5.1 setup back speakers larger than front? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-25-2014, 10:35 AM - Thread Starter
alfred34's Avatar
Hi
I bought an house which came with a polk audio 5.1 speakers system.
All cable are already in the wall so that's convenient. However the left and right speakers are way too close from each other, especially the surround ones. That makes me think the previous owner didn't know much about 5.1 setups.
The surround speakers are also bigger than the front ones. I wondered if it was a mistake or there was a reason for this?
thanks
alfred34 is offline
post #2 of 14 Old 01-26-2014, 10:07 AM
Ethan Winer's Avatar
Quoted: 270 Post(s)
Liked: 411
Ideally all five main speakers will be the same make and model. As for placement, this will help:
How To Set Up A Room
--Ethan
Ethan Winer is offline
post #3 of 14 Old 01-26-2014, 10:10 AM - Thread Starter
alfred34's Avatar
thanks but I am not going to buy new speakers, so I wonder if I should keep the larger ones at the back or bring them at the front?
alfred34 is offline
post #4 of 14 Old 01-26-2014, 01:54 PM
jlauderdal's Avatar
yes you should
jlauderdal is offline
post #5 of 14 Old 01-26-2014, 01:55 PM - Thread Starter
alfred34's Avatar
I should do what? :P
alfred34 is offline
post #6 of 14 Old 01-26-2014, 03:23 PM
Jack D Ripper's Avatar
Quoted: 168 Post(s)
Liked: 544
Size is not the same as quality.  Without knowing what they are, it is impossible to tell whether they are better or worse than the ones up front.  The better ones, if they are not all the same, should be up front.  But the front three should be "voice matched," so if the current three up front all match, and the rear ones don't, then you probably don't want to simply move the rear ones up front, even if they are better.  You would want to also replace the center with something that matches them, if you were to move the rear speakers up front and if they are not "voice matched" to the center speaker.
I would try listening to the rear speakers, as if they were just a stereo pair, and listen to the front right and left as if they were just a stereo pair, and decide whether I thought they sounded much different.
If you want more specific help from us, we would have to know what models of speakers we are discussing.  As I stated, size is not the same as quality.  Usually, though, if the speakers are not the same, the larger ones are put up front.  But it is certainly possible that they are all where they should be.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
post #7 of 14 Old 01-26-2014, 03:51 PM
Liked: 63
Yeah, might be that the surrounds are just some old speakers they had lying around and they put them to use.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #8 of 14 Old 01-26-2014, 05:17 PM
jlauderdal's Avatar
bring larger to the front
post #9 of 14 Old 05-20-2020, 08:20 AM
Liked: 0
Hi all,
I'm in a similar position, I have 3x cambridge audio x21s 2x cambridge audio x11s and an x301 subwoofer. im planning on putting the 3 x21s up front the two x11s to the side/back.
unfortunately i'm limited on where i can place the sub (apparenlty its a monstrosity, even tho i downgraded it from the x501 for peace and quiet)
The room is this shape.
Will it be okay to put the sub in the top left corner, and do you guys have any recommendations for angle/placement? Also is it best to put the 3 same x21s at the front?
Thanks all.
Rob
ROB HERD is offline
post #10 of 14 Old 05-20-2020, 09:56 AM
Quoted: 212 Post(s)
Liked: 1970
Outstanding necro.
leecreek is offline
post #11 of 14 Old 05-20-2020, 03:26 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
You may want to start your own thread for better feedback, but you should definitely move the sub to top left for the corner boundary reinforcement, and just being in the same room
I'd just say to angle the woofer towards the seating position, but you can experiment.
You'll get a flurry of recommendations to upgrade your speakers (they're pretty small for a surround setup and rely heavily on the sub), and sub (you may want more low-frequency for HT).
3 of the same speaker up front isn't a problem.
Originally Posted by ROB HERD View Post
Hi all,
Thanks all.
Rob
philpoe is online now
post #12 of 14 Old 05-20-2020, 03:30 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
Can you provide the model numbers of the Polk speakers?
Can you provide a picture of the setup?
Generally speaking, you want the most capable speakers handling the majority of the work. In a surround setup, the center channel carries the load, then front L/R, then surrounds.
I think that the sub is more important than any speaker except the center. Did the previous owner leave that as well? If so, what model?
Hi
thanks
post #13 of 14 Old 05-28-2020, 11:14 AM - Thread Starter
alfred34's Avatar
Hi
I don't see any model number on it. Here are the pictures. They all look the same. Except the back L/R (which were previously installed at the front, but I moved them) are larger and the center is horizontal while the others are vertical.
pictures of center, back, front speakers.
ID:	2733626   Click image for larger version
ID:	2733628   Click image for larger version
alfred34 is offline
post #14 of 14 Old 05-28-2020, 12:28 PM
Joe Fernand's Avatar
Quoted: 656 Post(s)
Liked: 354
The Model number is likely on a plate on the Rear of the Loudspeaker cabinets - you will need to lift them off of the wall to see that info.
If I follow you swapped the Front LR and Rear (or Surround) LR over as the Rear where physically smaller cabinets - that would suggest you have also switched the 'capabilities' of the two types of Speaker and would be better (sonically) swapping them back to the original positions.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
