Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 829 - AVS Forum | Home Theater Discussions And Reviews
 4149Likes
post #24841 of 27619 Old 05-30-2018, 03:06 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Man I generated a decay sweep on my final sub calibration and the ringing is prodigious lol especially in the lower frequencies. Which troubles me since ringing in lower frequencies I’ve read is hard to treat. Is this treatable, did I do something wrong in my measurements?
veger69 is offline
post #24842 of 27619 Old 05-30-2018, 03:19 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11037 Post(s)
Liked: 6578
On page 81 of the Guide, it is recommended to turn off all time slices except for 160ms in order to make the graph easier to interpret. Can you do this, please?
And as for bass resonance below 40Hz, you are correct, it is very difficult to eliminate with treatments. But before you get overly concerned, think about what type of content is in the ultra-low frequencies. Not most music content, where bass resonance can destroy the mood. It is primarily LFE effects in movies, like explosions. Can you really tell the difference between an explosion that has bass resonance and one that doesn’t? Probably hard to tell. My advice: focus on managing resonances above 40Hz, which we will be able to see better if you post an updated Decay measurement, as well as a Waterfall and a Spectrogram.
AustinJerry is online now
post #24843 of 27619 Old 05-30-2018, 04:01 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
I read your guide but can’t reproduce your graph
Could you tell me what the slice interval, window ms and rise time should be?
veger69 is offline
post #24844 of 27619 Old 05-30-2018, 04:14 PM
Liked: 6578
The guide on p79 clearly shows the exact settings to use. Are you looking for something else? How about posting a download link for your MDAT file so I can look at it directly?
post #24845 of 27619 Old 05-30-2018, 04:16 PM
Wayne A. Pflughaupt's Avatar
Quoted: 410 Post(s)
Liked: 333
Perfectly normal, and not readily treatable. As Jerry noted, it’s not that big of a deal. The main reason it looks so bad is that your level is really high.
I’d say just use a waterfall graph for this.
Wayne A. Pflughaupt
AustinJerry and ahblaza like this.
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #24846 of 27619 Old 05-30-2018, 04:29 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Ok I had the settings right but didn’t turn off all but 160
https://www.dropbox.com/s/8ocs85ch5k...only.mdat?dl=0
ID:	2409726   Click image for larger version
ID:	2409728   Click image for larger version
veger69 is offline
post #24847 of 27619 Old 05-30-2018, 05:36 PM
ereed's Avatar
Quoted: 2191 Post(s)
Liked: 1483
All of that is in the guide....it perfectly says all this if you're looking at the REW guide in Jerry's signature which you should have downloaded when you click on his link.
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is offline
post #24848 of 27619 Old 05-30-2018, 05:36 PM
Liked: 6578
The graph presentation is better now. You have three measurements in the file. What is "Subs all in phase filter" mean?
Clearly, the Decay graph shows an issue at 80Hz. The resonance at 40Hz as previously discussed would be difficult to fix. The frequency response measurement shows quite a peak at 40Hz, which is probably not helping the resonance at that frequency. The REW EQ tool can lower that peak:
I thought you were using REW EQ in a miniDSP device?
post #24849 of 27619 Old 05-30-2018, 05:43 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
The “subs all in phase 90db” was the raw sub sweep no filter applied
The “subs comb all in phase filter” was corrected with MiniDSP it saw that rise at 40hrz corrected for it but had no affect.
The “sub ARC cal” was the MiniDSP filter applied, then the Avm60 ARC calibration run
veger69 is offline
post #24850 of 27619 Old 05-30-2018, 06:03 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Here is my measured response and the filter it created. It predicted correcting the hump at 40hrz but the sweep with the filter applied had no affect on the bump
ID:	2409744   Click image for larger version
veger69 is offline
post #24851 of 27619 Old 05-30-2018, 06:28 PM
Liked: 6578
I see now. I was applying the EQ to the measurement after ARC, which is wrong. Too bad the PEQ isn't more effective. The measurement after the ARC Calibration is still not great.
BTW, I can get slightly better results if I set "Match Range" to be 20-70Hz. This is more reasonable, since nothing is going to touch that weird dip at 80Hz. Wonder what is causing that?
post #24852 of 27619 Old 05-30-2018, 06:36 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
It’s confusing to me too it’s. It’s in the individual sweeps too even the rear sub
veger69 is offline
post #24853 of 27619 Old 05-31-2018, 05:06 AM
artur9's Avatar
Quoted: 991 Post(s)
Liked: 377
Can you measure different places in the room? Maybe it's a placement issue. You might not be able to do anything about it but at least you'd know the reason.
artur9 is offline
post #24854 of 27619 Old 05-31-2018, 05:13 AM
JohnPM's Avatar
Quoted: 129 Post(s)
Liked: 129
The prediction is generally very accurate. It looks likely that your filters are simply not being applied, either not loaded correctly into the 2x4 HD or in some way disabled.
ahblaza likes this.
JohnPM is offline
post #24855 of 27619 Old 05-31-2018, 10:58 AM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
yes I’ll attempt today
Well the filter obviously worked in other areas of the curve but maybe I’ll know more with a little more experimentation
veger69 is offline
post #24856 of 27619 Old 05-31-2018, 08:57 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
I ran sweeps +3, +2’, +1’ MLP they all showed dips at 45-60hrz. I got better results this time at the MLP and the filters seemed to apply this time. So I guess the dip is something I’m going to have to deal with till I treat the room.
https://www.dropbox.com/s/xsqk2t3tkehz6pt/SUB.mdat?dl=0
The pics are,
1. the corrected sweep at MLP.
2. Four measurements surrounding the MLP at least 2’ feet apart, all exhibiting the dip.
3. Waterfall
4. Decay
5. Spectrogram
veger69 is offline
post #24857 of 27619 Old 06-01-2018, 03:32 AM
ereed's Avatar
Liked: 1483
@veger69 sub pos4 looks the best with the smallest dip at 50hz. Also can you show subs + center?
ereed is offline
post #24858 of 27619 Old 06-01-2018, 07:04 AM
Liked: 6578
In my experience, treatments don’t raise dips. They tend to address resonances.
post #24859 of 27619 Old 06-01-2018, 08:44 AM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Unfortunately erred that position 4 was on the outside edge of my right seating position. All the center position had the dip. I tried +3’mlp, +2’mlp, +1’mlp all showed dip.
Jerry I guess I stuck with it then I can try them in the corners when my new sub patch cable get here. I’m limited on space as you can see
veger69 is offline
post #24860 of 27619 Old 06-01-2018, 11:15 AM
Liked: 6578
Yes, that looks pretty tight. BTW, why do you point the tip of the mic downwards? The general guidance is to point it towards the ceiling, with the tip exactly at ear-height. You might try to see if that makes a difference.
ahblaza likes this.
post #24861 of 27619 Old 06-01-2018, 11:24 AM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
I switch it to downward for these measurements because with the booms height I wasn’t able to get the mic at ear level for all measurements. Weirdly the filters didn’t start acting right until I turned it down. I’ve seen pictures with the mic in that position, is it really different as long as it’s 90deg?
veger69 is offline
post #24862 of 27619 Old 06-01-2018, 11:37 AM
Liked: 6578
Not sure. I always point it at the ceiling, which is why I recommended at least giving it a try to see if there are any differences.
post #24863 of 27619 Old 06-01-2018, 12:00 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Looks the same to me
veger69 is offline
post #24864 of 27619 Old 06-01-2018, 12:14 PM
Liked: 6578
OK, agreed, but I still recommend pointing the tip of the mic towards the ceiling.
post #24865 of 27619 Old 06-01-2018, 12:18 PM
artur9's Avatar
Quoted: 991 Post(s)
Liked: 377
IIRC, I had a dip like that for a while. I think it's what prompted me to get another subwoofer.
Nice thing about that dip being in the 40-60Hz range is that you don't need a monster sub to fill it in. I think an 8" sub will do just fine.
artur9 is offline
post #24866 of 27619 Old 06-01-2018, 02:30 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Unfortunately I have three. two VTF-15HMK2 and one LMF-1 EX, all decent subs and all individual sweeps showing a dip at 40-60hrz. For a 16x12 room that should be more than enough. I have one shot left I’m going to place the front subs in the corner and see if that helps
veger69 is offline
post #24867 of 27619 Old 06-01-2018, 04:35 PM
Liked: 6578
Why I find most interesting is that all three subs, which are placed in different spots in the room, are all showing the same dip in the 40-60Hz range. I would think that to be highly unlikely.
Being an amateur detective, I would devise a test to figure out what is going on. For example, launch REW, open up the tone generator, and set it up to generate a 50Hz sine wave on HDMI4 (LFE). Place the mic near the center of the room, say 2ft to the left of the MLP. Turn off all but one sub. Output the 50Hz tone and record the output level as shown on the REW SPL meter. Without moving the mic, turn off the first sub and turn on the second sub. Output the test tone again and measure the level. Continue until all subs have been measured at position 1. Now move the mic to a second position, say 3ft behind the MLP. Re-run the level test for each sub at this new location.
After you have gone through this exercise for at least two mic positions (or more), compare the output results. There should be a significant variance among the measurements, from sub to sub, and from mic position to mic position. In my room, for one position and for four subs, I received measurements of 70, 74, 82, and 80. You should see the same variability. And as you move from one mic position to another, the output level for 50Hz should change. In other words, there is no way that you should see low levels at 50Hz for all subs at all positions, unless something is wrong with your measurement gear.
So what does this exercise prove? It shows that there has to be someplace in your listening room where the 40-60Hz dip doesn’t exist. Of course, that may be in a spot where it is impossible to locate a sub. If that is the case, then that is bad luck indeed.
ahblaza likes this.
post #24868 of 27619 Old 06-01-2018, 07:14 PM
veger69's Avatar
Quoted: 301 Post(s)
Liked: 47
Jerry I’ve seen the same results with the Anthem ARC mic using the Quick measure feature of ARC
And the same dip in the FL, FR, and C channels
veger69 is offline
post #24869 of 27619 Old 06-01-2018, 07:25 PM
Liked: 6578
Jerry I’ve seen the same results with the Anthem ARC mic using the Quick measure feature of ARC[
I am puzzled. There should be areas of the listening room that don’t show that dip.
post #24870 of 27619 Old 06-02-2018, 04:49 AM
JohnPM's Avatar
Quoted: 129 Post(s)
Liked: 129
Try a different measurement position rather than a different source position.
JohnPM is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
