so I posted a thread about building a cheap system here:
http://www.avsforum.com/t/1519352/threw-together-this-cheapo-system-what-do-you-guys-think
upon heavy recommendation from the forum, and nearly half of the forum viewing that monoprice is the best audio cable on the market for the best price.
http://www.avsforum.com/t/1518761/whats-your-favorite-cable-manufacturer-poll
with that said, I took the plunge and ordered some of it. and I went to radio shack to buy AUVIO to decided what I wanted to run.
first impressions of mono-price cable. along with a comparison to what is available to me locally.
1: dirty, when I opened the box, the spool looked used, beaten to hell and wrapped in what looked to be used/recycled sandwhich wrap.
it's not a big deal, so I took the cable off of the melting card board spool and discarded it. smelled like cheap china product you get on ebay, which nobody tells newbies for some reason.
I ordered 50 feet no logo, I got 50 feet no logo so that's a plus. radioshack's 25 foot spool only had about 20 feet in it.
2: it's thinner, and the strands are wrapped in a sloppier manner than the AUVIO cable. Radioshacks cable looks good, looks expensive, looks quality like what you would expect a "high end" speaker system to use. Mono-price stuff SHOULD BE SLEEVED/COVERED/BOOTED in my opinion
3: it's closer to radio-shack's 14 gauge cable than the 12 gauge, monoprice claims that the jacketing is thicker on the radioshack stuff hence the thickness difference, not true, I striped the jacketing off to get a banana plug on it, and there is more copper on the radio shack AUVIO 12 gauge.
jacketing quality is poor, takes 1-4 strands when you strip it no matter how great your stripper is. auvio cable is easier to strip, strips kind of like Monster cable i had in my boat/car 10 years ago, or like the great speaker cable that pioneer gave us on my dad's 90's 5.1 DD theater system.
the fittings from monoprice are harder to use than the banana plugs I picked up at radio-shack as well (however there is a $15 price difference PER SET, so pick your poison there, I just dealt with the so-so plugs at the speakers and sub, but I sprung for the higher end plugs at the amp end due to it being the expensive part of the system)
ending notes: I would NOT recommend this cable for someone who will have speakers in a visible location. but If it is used in a manner where you can see very little of it, or if you plan on sleeving it, it works fine.
monoprice 12 gauge cable is low end, cheap cable made thicker, if you take anything from this review, buyer beware, this brand is hyped because ......i don't know................it looks nearly identical to the low end RCA brand speaker wire sold at Walmart, just about 3 times as thick.
