The "Official" Onkyo TX-NR905 Thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1291 of 8862 Old 08-23-2007, 07:31 PM
vcor's Avatar
Quoted: 39 Post(s)
Liked: 42
Originally Posted by migs_inc View Post
Has anyone compared the Onkyo 905 to the 875? If so, what are the stand-out differences? I **think** the 905 is the more feature-rich of the two, but it's not clear from stats, etc online (or perhaps I am just not looking at the right info or digesting it correctly).
Thanks for the insight.
Here's my specification comparison with highlights and links for the 905/875/805:
http://www.theosfiles.com/zzz/receiv...are_onkyo.html
vcor is offline
post #1292 of 8862 Old 08-23-2007, 07:57 PM
joerod's Avatar
Quoted: 1131 Post(s)
Liked: 1200
THX modes should only be used in larger sized rooms. If you are enveloped with to much surround at once this is an indicator that maybe your room is not big enough.
4K HDR10- ignore the “rules” and trust your eyes!
joerod is offline
post #1293 of 8862 Old 08-23-2007, 07:59 PM
joerod's Avatar
Liked: 1200
I see Dude2006. I doubt there is a channel that is effected more. If so it would be hard to pin point with all the different cable and satellite boxes out there.
joerod is offline
post #1294 of 8862 Old 08-23-2007, 08:39 PM
Tallen234's Avatar
Quoted: 14 Post(s)
Hey guys,
I haven't seen much posted on Vector Linear Shaping Circuitry. It seems that this is only available on the 905. I'm wondering if it is similar to Denon's Compressed audio restoration? If not, can you really notice a difference on digital sources?
This is from an Onkyo webpage:
Conventional D/A conversion methods reduce digital pulse noise at the conversion stage but can't remove it completely. VLSC employs a unique D/A conversion circuit to overcome this problem. Data is converted between sampling points and these points are joined with analog vectors in real time to produce a smooth output wave form. The result—a virtually noiseless, smooth, analog signal based on the digital source that brings out even the most subtle of nuances in music sources (including DVD-Audio and Super Audio CD), DVD Video sources (including high-definition), broadcasts, digital music files such as MP3s, and gaming content.
Tallen234 is offline
post #1295 of 8862 Old 08-23-2007, 09:13 PM
mnn1265's Avatar
Nice comparison.
mnn1265 is offline
post #1296 of 8862 Old 08-23-2007, 09:17 PM
joerod's Avatar
Liked: 1200
So I started with the 805 Onkyo. Then I purchased the 605 to be used with my outdoor theater set up. I then jumped at a chance to get the 875 so I could compare it to the 805. Knowing my goal all summer was to eventually end up with the 905 I moved the 875 out. I then went back to the 805 until just yesterday I received a 905. So what does this tell you? Either I have waaaaay to much time on my hands or I just can't make up my damn mind!
So for starters I am very happy with the performance of the 805. As I posted many times already if you do not need the HQV REON chip then you should be happy with the 805. The sound is very solid and I can say I was very happy using the Ultra2 cinema mode for Dolby TrueHD and uncompressed soundtracks. The passthrough HDMI 1.3a handled all sources I thru at it. And I mean all of them. I was sending my XA2, 94HD and JVC HM100u thru the which would then pass it to my crystalio II (as seen in the picture)...I would directly send in my DirecTV sources and 360 ELITE to the crystalio II. I was satisfied so much that I decided to splurge and add the 605 for my outdoor set up. The HDMI switching between my Panny BD10a and A2 was a big plus. I know the 605 does not make 5.1 into 7.1 but I do not use 5 speakers for outside anyway. I also did hook up the 605 in my set up indoors. It is a nice receiver but it does lack the umph and sound quality of the 805. And with the price difference there should be a noticeable difference. THX ultra 2 AVRs usually cost a bunch more! The 805 is the BEST receiver in its class and will definitely push the bar much higher!
Moving on to the 875. I liked it at first. Then the more I thru at it the more I started to notice a few things. The HDMI 1.3a is not as reliable as the 805. There were more times when I would get a resolution error even though it would go away and pass the signal like normal. That is a small gripe but that adds a few more seconds between switching inputs and getting the picture. I was never able to achieve a handshake (and I tried about 30 different things) with y D-VHS player. I know it is just a vcr but as my sig says, I have 92 movies in 1080i which look amazing being deinterlaced into 1080p by my VP. That is not the end of the world but it was bothersome to know that the 805 handled it perfectly. The 875 had really good sound to. Since I was able to compare it with the 805 I was able to determine that they are nearly identical. The 875 has a little more power but that is hard to notice. I was not happy with the lack of a picture menu on the 875. I felt that onkyo dropped the ball on this one. Some say who cares, but since I am a tweaker, I need that menu. Many will be happy getting the 875 but since the 905 can be found for 200 more (when they are finally showing up) I would really consider investing in the 905. Which leads to...
The 905 story... I have only had it for about 28 hours now. Trust me though, I have put it thru the paces. On paper these 3 receivers are a lot alike. In fact, on paper some football teams are supposed to blow out other ones. Which sometimes does not happen which is why the games are still played! The 905 is better than the 875 and 805. I know it costs more but sometimes it is hard to tell where the extra cost goes. Not for me. I have spent so much time with these new onkyos that I know them inside and out. Maybe it is better because it has separate power supplies. Or maybe the Vector Linear shaping circuitry! Maybe it is the massive toraoidal transformer plus the 2 separate for video and audio. Whatever it is the sound is more clear. I have used The Matrix Dolby TrueHD a lot lately. I could hear a distinct difference in some of the scenes. That's not to say the 875 and 805 are not good. In fact all three of them kicked butt with this soundtrack. The 905 is just a little bit better. I am spoiled because I am coming from their TX1000. I have to admit the 905 is very close to it. I could still hear differences in the TX1000s favor when using the 805 and 875. Not as much with the 905. So I am liking the sound from the 905! I figured it would have the same hang up over HDMI and I was right. It does not play my D-VHS player. I am just sending it straight to my crystalio II. I have also spoke to onkyo today and they are aware of some of the issues others are having and are working on them. I also like the fact that the 905 will have firmware updates just like the TX1000. With the nice picture menu adjustments already on the 905 I am excited knowing that they will be adding more features (hint hint). Which is another reason why to go with the 905 instead of the 875. As far as digital inputs (optical and coax) I know there are not as many as other receivers. Especially in the optical department. I have been using a monoprice optical to coax converter (which was 12 bucks) and it works perfectly fine. I have 3 direcTV receivers that I like to use at different times. I have 2 of them permanently hooked up thru the 905. So with them, my 360 ELITE and D-VHS you can see I need to use all of my digital audio inputs.
Details... The OSDs are done nicely. The 875 and 905 have a better set up menu but the 805s is still no slouch. Remotes are all the same. I never had a troublesome remote. The Audyssey! This can be really a good asset when done correctly. I purchased a tripod recently and the differences were very noticeable. I just got a compact one from walmart for 18.88. I put it in my seats extended to ear level and did all 6 of my seats. i liked the results much better this way. If you are going to spend the cash for anyone of the receivers then getting a cost-effective tri pod is a must. I like the audyssey for setting crossovers, distances, speaker types, you know, the little things! I then use my trusty radio shack old fashioned sound meter to tweak the speaker levels. Afterwards, I was very impressed hearing the dialogue coming out of the center channel. People were sounding like they were sitting next to me talking in the theater. I did end up raising the rears and backs somewhat but I feel like I have achieved really good sound now. And since I have 7 subwoofers leaving it at -15.0 is a good idea. I have an Ultra, Supersonic, DIG 600(pinnacle) , and 4 smaller ones (MTX Lolita's) you feel and not really hear against the seats. I have pics of my theater on page 59 of the 805 thread. I didn't think people would want to see them twice.
Other details... I know many are concerned about the amount of HEAT these receivers make. I will say I have had all of them on (2 805s, 605, 875 and now 905) for very long periods of time and have never had one shut down on me. I do not consider it an issue. Just don't touch the top!
Also, I have sent 1080p/23.98 and 60 thru all of these receivers and have never had an issue. I am very excited that the 905 is a first generation receiver with HQV REON and is doing this well with up conversion. It does give my very high end crystalio II a run for the money. If I was not used to my VP's nice features (pip/pop, great user face, ability to firmware upgrade with usb flash, great pic Q and not to mention very good looking unit) I would be completely happy with the 905. Just think what the next one will bring! I really believe the VP market will be shrinking once the Denons, yamahas, HKs, marantzs and Pioneers start using advanced deinterlacing chips like the 905. Why spend 3,000 or even 2,000 on a high end VP when you get it all in a single unit for less?
My final thought... I plan to keep the 905 in my theater for more testing but more importantly to enjoy (and review Blu ray and HD DVD titles at Hidefpreview.com) watching and listening to movies! The Ultra2 cinema mode is my sweet spot for all of these excellent receivers. Anyone of them will get the job done nicely. If you are not going to go for the 905 then I would highly suggest getting the 805. If you never hear the 905 you won't be missing anything. The 805 is that good! But if you do splurge and grab the 905 you will be happy you did when you realize where the extra money went.
Onkyo has done a great job with this line. Success breeds followers and with this group of receivers they have positioned themselves nicely. Other manufacturers have some catching up to do!
joerod is offline
post #1297 of 8862 Old 08-23-2007, 09:29 PM
joerod's Avatar
Liked: 1200
And yes, I know I need to remove the stickers!
joerod is offline
post #1298 of 8862 Old 08-23-2007, 09:29 PM
oduckswon's Avatar
I've Just purchased for for the home a Mitsubishi WD-65833 TV, Onkyo TX-NR905 Receiver, Toshiba HD-XA2 DVD, Sony PS3 80GB Console, ORB Mod2 7.1 Speakers all to be married to my Dish 921 HD receiver. I've yet to receive tv and the receiver. Next week they'll be here. Any advise as to the set-up? ie. all to the tv or run it thru the receiver.
oduckswon is offline
post #1299 of 8862 Old 08-23-2007, 09:32 PM
niksem's Avatar
^^^ hey dude, where do you get TruHD movies? I thought they are decoded by dvd player so receiver actually neve sees true TruHD
niksem is offline
post #1300 of 8862 Old 08-23-2007, 09:33 PM
foofoobar's Avatar
Thanks for the detailed review. Does this mean that the 875 won't get any firmware updates ever? If so, it's a great way to kill the product line and certainly doesn't make us 875 owners any happy...
foofoobar is offline
post #1301 of 8862 Old 08-23-2007, 09:36 PM
joerod's Avatar
Liked: 1200
I have heard from one source they may update it but then a few others have said they have no plans to update it. I wish I knew more (which is really less). One thing is for sure, I do not like the fact that the 875 does not come with the picture menu adjustments. That is not a good sign...
joerod is offline
post #1302 of 8862 Old 08-23-2007, 09:39 PM
joerod's Avatar
Liked: 1200
niksem, Dolby TrueHD may be decoded by the player (at this time) but it takes a good receiver to make the speakers shine! And a damn good sound mode (Ultra2 cinema)...
joerod is offline
post #1303 of 8862 Old 08-23-2007, 09:45 PM
oduckswon's Avatar
What a sweet set-up! But if heat rises why not the 905 on top?
post #1304 of 8862 Old 08-23-2007, 09:55 PM
bass addict's Avatar
Quoted: 616 Post(s)
Liked: 629
Joe, thanks for the thorough review. You have made up my mind to go ahead and spend the extra dough to get the 905, which is good news seeing as both my local B&M sources claim to have them in their sights for mid/late next week. One actually offered it to me for less than I have seen it priced anywhere and I told him I'd gladly pay him a little bit more for putting up with my incessant whining.
The purpose of listening shouldn't be to respond as much as it should be to understand.
bass addict is offline
post #1305 of 8862 Old 08-23-2007, 09:55 PM
Quoted: 616 Post(s)
Liked: 629
Uh, one word.....weight.
post #1306 of 8862 Old 08-23-2007, 09:56 PM
joerod's Avatar
Liked: 1200
These receivers weigh to much to be on top! Actually the back of my rack is completely open so I do not have to worry about heat. I have another room behind my screen. That is where I keep all of my movies and another 26 inch LCD. Oh and not to mention my message chair!
joerod is offline
post #1307 of 8862 Old 08-23-2007, 09:57 PM
niksem's Avatar
I found THX Cinema ... is this the same as Ultra2 cinema?
niksem is offline
post #1308 of 8862 Old 08-23-2007, 10:02 PM
Quoted: 616 Post(s)
Liked: 629
What kind of messages are you sending? Just messin' with ya.
post #1309 of 8862 Old 08-23-2007, 10:02 PM
joerod's Avatar
Liked: 1200
Since I have been PM'd twice I will just post a few pics of my theater...
joerod is offline
post #1310 of 8862 Old 08-23-2007, 10:04 PM
joerod's Avatar
Liked: 1200
A couple more plus a pic of my Wife's bar...
joerod is offline
post #1311 of 8862 Old 08-23-2007, 10:07 PM
joerod's Avatar
Liked: 1200
Also my goofy signs with one of my 20' outdoor widescreen...
joerod is offline
post #1312 of 8862 Old 08-23-2007, 10:09 PM
facesnorth's Avatar
May I ask what speakers you use? Any external amplification?
Originally Posted by Johnsteph10 View Post
I haven't seen many people comment on it...but the THX mode: "THX Ultra Cinema 2" is the BEST I have ever heard movies sound without a doubt. ...
I hear things I have never heard before.
facesnorth is offline
post #1313 of 8862 Old 08-23-2007, 10:12 PM
facesnorth's Avatar
You too, please, the speakers you are using? In fact, would everyone state what speakers they are pairing with their 905, either for cinema or music. If you feel it will clutter the forum, please PM me. Thanks!
Originally Posted by dude2006 View Post
I too have been using Ultra2 for every 5.1 source, whether DVD or HDTV shows. It just seems to add an extra "oomph" to the sound, and it seems to enhance the sound from the rear speakers as well (especially when listening to uncompressed PCM in Blu Ray movies). I saw Apocalypto last week and it sounded like I was in the jungle, I kept hearing little noises all around me. For 5.1 music sources, though, I prefer the THX "Music Mode".
post #1314 of 8862 Old 08-23-2007, 10:12 PM
joerod's Avatar
Liked: 1200
I am using Pinnacle speakers. Their KLCR for center & back and K80 series. They are very nice... I am not using any amps and the 905 (like the TX1000) handles all of my subs like a champ!
joerod is offline
post #1315 of 8862 Old 08-23-2007, 10:16 PM
godzilliga's Avatar
Joe, thanks so much for the excellent review. I was hoping that you got your review posted before J&R shipped my 905. That reminds me, where is that sucker!?!
godzilliga is offline
post #1316 of 8862 Old 08-23-2007, 10:19 PM
joerod's Avatar
Liked: 1200
Thanks! I hope you get it soon. The 905 will be worth the wait... I was pleasantly surprised by it... To say the least...
joerod is offline
post #1317 of 8862 Old 08-23-2007, 10:29 PM
joerod's Avatar
Liked: 1200
One more thing I should point out before I call it a night. The NEW Panamax 7500PRO Power Management System (I have been PM'd a few times asking me what component that is right above the 905) helps me achieve optimal Picture Q and sound Q. That unit is that good! Of course with a msrp of 2,000 it better be!
joerod is offline
post #1318 of 8862 Old 08-23-2007, 11:11 PM
facesnorth's Avatar
Do you really charge people for candy and soda and stuff?
I also appreciate the reviews. I've been anxiously waiting for them. I am back on the pre-order list with J&R, although I am sad now that I gave up my #3 spot. I was worried to be one of the first in case the reviews were bad. Now I hope I'll even get one in September....
I have patience, heck I don't even own speakers yet. But my LVM-37w3 1080p TV can't be returned after the end of September, and I was kind of basing my decision to buy it on the promise of the 905. I'd like to test out the 1080i deinterlacing on it before the return period expires for the TV.
post #1319 of 8862 Old 08-23-2007, 11:18 PM
mnn1265's Avatar
Not so fast to bed!
After playing with the 905 how do you think it would perform as a pre/pro (with my PVA7 Anthem amp)?
mnn1265 is offline
post #1320 of 8862 Old 08-23-2007, 11:35 PM
masmole's Avatar
Some very nice choices you've made! Especially the receiver
As for set-up, of course you have to run everything first to the 905 and not the TV! The 905 is one helluva receiver with video processing being one of its best assets, being far superior to the processing the Mitsu TV is capable of, so why deny it of what it does best? Of course, since the XA2 has basically the same ReonVX chip as the 905, it's somewhat redundant, but you might as well make use of the 905's four HDMI inputs, if anything just to simplify your HT set-up. Also, if you run video via HDMI directly to the TV from sources like the PS3 and the XA2, then that would mean you would have to use optical for audio to the 905, which would limit you to bitstream and the audio bandwidth limitations of optical/coax, and deny you of PCM uncompressed audio up to 7.1 channels when available from certain media. Connect all HDMI sources durectly to the 905, allow it to process video and sound as desired, and have a single HDMI cable to send video to the Mitsubishi.
LG OLED65C7P, Panny 65VT50, Oppo UDP-203, BDP-105D, HA-1, HA-2, Auralic Vega, Cambridge CXN, Apple TV, Mac mini 2014 core i7 SSD, Synology NAS, VPI Scout
Denon 4520ci, Parasound Halo Integrated, Jolida JD1000P, Vincent SV226 mk2, Gallo Ref3 SA, Peachtree Audio Nova, Woo WA22
Monitor Audio GX100, GS20/10/LCR, SVS SB13 Ultra, Gallo Reference 3.1, KEF LS50, Audeze LCD XC, Fostex TH900, Philips Fidelio X2, Sennheiser M2W
masmole is offline
