Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 856 - AVS Forum | Home Theater Discussions And Reviews
 4792Likes
post #25651 of 29492 Old 10-16-2018, 05:56 PM
LGERIC's Avatar
Quoted: 132 Post(s)
Liked: 43
Originally Posted by AustinJerry View Post
For the REW sweep, are you measuring re-directed bass, using one of the HDMI channels associated with the main speakers? Or are you measuring the LFE channel (HDMI4)?
You really need to be measuring voltages with a DMM to implement proper gain management. There is a section on gain management in the 88BM implementation guide linked in my sig. You may find something useful in that guide.
I tried HDMI4 and HDMI3 with the same results. I know I can just lower the gain on the avr but I want to do it the right way. Thanks for the info. I will check out your guide as they have always been ver helpful.
65" Sony X900E, Denon X2300, SVS Prime LCR, Polk TSI100 surround, 2X 18" RSS460HO sealed 3.5ft3, Inuke 6KDSP, minidsp 2x4 revA
LGERIC is online now
post #25652 of 29492 Old 10-16-2018, 06:42 PM
LGERIC's Avatar
Quoted: 132 Post(s)
Liked: 43
I looked at the guide. I found that the 40hz at 0db could be helpful. The problem I am having is when I use rew as the source I don't see the changes when I adjust the sub gain in the avr so I don't truly know what the changes I am making are doing..
I have a DMM what setting and what voltage would I be looking for?
post #25653 of 29492 Old 10-16-2018, 07:40 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 12680 Post(s)
Liked: 7595
What model MiniDSP are you using? And when you say you are not seeing the changes, where are you looking? At the output level indicator on a MiniDSP? I need more specific information on what you are trying to do, because it probably isn’t the same as what I describe in the guide.
AustinJerry is online now
post #25654 of 29492 Old 10-17-2018, 09:20 AM
tamiya's Avatar
Quoted: 212 Post(s)
Liked: 55
Can you treat HDMI4 as sub only measurement?
Marantz AV7703, Outlaw 7700+5000
LCR JBL 590, Surround 530, Surround Back 520c, Atmos Arena B15
IB SBA setup with 4x18" IB3-V2 & NX3000D
Epson 5040ub, 133" 16:9 Milliskin
FS: Brand new never open JBL Studio 580 speaker pair
tamiya is offline
post #25655 of 29492 Old 10-17-2018, 10:19 AM
Liked: 7595
Yes, but measurements taken with HDMI4 (LFE) will be 10dB higher than measurements taken with redirected bass on one of the other HDMI channels. This is not an issue, but you need to be aware of it in case you notice higher levels.
post #25656 of 29492 Old 10-17-2018, 07:11 PM
LGERIC's Avatar
Quoted: 132 Post(s)
Liked: 43
It is a 2x4 non hd. I am trying to lower the level in the avr to prevent the mini dsp from clipping.
My goal is to raise the amps level to get back to the same output as where I started. Hopefully without clipping the amps.
First I ran a sweep to get a baseline of the levels. Then I lowered the sub trim in the avr and ran another sweep. Nothing changed so I began to investigate further. Also monitoring the input level of the mini dsp I saw no change. I began to use the db meter while using the test tones or pink noise in rew. When doing this and changing the gain in the avr WITH REW AS THE SOURCE I saw no changes to the db meter when changing the level in the avr.
When using the test tone in the avr I can see the db meter raise and lower as would be expected.
I think my best bet will be to play some of my most demanding content and lower the avr gain while monitoring the mini dsp levels. Then raise the sub levels.
post #25657 of 29492 Old 10-17-2018, 07:33 PM
Liked: 7595
You don’t specify whether it is balanced or unbalanced and, if unbalanced, whether it is Rev A or Rev B. The balanced has switchable input voltages of 1.8v or 4v. The unbalanced Rev A has a .9v input, while the Rev B has a 2v input.
I would raise the AVR master volume to unity, set the sub trim to zero, and measure the output voltage using a DMM. Depending on what you measure, set the 2x4 jumpers for the appropriate voltage input level. Then, If the voltage still exceeds the input specifications depending on the type of 2x4 you have, I would lower the trim until it falls within the desired range. This assumes that varying the trim produces measurable output voltage variations, and I don’t see why it wouldn’t.
Once the input voltage to the 2x4 is verified, output the sub level setting test tone from the AVR (again, with the AVR MV set to unity) and adjust the gain control on the sub until you measure 75dB output at the MLP. Then you should be done, and can be confident that the 2x4 input is not being overdriven even when the AVR is outputting at reference levels. Make sense?
ahblaza likes this.
post #25658 of 29492 Old 10-18-2018, 07:04 AM
LGERIC's Avatar
Quoted: 132 Post(s)
Liked: 43
Sorry. It is unbalanced revA
post #25659 of 29492 Old 10-18-2018, 12:45 PM
Liked: 7595
My recommendation is to follow my previous advice, assuming that you have a DMM. There are inexpensive DMM's at Home Deport, and it is a nice tool to have.
post #25660 of 29492 Old 10-18-2018, 01:24 PM
LastButNotLeast's Avatar
Quoted: 3045 Post(s)
Liked: 2858
FYI, that's a digital multimeter.
LastButNotLeast is offline
post #25661 of 29492 Old 10-18-2018, 04:55 PM
LGERIC's Avatar
Quoted: 132 Post(s)
Liked: 43
So the goal would be to keep the voltage at or less than.9 volts with the avr mv at 0?
post #25662 of 29492 Old 10-18-2018, 05:29 PM
Liked: 7595
Yes, AVR MV = 0 is defined as “Reference”, which is as loud as you should ever want to play your system. So if at Reference the voltage does not exceed .9v, then at any lower volume you will be safe. And, of course, you need to adjust the sub gain so you get back to 75dB at the MLP when playing the AVR test tones at reference. Easy, isn’t it?
Let us know how it goes.
post #25663 of 29492 Old 10-18-2018, 06:21 PM
LGERIC's Avatar
Quoted: 132 Post(s)
Liked: 43
Will do thanks!
post #25664 of 29492 Old 10-21-2018, 05:59 AM
superkyle's Avatar
Quoted: 1092 Post(s)
Liked: 515
Hey Guys I am having a lot of struggles trying to get all my speakers setup in my room. It is a 20' wide room with 19' depth Vaulted ceiling that peaks at 13.8'. I have ran many measurements as well as positioned the sub just about everywhere I can think of. I can get the sub response to look very good IMO but when I pair it with the speakers sound below the crossover is still being sent to the speakers and the graphs end up looking terrible. Any clue what I am doing wrong? I need lots of helps s anyone willing to take the time would be greatly appreciated as I would really like to get this done! All graphs below are smoothed using variable smoothing. It really seems like every adjustment I think should work ends up making it worse. I've done this before in a much more user friendly room with ease but this room requires me to reach out to the experts here for advice.
Speaker setup:
Left/Right: Klipsch rf7III
Center: Klipsch rc64III
Surrounds: Polk RTI4
Sub: Rythmik FV25HP
Receiver: MarAN
Name:	80hz With AUD.jpg
ID:	2471328   Click image for larger version
Name:	60hz with AUD.jpg
ID:	2471330   Click image for larger version
Name:	60hz No AUD.jpg
ID:	2471332   Click image for larger version
Name:	80hz No AUD.jpg
ID:	2471334   Click image for larger version
Name:	HDMI4 With AUD.jpg
Name:	80hz run with HDMI4 added with AUD.jpg
ID:	2471338   Click image for larger version
Name:	60hz run with HDMI4 added and AUD.jpg
ID:	2471340   Click image for larger version
Name:	60,80,100 hz sub off sweeps.jpg
ID:	2471342   Click image for larger version
Name:	HDMI4 Without AUD.jpg
Always destroying exergy!
superkyle is offline
post #25665 of 29492 Old 10-21-2018, 07:14 AM
Liked: 7595
When posting images, select the “Include Legend” option, which will provide the description on the bottom of the measurement screen identifying the measurements. Also, provide a description for each measurement in the small box associated with the measurement, like “Left speaker, no subs” Otherwise, we will not know which measurement is which.
If the bass frequencies are being routed to the mains below the crossover, this typically happens when the speakers are set to Large. However, you can’t establish a crossover if the speakers are set to large, so this can’t be the case. Perhaps your crossover is set too low? To verify that the mains are indeed receiving a signal below the crossover, turn off the sub(s), set the crossover to a high value (at least 100Hz), and use the REW Signal generator to send a low frequency signal, say 50Hz, to see if the tone is being reproduced by the mains. You may hear some low frequencies, since the crossover is not a brick wall, but the level should be attenuated.
Other than that, I have no additional comments, since I can’t identify the specific measurements in your screenshots.
superkyle likes this.
post #25666 of 29492 Old 10-21-2018, 07:37 AM
superkyle's Avatar
Liked: 515
Jerry first off I want to give you a very heartfelt thank you for the guide you have posted. It allowed me to pursue this level of audio integration. Without it I would not even be here attempting to learn about such a great hobby and for that I really thank you.
Secondly, I have updated the graphs as well as posted a plot using the HDMI1 and sub off. Personally I am just not very happy with the results I am getting and have moved the speakers everywhere I could Imagine. Any advice on things to try or do to better the results in my room would be greatly appreciated for sure.
EDIT: I have added a picture of the room. I wanted to provide as much information as I can to anyone willing to help a fellow member out!
AustinJerry likes this.
post #25667 of 29492 Old 10-21-2018, 08:42 AM
Liked: 7595
Thanks for the kind words. You have a very nice listening room, although a challenging one from an audio perspective. I also have a living room as my primary listening area--you can see pictures in the My Setup link in my sig. I have a significant amount of treatments and have achieved a pretty good result. Wife acceptance factor may limit your treatment options (I am a single guy).
Thanks for adding the graph descriptions. Only three graphs are of interest to me: no 2 (mains, Aud on), no 5 (Sub only, Aud on), and no 8 (Mains only). BTW, is graph 8 with or without Audyssey? And do not measure mains AND HDMI4. As long as the mains are set to Small, the measurement will include the low frequencies coming from the sub. Adding HDMI4 (which is LFE) only doubles up the bass (at 10dB higher) and distorts the results.
Graph 8 showing mains only looks normal. Graph 5 showing subs only looks quite good. However, graph 2 showing Mains+sub, does not look very good. I don't know why the mains and subs are interacting poorly. Several suggestions: 1) experiment with a higher crossover, 2) double-check to make sure there isn't a polarity issue (using REW Impulse response--see Guide), and 3) experiment with the "Sub distance tweak". Let me know if you are unfamiliar with the distance tweak and I'll describe.
post #25668 of 29492 Old 10-21-2018, 08:54 AM
superkyle's Avatar
Liked: 515
Thanks again for your support on this. That is exactly what I do not get. My sub response seems very good for single sub in an odd room. Once I add in the mains everything looks terrible.
I have not looked at polarity issues so I will do that now and post back. I’ve played around with the sub distance tweak but not sure I am doing it correct or not. Basically just add up to 3’ or subtract up to 3’ measuring each step size of say 0.5’ to see if it helps or hurts. Is this correct? Will post back results shortly.
EDIT: Attached are the impulse responses. It seems they are off a bit. For clarification I used the right rear speakers HDMI6 as the timing reference when taking the measurements. All measurements that are shown are with AUD on. I am not quite sure what I am looking at here or what I can do to fix it. What do you think?
EDIT2: Added graphs for 100hz crossover Also I tried the sub tweak but was unable to really change the graph. Minor peak and Null changes but where it was placed seemed to be the best so left it alone. Certainly I must be doing something wrong or Audyseey is really throwing me off bc The results from audyssey are trimming down the bass on my mains drastically but yet I am left with a unsmooth graph. Would it help me at all to buy a minidsp and run the sub through it then tweak with Audyssey?
Name:	impulse responce LCR 60hz with HDMI4 overlay.jpg
ID:	2471400   Click image for larger version
Name:	impulse responce LCR 80hz with HDMI4 overlay.jpg
ID:	2471402   Click image for larger version
Name:	HDMI1,2,3 at 100hz with AUD.jpg
post #25669 of 29492 Old 10-21-2018, 01:19 PM
Liked: 2858
With my Pioneer, mains on large and subs on plus, changing the xo still has an effect, so that may be brand-dependent.
Michael
post #25670 of 29492 Old 10-21-2018, 02:31 PM
Liked: 7595
Michael
The OP clearly showed that he has a Marantz in his post, so not applicable.
post #25671 of 29492 Old 10-21-2018, 05:10 PM
superkyle's Avatar
Liked: 515
Jerry I indeed have a Marantz. I continued to play around with placement taking graphs and trying various different things. I will say the 100hz graphs I posted did look a little better but running rf7iiis at 100hz has to be a sin! In all seriousness though how does the timing graph look? Any ideas of what I could provide the group such that someone may see the smoking gun that’s causing my terrible response in my room?
post #25672 of 29492 Old 10-21-2018, 05:29 PM
Liked: 7595
The impulse response graphs need to be re-worked. If you look in the lower right corner, you will see “+” and “-“ signs. Use the + sign to zoom in on the impulse responses so that we can see whether the initial pulse is upwards or downwards. The initial pulse for all speakers should be in the same direction, which would indicate correct polarity. The initial pulse should line up as well, indicating good time alignment. Re-post the measurements after you have made this correction, please.
No need to be concerned with a higher crossover, regardless of how capable your mains are. Subs are inherently better at reproducing low frequencies, and can be placed to produce the smoothest response. The mains are positioned to produce the best soundstage. The position for best soundstage and the smoothest bass response rarely coincide. I have highly-capable mains (PSB Synchrony One’s), and still use a 100Hz crossover.
I can’t really tell whether the latest frequency response measurements are better or not.
sdrucker likes this.
post #25673 of 29492 Old 10-21-2018, 07:22 PM
brettus's Avatar
Quoted: 51 Post(s)
Liked: 30
@superkyle ,
My advice for now mate is to put a movie on with the missus and kids (if you have them) and just try to enjoy. That means have a few beers to relax so your brain forgets the frequency response in REW of here and there locations....if you're a recovering alcoholic or whatever then hooch, a coffee or some pushups but just relax and enjoy!
brettus is offline
post #25674 of 29492 Old 10-22-2018, 03:07 AM
superkyle's Avatar
Liked: 515
Originally Posted by brettus View Post
@superkyle ,
Oh I have but after movie night I wake up knowing that I can do better. Until it’s fixed or I have resolved everything possible to fix it without adding 4” bass traps all over the room I am hoping to keep going.
Thanks Jerry! I will work up the graphs when I get off work and post them back. While I hope that is the issue I’m leaning toward the room just being a pain in the butt. Since the sub and sealers are effectively pointing the same direction I’m wondering if they are not voicing off and causing all kind of chaos. Certainly good bass response has been achieved with a vaulted ceiling open floor plan.
Anyone have this style room? What was done to achieve better results? I know may will say add a sub but with the single bass response smooth would that benefit me at all?
post #25675 of 29492 Old 10-22-2018, 07:00 AM
Liked: 7595
Bass traps address resonance, which is measured with the waterfall graph. The most effective way to smooth out bass response is 1) positioning (which you have tried), and 2) adding additional subs. Whether or not you add additional subs depends on whether or not you are pleased with the sound. Let your ears be the final judge, not some slight imperfections in REW response curves. I have an open floor plan as well (but not vaulted ceilings), and it took four 15” sealed subs to achieve a fairly flat bass response, plus a lot of moving subs around the room.
And I agree, before you consider adding additional subs, we need to figure out why the mains and sub are not playing nice together.
You might want to post a waterfall graph (mains+subs, Audyssey on) so that we can see how well bass resonance is being controlled.
post #25676 of 29492 Old 10-22-2018, 07:08 AM
Liked: 7595
BTW, as you were moving the sub around to find the best location, did you re-run Audyssey in the current speaker and sub layout? Audyssey is sensitive to speaker placement, and needs to be redone when you make changes.
And if you want to, can you upload your REW measurement MDAT file to a file-sharing site (like Dropbox.com) so that I can download it and look at it? I would like to see the main speaker measurements without the sub, and the sub measurement by itself, Audyssey either on or off.
post #25677 of 29492 Old 10-22-2018, 02:53 PM
superkyle's Avatar
Liked: 515
Jerry sorry for the delay as I was stuck at work. Now that I am home I will be happy to upload my files to Dropbox as well as add any additional measurements requested. I really appreciate it bc I just can’t find out why they are fighting and it driving me mad haha.
To answer your questions I looked at the impulse response and all do move in the same direction however none are stacked on top of each other. This includes with and without Audyssey on.
As far as running Audyssey each time I move I will say that I do but with an asterisk. What I mean by that is I will run sweeps moving the sub all over the room with Audyssey off. Once I feel I get a spot that is showing good response I will run the full 8 positions. My position sequence covers 8 positions all on my couch as I have tried it as the diagram shows as well as many others and this seems to provide a little better results at the MLPs. Let me know how I can share that Dropbox file with you and I’ll upload it now.
EDIT: Link Created for downloading measurments
https://www.dropbox.com/s/bkdx47a95t...tion.mdat?dl=0
post #25678 of 29492 Old 10-22-2018, 04:42 PM
Liked: 7595
Typically you would move the sub around, and take measurements with Audyssey off. Once you feel you have found the best spot, then run Audyssey again. In theory, the best measurement with Audyssey off should yield the best result with Audyssey on as well (and hopefully even better).
The impulse response overlay shows all three mains with the same polarity (good), but with a slight timing difference. However, the timing issue is only .14ft, or 1.7 inches. Hardly anything to worry about, and certainly inaudible. Audyssey has done a good job with alignment.
The sub is also showing the same polarity, so no problem there.
The ETC measurement is showing a significant reflection between 11 and 11.5 feet from the measurement mic's position. You should try and identify what is causing that reflection. There are several other less serious reflections.
And finally, the waterfall is showing significant ringing in the 35-70Hz region, which is difficult to resolve without adding tons of bass traps.
As far as addressing a rather serious dip in combined mains+sub response at 64Hz, and another dip between 90 and 95Hz, I think the sub distance tweak might help:
1. Measure left+sub with the default sub distance established by Audyssey.
2. Increase the sub distance, say 5ft as a starter, and re-measure.
3. If improved, keep increasing in 1ft increments until the measurement starts getting worse. Pick the distance that produced the flattest response.
4. If 5ft makes the measurement worse, try 4ft, then 3ft, etc. looking for the flattest response.
5. Once you have settled on a distance, measure right+sub and center+sub to verify that the measurement is flatter for both of those as well.
Publish your results, hoping they are improved.
post #25679 of 29492 Old 10-22-2018, 04:58 PM
superkyle's Avatar
Liked: 515
Jerry, wow I really appreciate you taking the time and helping me out with this. What you have laid out for measuring sub locations is exactly what I attempt to do so sounds like I am on the right track there. What I may be doing wrong is while I moved the sub around I only took sub measurements ie hdmi4. I know it makes it louder but I was only looking at response. I may spend some time this weekend moving it around and look at how all three (LCR) behave at each spot as I may just have to use the give and take method and settle.
The ringing at 11 feet is odd. The main thing that comes to mind it the front of the room where all the speakers are. That is nearly the correct distance. This also matches the back corner of the room and even worse matches the distance to the peak of the ceiling.
With the waterfall my sub does have PEQ would it be possible to reduce the Db over a fairly large bandwidth say at 50hz? I’m fairly new to sub PEQ also but is this not what it should be used for? Knowing this location may help me eliminate the ringing a little and help with sounds canceling out.
I should be able to run the sub distance tweak tomorrow after work so I can have those posted fairly quickly. I also have a few that we’re not included like the 100hz sweeps which is what it is set at currently. I really think that increasing it even more may work out but I’m worried I may reach the point of vocals coming through the sub and I want to avoid that.
post #25680 of 29492 Old 10-22-2018, 05:04 PM
Liked: 7595
The guide has some tips with respect to locating the source of reflections.
I wouldn’t raise the crossover above 100Hz. And I doubt whether PEQ will improve bass ringing. Get used to the fact that there never is an easy answer—you just need to keep experimenting and measuring until you are happy with (or can live with) the sound.
ahblaza likes this.
#rew , #room acoustics , #studio , Dayton , Dayton Audio , Room Equilizer Wizard Rew
