this is how all my XLR cables and equipment pin out.
Pin 1 = negative
Pin 2 = positive
Pin 3 = shield
David, Pin 1 should always be ground. Shield usually stays disconnected on XLR interconnects. What equipment do you have that uses the Emotiva wiring? I'm fairly confident that D-Sonic uses the correct wiring.
post #1833 of 1989 Old 04-06-2018, 09:44 AM
Jonas2's Avatar
Quoted: 2841 Post(s)
Liked: 1813
Pin 1 = negative
Pin 2 = positive
Pin 3 = shield
Pin 1 should be shield
Pin 2 = +
Pin 3 = -
At least that's how I'm wired with all of my XLRs....
dwaleke likes this.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #1834 of 1989 Old 04-06-2018, 09:48 AM
Jonas2's Avatar
Liked: 1813
Yep, as does Anthem and my Class D Audio amp, and SVS subs....!
How do mean shield is usually disconnected on XLR interconnects? I thought shield and ground are the same thing with XLR....
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1835 of 1989 Old 04-06-2018, 10:11 AM
Quoted: 438 Post(s)
Liked: 192
Pin 2 = +
Pin 3 = -
Sorry u are correct post edited.
Sent from my SM-G955U1 using Tapatalk
Pre-Pro: Yamaha CX-A5100, Amp: D-Sonic M3-5400-7, Subs: 3 JTR Orbit Shifter LFU's, LCR: DIYSG F-15 Sentinels, Surrounds: Tannoy 802's, 4k player: Panasonic UB-900, 4k Gaming PC
David Varner is offline
post #1836 of 1989 Old 04-06-2018, 10:36 AM
Quoted: 438 Post(s)
Liked: 192
I always connect the shield that's what separates them from RCA. The shield rejects RFI, EMI, and so forth. Without XLR cables to my three Subs they will buzz like crazy.
Short runs RCA no problem.Long runs XLR.
post #1837 of 1989 Old 04-06-2018, 10:54 AM
Liked: 5176
If you take apart an XLR connector you will find 4 solder points. The 4th is for the shell casing. On every mic cable I've seen the foil shield is left floating, even though it can be connected to point 4. Connecting would likely lead to some ground loop issues as it would be tying together the chassis.
post #1838 of 1989 Old 04-06-2018, 01:25 PM
Quoted: 438 Post(s)
Liked: 192
Interesting no foil on the mogami quad cable I use but know I know.
post #1839 of 1989 Old 04-06-2018, 02:26 PM
Liked: 5176
If its a dual cable you have to use the braided shield for signal ground.
A tri/quad cable often has a foil over the braid. You can chose to use the braid as signal ground but I prefer to use one of the insulated wires and leave the braid unconnected. Another strategy is to connect the braid to chassis ground on the female side and float it on the male.
post #1840 of 1989 Old 04-06-2018, 03:52 PM
Quoted: 1555 Post(s)
Liked: 816
All three pins are connected on the cables themselves.
Inside your amplifier pin 1 (shield) is supposed to terminate to earth ground as close to the xlr connector as possible. It does not go to the amplifier modules where pin 2 and pin 3 go.
Google the pin 1 problem.
jkbs likes this.
dwaleke is offline
post #1841 of 1989 Old 04-06-2018, 06:27 PM
Jonas2's Avatar
Liked: 1813
Ah, gotcha, yeah forgot about that extra solder point on the connectors, but it's there alright! I've only ever used one type of XLR with "wrapped shield" wire, wasn't even foil, was braided, tinned copper with a drain wire, though the drain wire and shield touch, so I totally don't get how that even works. Anyway, drain wire went to Pin 1! This was the Belden 1800F (only XLR I was able to find in-wall rated....).
Nope! Just the braided copper - and this wire, hands-down, is my FAVORITE. I just find the spiral wire so much easier to work with than braided. Thank you Mogami. And it's available in a bunch of colors....
Oh yes, I remember reading about this when I was first deciding on building the XLR cables and had a ground loop! (That turned out to be the safety ground for my Comcast system....)
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1842 of 1989 Old 04-14-2018, 06:40 AM
rukus29's Avatar
Quoted: 286 Post(s)
Liked: 147
Do the m3 multi channel amps have some sort of gain control?
rukus29 is offline
post #1843 of 1989 Old 04-14-2018, 07:42 AM
Quoted: 438 Post(s)
Liked: 192
No your pre pro would handle that
post #1844 of 1989 Old 04-23-2018, 08:16 PM
Jonas2's Avatar
Liked: 1813
NEW WEBSITE IS UP!
https://www.d-sonic.com/
Lookin' good!
Marc Alexander and Pres2play like this.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1845 of 1989 Old 04-29-2018, 08:40 PM
Jonas2's Avatar
Liked: 1813
Looks like the 3-channel amp has been discontinued.....??
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1846 of 1989 Old 04-29-2018, 10:26 PM
laserjock II's Avatar
Quoted: 1301 Post(s)
Liked: 739
No, just not listed.
Use contact to get prices/specs on available configurations.
laserjock II is offline
post #1847 of 1989 Old 04-30-2018, 09:21 AM
Jonas2's Avatar
Liked: 1813
Huh. Wonder why?
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1848 of 1989 Old 04-30-2018, 01:00 PM
Liked: 5176
Huh. Wonder why?
Likely just an oversight. Dennis can make any configuration one desires, not just what is listed on the site.
I just received a M3a-2800-7 that Dennis converted from a M3-2400-6 I purchased on the classifieds.
Now I have the M3a-2800-7 & 2000-5. My OCD would prefer to have to 2400-6s but 5s and 7s should be easier to resell if need be.
I'm moving to active LCRs so I really don't need my M3a-600Ms anymore.
post #1849 of 1989 Old 05-03-2018, 02:20 PM
Liked: 739
What speakers are you using with them?
post #1850 of 1989 Old 07-01-2018, 12:41 PM
dsonic's Avatar
Quoted: 16 Post(s)
Liked: 31
D-Sonic Update
Hello All, thought it was time for an update.
1) I do have custom rack shelves. 16GA steel, vent holes, powder coated chassis grey, very stable. Each kit comes with low-profile 3U feet and mounting hardware. There is no shipping charge if ordered with the multi-channel chassis amplifier.
2) Ostrey93 chose the Sanders Magtech. I have a customer's Magtech right now and am very impressed with it. Sonically, from the midrange up it is very close to the D-Sonic and I likely could not tell the difference in a blind test. I give D-Sonic the edge on bass extension and control due to 3x the damping factor. Also less than half the price and weight. Maybe Ostrey's girl friend had it right the first time .
3) XLR grounding: Marc Alexander is correct in post #1837 . The shield ground should tie to pin 4 on the input board connector and should float (no connection) on the XLR end. Pin 1 on this input board connector is labeled S GND. This stands for SIGNAL ground, not SHIELD ground. Both grounds tie together at 3 control points.
4) I only have 6 of the older style 3 channel chassis left. 3x400w was the maximum power in that chassis. I will use the multi-channel chassis for all 3-7 channel models after these are gone.
5) I am designing some new, lower powered models using smaller modules in the 250-500w power class. I propose to put 2 channels in my present mono size chassis, 4 channels into the stereo and 11 channels into the large multi. This will take a few months to get custom inputs and metal work.
Happy Sonics,
Dennis
pgwalsh, Jonas2, Pradeep2 and 1 others like this.
dsonic is offline
post #1851 of 1989 Old 07-01-2018, 02:28 PM
Jonas2's Avatar
Liked: 1813
Happy Sonics,
Dennis
Thanks for the updates Dennis! Can't wait to see the new 11-channel monster!
Pradeep2 likes this.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1852 of 1989 Old 07-01-2018, 05:20 PM
madhuski's Avatar
Quoted: 1393 Post(s)
Liked: 885
Happy Sonics,
Dennis
Hi Dennis - are you able to give more details on the 11 channel you are working on? is it 250x11?
this thing sounds like exactly what i’ve been looking for, a high powered one box solution to do 7.x.4
(finally got a new, deeper stand that can fit bigger amps...)
Selling in AVS classifieds
FS: McIntosh MX-160 Processor
madhuski is online now
post #1853 of 1989 Old 07-02-2018, 02:11 PM
dsonic's Avatar
Quoted: 16 Post(s)
Liked: 31
I am proposing two models:
1) M3as-2750-11, 11x250w/8 ohm
2) M3as-3250-11, 9x250w, 2x500w - a 500w center channel could be an option on this model.
D
pgwalsh likes this.
dsonic is offline
post #1854 of 1989 Old 07-02-2018, 02:13 PM
madhuski's Avatar
Liked: 885
D
and sorry - should have asked earlier, but I’m
assuming you could do a 9 channel version as well? (for the 5.x.4 guys...)
and idea yet cost and general eta?
post #1855 of 1989 Old 07-03-2018, 06:31 AM
dsonic's Avatar
Quoted: 16 Post(s)
Liked: 31
Yes, many custom builds would be available including the 5+4 nine channel.
Pricing for the 11 channel M3as series should be close to the 7 channel M3a series.
D
Jonas2 and Pradeep2 like this.
dsonic is offline
post #1856 of 1989 Old 07-03-2018, 05:59 PM
Jonas2's Avatar
Liked: 1813
Wow, that is aggressive pricing for 11 channels!!
What does the "s" stand for in M3as?
TL5 likes this.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1857 of 1989 Old 07-04-2018, 11:10 AM
Liked: 739
@dsonic
Bridging not possible on any of your amps?
post #1858 of 1989 Old 07-04-2018, 04:05 PM
Jonas2's Avatar
Liked: 1813
@dsonic
Not sure how often Dennis checks the forums - I'd give him a direct shout out on the phone or email!
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1859 of 1989 Old 07-04-2018, 06:30 PM
dsonic's Avatar
Quoted: 16 Post(s)
Liked: 31
The "s" references an internal part that is unique to the new series. Some of the numeric designations will be the same for these new models as they are for the M3a series so an alpha addition acts as a unique separator for each serial number.
Jonas2 likes this.
dsonic is offline
post #1860 of 1989 Old 07-04-2018, 06:32 PM
dsonic's Avatar
Quoted: 16 Post(s)
Liked: 31
@dsonic
No customer bridging for the assembled amplifier. Internal bridging is possible with some models and I do so for various upgrades.
dsonic is offline
