Outlaw Amps Owners Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 237Likes
post #811 of 898 Old 01-30-2020, 01:34 PM
rdgrimes's Avatar
Quoted: 4065 Post(s)
Liked: 3386
Originally Posted by Jameshtx View Post
I have a question on how to hook up the Outlaw 2200 monoblock. It has a plug for "balanced input". To hookup the 2200 into my Denon AVR preouts, I'm wondering if these are the cables I should get?
https://www.amazon.com/dp/B001VLW398..._G3YmEbN3N8F1Y
Broken link, but no - you don't want to use the balanced input on the 2200 in that scenario.
rdgrimes is offline
post #812 of 898 Old 01-30-2020, 01:57 PM
Jameshtx's Avatar
Quoted: 274 Post(s)
Liked: 27
Got it. Glad I asked
Epson 5040ub Projector l Oppo 203 l Denon AVR-X4300h l Monolith 5x200w Amp l Def Tech BP9080 L/C/R/SL/SR/SBL/SBR l SVS PB-2000 x2 l Panamax M5400
Jameshtx is offline
post #813 of 898 Old 01-30-2020, 01:59 PM
Jameshtx's Avatar
Quoted: 274 Post(s)
Liked: 27
Originally Posted by Dan Hitchman View Post
If you have single ended RCA pre-amp outs then you would buy a male to male RCA shielded audio cable and plug it into the unbalanced input. Monoprice makes some good premium RCA audio cables.
https://www.monoprice.com/product?p_id=2683
Awesome. Will go w/ these. Thx Dan
Jameshtx is offline
post #814 of 898 Old 01-30-2020, 10:29 PM
Quoted: 18 Post(s)
Liked: 7
Well, I just bit the bullet and bought a model 5000. I'm hoping I made the right choice of amp for my set up. I'm a total newbie and have to say I was frustrated as hell trying to figure out what amp to purchase. I didn't want to go overboard and overspend on a powerful amp I don't need. However, I also didn't want a cheap amp that wouldn't make a difference.
I have a Denon x3400h for my avr. It's hooked up to a pair of klipsch rp-280f speakers. My center channel is a rp-600c ( I wanted to buy a rp-450c for my center channel but had to compromise due to space constraints). My sub is a svs sb4000. I still have yet to buy my 2 surround and 2 atmos speakers. Looking to complete a 5.1.2 set up in the near future. Since the klipsch speakers I already have come with a pretty high sensitivity rating, I'm hoping the outlaw amp will provide a nice punch to my speakers. This is all set up in my living room and center listening position is roughly 10 feet away from my front L & R speakers and about 7 feet from my center channel.
I'm looking to hook up my L, R, C, and 2 surround speakers directly to the amp. I'll then eventually use the x3400h to power the 2 atmos speakers in my ceiling when I get them. Hopefully I made the right call on going with the model 5000 for my amp.
filip629 is offline
post #815 of 898 Old 01-30-2020, 11:09 PM
Dan Hitchman's Avatar
Quoted: 4993 Post(s)
Liked: 3018
The only real weak link is the receiver and it's limitation of 2 overheads. You really need a minimum of 4 to start getting better overhead action when it does occur. Just a stereo overhead pair won't allow for much in the way of object panning potential. FYI
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #816 of 898 Old 01-31-2020, 12:16 AM
Quoted: 18 Post(s)
Liked: 7
I would love to do 4 overheads but my budget won't allow for it unfortunately. I've got a medium sized living room and the 2 overhead speakers will be pretty much directly over my seating area. In the future I may upgrade my avr to add more overhead speakers, but for now, I'll have to do my best with what I've got to work with. I went from a cheap 3.1 LG home theater in a box system to what I have now. This new set up is drastically better than what I was working with before and I don't even have the ceiling or surround speakers yet. Whenever I get the chance to finish my basement, that's when I'll go the extra mile and spend on a better set up. For now, I'm planning on adding 2 klipsch pro 180rpc's to the ceiling and probably a pair of klipsch 5502 -W II in walls for my surround. Hopefully I'll be happy with everything after it's bought and installed. If not, I'll start putting some coin aside to upgrade my avr.
filip629 is offline
post #817 of 898 Old 01-31-2020, 05:18 AM
mattg3's Avatar
Quoted: 1049 Post(s)
Liked: 344
Does anyone know if you can safely stack three monoblocks on top of each other? Wish the company would come out with a way for them to plug into each other so you only needed one outlet but I'm sure that's probably not a very sound electrical situation.
Matt
mattg3 is offline
post #818 of 898 Old 01-31-2020, 05:31 AM
bwillcox's Avatar
Quoted: 1068 Post(s)
Liked: 628
I stacked 4 of the 2200 monoblocks on each other for my presence channels with my AVP for years before I replaced them with a 7700. Currently I am using two of them as the front L&R channels with my 3080 system and they are stacked. I'm not saying you should do it, but it worked ok for me.
mattg3 likes this.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is offline
post #819 of 898 Old 02-02-2020, 01:24 PM
irishluck73's Avatar
Quoted: 331 Post(s)
Liked: 214
Ordered the promo for (3) 2200 for $799 and received 2 yesterday, FedEx dropped the ball on the 3rd.
Waiting to install my Atmos speakers this week and will fire them up for the front 3.
mattg3 likes this.
JTR 110HT, 8HT, Captivator 1400; JBL SP8CII (Atmos); Denon X4200W; Outlaw 2200; Sony 75X940E; Sony X800M2; ATV4K
irishluck73 is offline
post #820 of 898 Old 02-14-2020, 06:13 AM
mattg3's Avatar
Liked: 344
If I were to buy the outlaw 5000 amplifier but only use three channels(left-right-center),would I get close to 200 watts per channel since I was not using 2 channels?
Matt
mattg3 is offline
post #821 of 898 Old 02-14-2020, 08:06 AM
kokishin's Avatar
Quoted: 1434 Post(s)
Liked: 1542
Most likely especially if your speakers are nominally four ohms.
Scroll down to Amplifier Power Measurements:
https://www.audiosciencereview.com/f...-review.10585/
mattg3 likes this.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon FTV Stick 4K, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is offline
post #822 of 898 Old 02-24-2020, 10:03 PM
creimes's Avatar
Quoted: 128 Post(s)
Liked: 160
I have the Model 7000x en-route and should be here by the weekend, I have a buddy picking it up on the south side of the border for me to save on shipping costs, I've had only Emotiva amps for the past seven or eight years so looking forward to something new
Theater - Emotiva XMC-1 | D-Sonic M2-750-3 | Outlaw Model 7000x | Emotiva T1 (LCR) | UAC-8.2 rears | Mach 5 IXL-18's | NX6000D | Epson 3500 | DIY AT Spandex 100"
Desktop - Asgard 3 | HD58X | Airmotiv 5s
creimes is offline
post #823 of 898 Old 03-01-2020, 12:37 PM
mavericks64's Avatar
Quoted: 26 Post(s)
Liked: 25
Please share your thoughts once you've had a chance to compare.
Sharp 80-inch 3D LED TV, Yamaha RX-A3070 Receiver, Outlaw 5000 Amplifier
Paradigm Reference Studio/100 v.2 front speakers Paradigm, Studio CC-690 center-channel
Paradigm CI Pro P80-IW Side Surrounds, Paradigm Monitor 9 rear surrounds, 4 CI Pro P80-R overheads
FV15HP Rythmik subwoofer
mavericks64 is offline
post #824 of 898 Old 03-01-2020, 03:24 PM
creimes's Avatar
Quoted: 128 Post(s)
Liked: 160
So far so good for how the unit sounds, I typically use Dirac for most of my listening but I'm really enjoying the amp so far, the only issue I am having is the trigger input is not working from any of my 4 trigger outputs on my XMC-1, I previously had two UPA-1's and a UPA-700 that triggered fine and an ERC-3 so I'm thinking it's the amp that is the issue, I have the rear rocker switch set to trigger and then front power button pressed but when I start my XMC-1 the 7000x will not power up, also when in this mode if I adjust the volume or press any buttons on the remote or front panel the front blue power ring on the 7000x blinks slightly, guessing I will need to call them tomorrow ughhh. Otherwise the sounds quality is outstanding.
creimes is offline
post #825 of 898 Old 03-04-2020, 06:00 PM
psraj's Avatar
Just ordered 3 * 2200 bundle for my LCR. I have a Yamaha Avantage 1060 AVR, speakers are all Klipsch RP280F, RP450C. I hope these 2200's will play nice with my AVR and speakers. Looking forward to having them.
psraj is offline
post #826 of 898 Old 03-04-2020, 06:35 PM
Liked: 3018
You may have to raise your speaker trim levels unless Yamaha has fixed the low pre-amp signal levels on their latest receivers.
post #827 of 898 Old 03-04-2020, 07:53 PM
psraj's Avatar
Thanks for the tip Dan. I did not know Yamaha had this issue Is anyone using the 2200 with Yamaha Avantage series AVRs? Any issues?
psraj is offline
post #828 of 898 Old 03-04-2020, 09:19 PM
ceh383's Avatar
Quoted: 545 Post(s)
Liked: 3423
I'm running 5 of them off of my Yamaha 2060, it drives them just fine.
You should have no problems at all.
psraj likes this.
Yamaha RX-A2060 | Outlaw M-2200 (x5) | Oppo UDP-203 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | Amber In-ceiling | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #829 of 898 Old 03-05-2020, 02:10 PM
psraj's Avatar
Thanks ceh383. I should get mine next week. Will update how it goes.
psraj is offline
post #830 of 898 Old 03-05-2020, 02:20 PM
bwillcox's Avatar
Liked: 628
I am running 2 of them currently with my 3080. Prior the 3080 I was using a 3070 in the same configuration. I actually own 4 2200s and originally used them with a RX-Z11 and then a CX-A5000. Never had any trouble driving them.
psraj likes this.
bwillcox is offline
post #831 of 898 Old 03-05-2020, 07:29 PM
ceh383's Avatar
Quoted: 545 Post(s)
Liked: 3423
Good little amps, I'm very pleased.
Curiosity, why did you change from the CX-A5000 to the RX-A3080?
ceh383 is offline
post #832 of 898 Old 03-05-2020, 07:39 PM
bwillcox's Avatar
Liked: 628
I didn't. The 3080 is in my den and I currently have a CX-A5200 in my living room which is my HT room these days. I used to use 4 2200s in my living room system with an RX-Z11 that I had at the time. I replaced the Z11 with the 5000 and then the 5000 with a 5100 and then I replaced it with a 5200. I think it was when I was using the 5000 that I replaced the 4 2200s with a 7700. That freed up the 2200s and I eventually starting using two of them for the L&R front channels in the den system. Just a bit of upgradeitus going on over the years it would seem.
bwillcox is offline
post #833 of 898 Old 03-05-2020, 08:40 PM
ceh383's Avatar
Quoted: 545 Post(s)
Liked: 3423
I get it, been there done that. I've been very happy with my system, to the point of not feeling the need to upgrade.
Well, I am thinking about a new TV, but that's off topic
ceh383 is offline
post #834 of 898 Old 03-11-2020, 07:08 PM
psraj's Avatar
They are here.. and awesome!!!
Finally received my 3 * 2200 today. Installed them, in my setup, and they sound AWESOME!!! My Niles SI2150 that was doing LR before has now moved to surround. The Outlaw LCR sounds silky smooth and warm. I can tell the difference from the Niles SI2150. These Outlaw units are quite heavy, and the build quality is top notch. The audio is clean, no hum of any sort. The only quirkiness I noticed was, in standby mode, each front LED had a different shade, light yellow, amber and yellowish green , no issues at all. Haven't run them long enough to see if they get too warm. Will update once test them longer. Thanks for everyone who answered my question, helped a lot in my decision making.
Name:	outlaw - 1.jpg
ID:	2696636   Click image for larger version
Name:	outlaw - 1 (1).jpg
nonametofame and mavericks64 like this.
psraj is offline
post #835 of 898 Old 03-11-2020, 07:45 PM
Sorny's Avatar
Quoted: 169 Post(s)
Liked: 201
Ordered a 7000x yesterday, waiting for shipping confirmation now. I hate the waiting game...
MiniDSP 2x4HD, UMIK-1, REW... The holy trinity for running multiple subs.
Espon 5050UB, 120" screen, AppleTV4k, Harmony Elite, Sony UBP-X700, Pioneer Elite VSX-LX504, Outlaw 7000x, MiniDSP 2x4HD, 2x HSU TN1220HO subs, 2x HSU VTF-15H Mk2 subs, Defintive Technology speakers: CLR2002 x3 for FR, C, FL; BP2x SR & SL; BP1.2x SBL & SBR; ProMonitor 800 x4 height speakers.
Sorny is offline
post #836 of 898 Old 03-11-2020, 08:56 PM
ceh383's Avatar
Quoted: 545 Post(s)
Liked: 3423
Yeah, that's the only issue with mine as well. Of the 5, 4 are amber and 1 yellowish green. One day, if I ever have the time, I'll swap the LED's out for something more consistent...
ceh383 is offline
post #837 of 898 Old 03-17-2020, 07:17 PM
iserum's Avatar
Quoted: 336 Post(s)
Liked: 141
thinking of adding amp to my set 5.2.4 to run my deftech 9060 and Cs9060, i was thinking of getting 5000, or 7000x for future proofing, or should i get the 2200 three of them, new to this topic. my AVR can drive the atmos, or i use all channels if i get the 7 channel.
need some advise what is the best options or other brands, want to keep price under or close to 1K. there is limitation on the size as there is limited space to place amp. these are very heavy when i went through specs.
SONY 75X900F: Oppo UDP-203: DirecTv 4K: ATV4K
Marantz SR6013: Parasound 2250 V2: Aircom T8: Dolby Atmos 5.2.4
Definitive Tech. BP9060, CS 9060 HD: Mythos GEMS
Subwoofer Paradigm X12: Belkin PF30: Panamax M8-AV Pro
Harmony Elite Remote: Philips Hue Ambient Lights: 6500K Bias LED Lights
iserum is offline
post #838 of 898 Old 03-18-2020, 05:06 PM
nonametofame's Avatar
Quoted: 78 Post(s)
Liked: 45
I would get the trio of 2200 monoblocks based on what you mentioned:
lightweight
compact
flexible configurations
solid measurements
stackable
$800 when on sale (not sure if it's still running)
Audio: Audiocontrol Maestro M5 | Parasound A21 | Parasound A51 | Emotiva XPA 5 Gen 2
Video: LG 65E6P | Panasonic UB9000 | Oppo 203 |
Speakers: Martin Logan 60XT & 50XT| Motion 4| FX2s
| Dual SVS PB16 |
nonametofame is online now
post #839 of 898 Old 03-18-2020, 05:19 PM
spyboy's Avatar
Quoted: 360 Post(s)
Liked: 294
lightweight
compact
solid measurements
stackable
The trio of 2200's is still on sale for $799 delivered.
spyboy is offline
post #840 of 898 Old 03-18-2020, 07:49 PM
iserum's Avatar
Quoted: 336 Post(s)
Liked: 141
lightweight
compact
solid measurements
stackable
so i can stack all three and daisy chain trigger, will that work, does it requires special power outlet?
iserum is offline
