Challenging room/ room treatments - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-20-2010, 06:59 AM - Thread Starter
ratboy's Avatar
My HT room sits above my garage and is a acoustical nightmare. Despite endless calibration, speaker movement, audssey correction etc, I just can't seem to get the sound I desire.
I have never done any room treatments but wondered if there was a "room treatments guide" of any sorts that anyone knows about. Suggestions would be appreciated.
ratboy is offline
post #2 of 5 Old 11-21-2010, 01:00 PM
DanLW's Avatar
Liked: 37
A good place to start would be the Acoustic Treatments Master Thread:
https://www.avsforum.com/avs-vb/showthread.php?t=1226757
Also, the sticky at the top of the forum: "Setting Up Your Home Theater 101" has many links.
From what I have gathered, for multi-channel audio, a good start is a nice large area rug that fills up as much of the floor as possible. (Assuming the room is not already carpeted) Next, cover the front wall with ~1" of rigid fiberglass or mineral wool. Next, treat the side walls to above ear height. Finally, bass trapping if needed.
What exactly are the issues you are coming up against? Echo? Bad imaging? Peaks and nulls?
DanLW is offline
post #3 of 5 Old 11-22-2010, 10:07 AM
Ethan Winer's Avatar
Quoted: 270 Post(s)
Liked: 408
This short article explains the basics in plain English:
Acoustic Basics
More here:
How to set up a room
Early Reflections
--Ethan
Ethan Winer is offline
post #4 of 5 Old 11-23-2010, 12:39 AM
SierraMikeBravo's Avatar
Quoted: 398 Post(s)
Liked: 296
There are numerous parts to calibration and treatment strategies to consider when trying to shape the sound you want. You can often end up chasing your tail. What have you been doing that sound so bad in regards to calibration, and what sound are you after?
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
[email protected]
[email protected]
SierraMikeBravo is offline
post #5 of 5 Old 11-24-2010, 05:04 AM
kgveteran's Avatar
Quoted: 761 Post(s)
Liked: 230
How about some pics of this nightmare. It would help us at least get a picture of things.
I would presume you have big nulls and peaks.....
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
