AVRs that support HDMI Audio MPCM or HBR Decoders - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 158 Old 12-04-2007, 05:05 PM
almostinsane's Avatar
Quoted: 71 Post(s)
Liked: 48
Rudolpht - This thread is awesome and I can only assume it will grow with info and info requests. Would it be possible to put the info in the first post into a matrix/spreadsheet type display? I think it would be easier for everyone to view and compare the feature that each AVR has.
almostinsane is offline
post #62 of 158 Old 12-04-2007, 05:50 PM - Thread Starter
rudolpht's Avatar
Let me see what I can do this weekend, unless somebody wants to take a stab in the interim and I can attach it up front.
Tim
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #63 of 158 Old 12-04-2007, 10:21 PM
mike171979's Avatar
Quoted: 43 Post(s)
Liked: 36
Marantz sr4002, 3 inputs, 1 out HDMI Ver 1.3 Multi-channel (7.1) LPCM via HDMI
Marantz sr5002, 3 inputs, 1 out HDMI Ver 1.3 Multi-channel (7.1) LPCM via HDMI
mike171979 is offline
post #64 of 158 Old 12-04-2007, 10:32 PM
mike171979's Avatar
Quoted: 43 Post(s)
Liked: 36
Sony STR-DG810, 3 inputs, 1 out HDMI, Multi-channel (6.1) LPCM via HDMI 1080P Passthrough, No Upconversion
Sony STR-DG910, 3 inputs, 1 out HDMI, Multi-channel (7.1) LPCM via HDMI 1080P Passthrough, No Upconversion
Sony STR-DG1000, 2 inputs, 1 out HDMI, Multi-channel (7.1) LPCM via HDMI 1080P Passthrough, and upconversion of analog inputs up to 1080i
post #65 of 158 Old 12-05-2007, 06:11 PM - Thread Starter
rudolpht's Avatar
Mike, thank you. Updated.
Tim
rudolpht is offline
post #66 of 158 Old 12-05-2007, 06:12 PM - Thread Starter
rudolpht's Avatar
Mike,
Thanks X 2
Tim
rudolpht is offline
post #67 of 158 Old 12-06-2007, 04:34 PM
samsurd2's Avatar
rudolpht - thanks for the excellent thread. Here's a correction re. the Sony 910. The STR-DG910 upconverts/transcodes analog video signals to HDMI so "No Upconversion" should changed to "and upconversion of analog inputs up to 1080i"
samsurd2 is offline
post #68 of 158 Old 12-06-2007, 04:44 PM - Thread Starter
rudolpht's Avatar
Done, thank you.
Tim
rudolpht is offline
post #69 of 158 Old 12-07-2007, 12:16 PM
godfa7h3r's Avatar
Yamaha 861 has 2 HDMI inputs, not 3
Double check your Denon 580xCI. It's actually the 5805CI, not 5808CI and does not do any of the lossless audio formats, only MPCM.
godfa7h3r is offline
post #70 of 158 Old 12-07-2007, 02:22 PM - Thread Starter
rudolpht's Avatar
Corrected the 861. The model is the Denon 5308CI, not the 5805CI or the 5808. The Denon link must be down. Intent is to capture new or imminent models.
Thank you.
Tim
rudolpht is offline
post #71 of 158 Old 12-08-2007, 11:40 AM - Thread Starter
rudolpht's Avatar
Well, while I should have been reprogramming my remote (or being with family ) I did take a cut at a spreadsheet version.
Jump to 1st Post
The most helpful way to make edits would be to save off the XLS attachment make updates in red and email it back to me. This has been a much more time consuming endeavor than I considered, so anyone feel free to start a new thread with material and this one can die a semi-noble death. There are questions in a few fields it would be good to fix. Many are "yes" but I'm leaving the "?" until it's more specific, e.g., is it 480i->p w/ Time Base Correction, 1080p passthru or upconversion also and if so to what. (Only to 720p surprised me on a some of the units).
The gates are open, let the criticism begin.
Tim
rudolpht is offline
post #72 of 158 Old 12-10-2007, 07:46 PM - Thread Starter
rudolpht's Avatar
Any inputs?
Tim
rudolpht is offline
post #73 of 158 Old 12-10-2007, 08:38 PM
Steve Dodds's Avatar
Quoted: 24 Post(s)
Liked: 27
Just a clarification on the Yamaha v1800/3800. They use an iChip for deinterlacing and the ABT for scaling. Also, neither will upscale via the HDMI inputs, it is strictly pass through. They will upscale component to 1080P and output that via the HDMI output. They will not upscale component and send it over the component out though, merely deinterlace it.
Steve Dodds is offline
post #74 of 158 Old 12-11-2007, 09:27 AM
benso37's Avatar
Quoted: 46 Post(s)
Correction needs to be made on the chart...The TX-SR805 uses the Faroudija chip not the Reon. It's upconversion is the same as the 605 and 705.
Source: Onkyo
benso37 is offline
post #75 of 158 Old 12-11-2007, 04:47 PM - Thread Starter
rudolpht's Avatar
I'm a little confused. iChip for component deinterlace (only)? ABT for HDMI scaling (only)?
Is there a way that the comment can be reduced to fit in the remarks field?
Tim
rudolpht is offline
post #76 of 158 Old 12-11-2007, 04:48 PM - Thread Starter
rudolpht's Avatar
Source: Onkyo
Thanks. Made in the text, I'll make updates to the spreadsheet when more changes accumulate.
Tim
rudolpht is offline
post #77 of 158 Old 12-28-2007, 10:07 AM
TXBDan's Avatar
Quoted: 34 Post(s)
The Marantz x001 series can all take at least 5.1 multichan PCM.
I have the SR4001 and i can verify it takes 5.1 multichan PCM. it has 2 HDMI inputs, one output. I've HEARD that the entire x001 line will take 7.1 multichan as well, but i can not personally verify this.
TXBDan is offline
post #78 of 158 Old 12-28-2007, 12:15 PM - Thread Starter
rudolpht's Avatar
Thanks. Focusing on newer releases here, but if you can provide the info on the columns, even just for the 4001, I'm happy to add it. Thanks,
Tim
Tim
rudolpht is offline
post #79 of 158 Old 12-28-2007, 12:52 PM
thehun's Avatar
Quoted: 1076 Post(s)
Liked: 1080
Originally Posted by catapult View Post
Are you sure about that? Pioneer has supported native MLP and DSD over i.Link for years so they have the chips to convert them to PCM in the receiver. As I understand it, MLP is the compression used by Dolby TrueHD so it shouldn't be a problem for the HDMI interface either. I forget which thread, maybe one of the Onkyo or Denon threads, but someone was sending MLP to the receiver over HDMI with no problems.
It's not a technical issue but a licencing one. Besides some Meridian products I don't know any that sends MLP downstream. Having said that Dolby THD only available via HDMI v1.3a, which very recent so MLP couldn't been sent before that, however when player does the decompression the resulting PCM can be sent with v1.1. DSD via I link was never fully proven to my knowledge if it was indeed DSD, however Pioneer did convert it to PCM anyway.
Is that "someone" explained how he knows what travels in his HDMI cable?
De sagittis Hungarorum libera nos, Domine!
Attention, don't read my posts if you're a snowflake or easily offended.
The Hun
thehun is offline
post #80 of 158 Old 12-28-2007, 04:03 PM
jruser's Avatar
Quoted: 81 Post(s)
Liked: 33
Integra DTC 5.8 (same as TX-SR605)*
Integra DTC 6.8 (same as TX-SR705)*
Integra DTC 7.8 (same as TX-SR805)*
*For the intents of the table on the first post.
jruser is offline
post #81 of 158 Old 12-28-2007, 04:31 PM - Thread Starter
rudolpht's Avatar
Thank you.
Updated the text and links. Will update the graphic table and spreadsheet after a couple more updates.
In the future, if folks provide the links (found the Integras) like mike did above, it is much appreciated.
Tim
Tim
rudolpht is offline
post #82 of 158 Old 12-29-2007, 08:37 AM
jruser's Avatar
Quoted: 81 Post(s)
Liked: 33
What about putting MSRP in the table? That way somebody wanting to buy one of these receivers wouldn't have to look them all up. Some of these are hard to find.
jruser is offline
post #83 of 158 Old 12-29-2007, 09:06 AM - Thread Starter
rudolpht's Avatar
If people provide it, like links to the manufacturer specs, I'll put it in. I just can't hunt it down for all of them, regardless if the margins on each are very different and street price is not an option on the forum.
Tim
rudolpht is offline
post #84 of 158 Old 01-01-2008, 10:02 AM
sleepyeddie's Avatar
Originally Posted by fyzziks View Post
This kind of listing is *very* helpful, good idea.
Just a few corrections:
The Denon 4308 uses the same Faroudja video processing as the 3808.
The Denon 5308 uses Realta HQV video processing.
The Onkyo 875 has the same Reon HQV video processing as the 905.
Obviously, I have spent too much time checking out the VP capabilities...
I just got a new sony kds-60a3000 projection tv. I am looking for an av receiver with superior video processing. A weakness described by CNET in the tv is" it`s inability to properly de-interlace material from off air HD broadcasts, and cable and satellite tv HD sources. " I`ll be getting the top of the line HD receiver from directv. I know this may be a subjective question but I just don`t have the motivation to learn all about the technicals like most of you do. I hope this question is appropriate in this forum. If you "Knowledgeables" would give me some suggestions it would be most appreciated.
I love this site. And for someone like me to be able to draw upon the intellect of you guys before deciding on a purchase is priceless.
Thankyou Greg
sleepyeddie is offline
post #85 of 158 Old 01-01-2008, 11:55 AM - Thread Starter
rudolpht's Avatar
Thankyou Greg
This thread will work until you pick a receiver then you can jump to a thread specific to it.
As someone suggested having the MSRP my help narrow for peoples price range, and with that we can figure out a recommended option.
I think it sounds like you need motion adaptive 1080i -> 1080p for the specific issue. Suggestion is to get a higher end Realta or step down to a Reon chip.
Tim
rudolpht is offline
post #86 of 158 Old 01-01-2008, 12:10 PM - Thread Starter
rudolpht's Avatar
I updated the graphic and attached excel zip file to reflect the Integra additions.
Tim
rudolpht is offline
post #87 of 158 Old 01-02-2008, 02:49 PM
jeff_c's Avatar
Thought this might be useful for some people shopping. The JVC RS-D702B is capable of handling multichannel PCM over HDMI. It has 2 HDMI in and 1 out. Got it for a great deal at Ultimate Electronics (which I have heard is the national price at UE's across the country) so some others may be interested in finding some info on it.
http://av.jvc.com/product.jsp?modelI...athId=5&page=1
jeff_c is offline
post #88 of 158 Old 01-02-2008, 05:26 PM - Thread Starter
rudolpht's Avatar
jeff,
Thanks. If you provide the other info like Mike did above I'll add it to the table, otherwise folks can jump off your link and benefit from your heads up.
Tim
rudolpht is offline
post #89 of 158 Old 01-06-2008, 05:28 AM
Thanks for your reply Rudolpht. I have just learned that some avr`s do not upconvert from hdmi to hdmi. I`ll be getting directv hd next week and I was wondering if you knew which " futureproof" avr`s do upconvert from hdmi to hdmi.
post #90 of 158 Old 01-06-2008, 07:23 AM - Thread Starter
rudolpht's Avatar
My understanding is that all the AVRs in the table with Yes in the Scaling/Deinterlacing column and no notes to the contrary will do that. Double check the item links for specs to be sure. Quite a number do.
Tim
Tim
rudolpht is offline
