What is your LFE low pass filter setting? - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What is your LFE low pass filter setting?
80hz 34 41.98%
120hz 34 41.98%
Other 13 16.05%
Voters: 81. You may not vote on this poll
 6Likes
post #1 of 39 Old 04-28-2015, 08:49 PM - Thread Starter
primetimeguy's Avatar
Quoted: 715 Post(s)
Liked: 466
I'm curious what people set the LFE low pass filter (lpf) to in their receiver or pre/pro.
I know technically 120hz should be the correct setting as that is the limit of the LFE channel but in the Audyssey thread and other threads it has been discussed that people recommend an 80hz setting as it reduces some of the bloated or muddy bass in some 5.1 tracks. I have just recently found this to be the case and now am using the 80hz setting.
So just curious as to what others are doing and please don't confuse this question about the LFE lpf with a speaker crossover bass management setting or the lpf knob on your subwoofer.
primetimeguy is offline
post #2 of 39 Old 04-28-2015, 08:55 PM
A9X-308's Avatar
Quoted: 1807 Post(s)
Liked: 1495
It should be whatever works better for your gear and room. I use 80Hz, but 60Hz also works as well.
primetimeguy likes this.
A9X-308 is offline
post #3 of 39 Old 04-28-2015, 11:13 PM
grasshoppers's Avatar
Quoted: 960 Post(s)
Liked: 701
I use 120hz and don't have any bloat
Or muddy bass. Wouldn't have a problem
Using 100hz either. Don't think I would want
To go any lower though.
FWIW YMMV.
(Main)-Marantz 6012*Outlaw Audio M2200*Rythmik F12 subs*Paradigm Signature S6,C1,S1
******Harman Kardon DMC1000 (music)-Assassin HTPC (movies).
(Bedroom)-Marantz SR5003*Paradigm Studio 40,SE Center,SE One*SVS SB-2000 subs*Sony S6200
(Music room)-Outlaw Audio RR2150*Sierra Two ribbon speakers*Rythmik L12 sub*Yamaha CDR-HD1500
grasshoppers is online now
post #4 of 39 Old 04-28-2015, 11:29 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4796
I haven't had any issues but haven't experimented, although I'm willing to experiment, I've just gone with that general wisdom that it shouldn't even be adjustable and should be left at 120. I just got Everly which apparently has good low end content, maybe that will be a good candidate.
Curious, was it particular movies where it was muddy or this is across the board definitely less muddy set at 80? Anyone changing back and forth?
I had to go look to even see what my options are....my Onkyo offers 80, 90,100,120 or bypass; my Denon offers 80,90,100,110,120,150,200,250; my Pioneer nor Sony have an adjustment.
ps Is this always implemented the same way in bass management among the avrs?
lovinthehd is offline
post #5 of 39 Old 04-29-2015, 06:24 AM - Thread Starter
Quoted: 715 Post(s)
Liked: 466
The biggest difference is in concert/music Blu-rays. But the difference is notable on all movies too, obviously those will bass more so. And maybe muddy is the wrong word. The reduced level in the 80-120hz range removes some of the chest slam but allows you to better here the lower bass and doesn't seem to drown out the upper bass from the other speakers. So it just sounds different and preferable for me to set it to 80hz.
And I should add that I did bump up the sub level a couple db after this change. So running about 4-5db hot now rather than 2-3db hot.
post #6 of 39 Old 04-29-2015, 06:56 AM
ChromeJob's Avatar
Quoted: 2115 Post(s)
Liked: 1106
Oops, didn't see that last sentence. Had no idea that some systems let you trim the .1 LFE channel.
"Exceedingly odd," said the butler.
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is offline
post #7 of 39 Old 04-29-2015, 07:00 AM - Thread Starter
Quoted: 715 Post(s)
Liked: 466
Originally Posted by ChromeJob View Post
This all depends upon what front and center speakers you have. If you have smaller bookshelf speakers, you can set the crossover higher. If you have full range speakers but set to "small" in the AVR, then setting the crossover to the THX recommended 80Hz makes sense.
If you download some test files fr audiocheck.net, you can see if your main speakers have any deficiency in the lower register.
This all falls in the realm of bass management that AVRs offer. Each system or set of speakers will be different, comparing cross over freqs from one person to another without context is less than half the picture. Audioholics.com has a couple of good articles on bass management, including one on where to set your cross over. "Muddy" bass will depend upon your speakers, and your avr settings.
... FWIW, I have Bose 401s for mains, set "small" with cross over at 120Hz in my setup. Why: they produce down to 40Hz, but inconsistently < 100Hz. Using sweep test files, found there's a dip around 130Hz, so letting my sub start in that area smooths out the response.
No, it has nothing to do with your speakers. This is not about the crossover for your speakers. It is the low pass filter for LFE which is the dedicated .1 channel. It is a separate setting in some receivers, some may not have the setting at all. It has no impact on the signal sent to other speakers.
post #8 of 39 Old 04-29-2015, 07:02 AM
eljaycanuck's Avatar
Quoted: 1916 Post(s)
Liked: 2701
I use the default 120Hz setting.
Originally Posted by Homer J.
Default? The two sweetest words in the English language! De-FAULT! De-FAULT! De-FAULT!
eljaycanuck is online now
post #9 of 39 Old 04-29-2015, 07:05 AM
smcmillan2's Avatar
Quoted: 950 Post(s)
Liked: 814
Correct. And lowering the setting causes anything above that (to 120Hz) to be discarded from that channel, which appeals to some:
https://www.avsforum.com/forum/90-rec...a-1726.html#c5
I leave it at 120Hz.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #10 of 39 Old 04-29-2015, 07:08 AM - Thread Starter
Quoted: 715 Post(s)
Liked: 466
Not discarded, just rolled off more.
post #11 of 39 Old 04-29-2015, 07:12 AM
ChromeJob's Avatar
Liked: 1106
Oooohhhhhh. Didn't see that distinction in your first post.
Need more coffee....
post #12 of 39 Old 04-29-2015, 07:30 AM
smcmillan2's Avatar
Quoted: 950 Post(s)
Liked: 814
Negative, it's discarded. From the link I posted (and that info was directly from Chris Kyriakakis AFAIK):
If you set it to anything below 120Hz then any content between 120Hz and whatever you set it to is lost. It is not redirected anywhere - it is simply discarded.
Again, it's only content on the LFE channel.
post #13 of 39 Old 04-29-2015, 07:47 AM - Thread Starter
Quoted: 715 Post(s)
Liked: 466
You need to read the entire section of the post you linked. :-)
We should have Keith update his FAQ answer to remove the word "discarded". His quotes from other people actually back up the idea it is not a brickwall filter.
Mark explains it like this in this post:
"I personally tend to set the low pass on the LFE channel at 80Hz in most systems by preference. I think many forget that the difference between a 120Hz low pass and an 80Hz low pass is nothing more than a shelving filter. If the low pass is 4th order, the 80Hz filter is about 7dB lower at 100Hz and about 4dB at 80Hz. A 100Hz low pass setting would have about 1/2 that difference. The adjustment has more effect on shaping the LFE track's response than it does on cutting off content. If you're running the subs with a rising response on the low end which blends with the main speakers, experimenting with 80, 100 vs. 120Hz is basically a means to taper the top end of the LFE channel. Setting this lower than 120Hz is not hacking off content any more than setting your sub a few dB hot would destroy a soundtrack."
I have graphs to prove it from a while back where I played around with the setting.
post #14 of 39 Old 04-29-2015, 07:49 AM
krabapple's Avatar
Quoted: 487 Post(s)
Liked: 469
LFE @ 120. Bass redirection from other channels @ 80
krabapple is offline
post #15 of 39 Old 04-29-2015, 07:56 AM
smcmillan2's Avatar
Quoted: 950 Post(s)
Liked: 814
Right you are, I had not read through that before and had seen the "discarded" comment mentioned in other forums so I took it as truth.
Thanks, and apologies for perpetuating the misinformation.
post #16 of 39 Old 04-29-2015, 08:12 AM
kbarnes701's Avatar
Quoted: 7743 Post(s)
Liked: 7046
Agreed. "Discarded" is too strong. If you set the LPF of LFE to, say, 80Hz, there will be a roll-off above that frequency, so some content above 80Hz will still be present, but much lower in level. I will amend the FAQ to reflect this distinction.
c)5. What is the LPF of LFE and what should it be set to?
kbarnes701 is offline
post #17 of 39 Old 04-29-2015, 09:47 AM
jim19611961's Avatar
Quoted: 451 Post(s)
Liked: 158
I agree XO points are very room and system dependent. In my case, I have (3) subs. (2) have a XO of [email protected]/oct. (1) has a XO of [email protected]/oct.
One point of note though. Our hearing doesn't become totally non-directional until about 80hz. Depending on sub location, a 120hz XO (even 80hz with a gentle slope) could really foul up lower midrange/upper bass imaging.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #18 of 39 Old 04-29-2015, 03:03 PM
They_call_me_Roto's Avatar
Quoted: 353 Post(s)
Liked: 255
200 Hz
Packing a lot of sound into a small room.
268 square feet/2144 cubic feet
7.2 surround sound.
They_call_me_Roto is offline
post #19 of 39 Old 04-29-2015, 03:14 PM
lovinthehd's Avatar
Liked: 4796
I'll try some of my bluray music next. I did go back and forth between 120 and 80 on Everly last night a little bit. Just seemed to thin out the LFE a bit and I think I prefer it fuller.
Thanks for the clarification on whether the 120hz thing was a cutoff as I'd read Chris K's comment a long time ago, but had seen some of Mark's recently, too.
post #20 of 39 Old 04-29-2015, 03:22 PM
cdelena's Avatar
Quoted: 107 Post(s)
Liked: 67
I have experimented going back and forth between 80 and 120. Spend few days with each and you can find numerous places to hear the difference. I will stick with 80 from now on.
cdelena is offline
post #21 of 39 Old 04-29-2015, 03:33 PM
lovinthehd's Avatar
Liked: 4796
How do you set separate crossovers per sub?
post #22 of 39 Old 04-29-2015, 03:53 PM
Quoted: 451 Post(s)
Liked: 158
The knob on the back
My Room
My Music
Jenzen Next
post #23 of 39 Old 04-29-2015, 03:58 PM
lovinthehd's Avatar
Liked: 4796
So you're bypassing the bass management in an avr/pre and don't use the LFE channel at all?
post #24 of 39 Old 04-29-2015, 04:27 PM
Quoted: 451 Post(s)
Liked: 158
I dont use an AVR, And so no, I dont use any bass mgmt or a LFE channel.
My Room
My Music
Jenzen Next
post #25 of 39 Old 04-30-2015, 07:08 AM
Quoted: 1331 Post(s)
Liked: 819
Seems to be a bit of confusion here. There are several functions being blended into one: the LFE LPF, the crossover frequency, and bass management. However, they are actually separate functions.
The LFE channel is an independent channel containing up to 120Hz content, therefore the LPF should be at 120Hz, or LFE content will be missing. Then there's the crossover used in bass management, which would be the more room/speaker dependant function, as it controls how much LF material is crossed over from the mains to the sub. Then there's the small/large speaker size function, which determines if the crossover removes LF material from the mains and redirects it to the sub, or leaves it in the mains AND sub. That function is affected by the crossover frequency setting. The exception is if there's no sub, then the LFE gets distributed to the mains (usually).
Typical bass management crossover setting is 80Hz, but depends on the performance of the room and the mains, and would change the bass character and quality. Changing the LFE LPF usually has very little audible effect as most LFE content is below 80Hz, though technically there can be content up to 120Hz in that channel. It does not change what happens in the mains.
But really, the only correct setting for the LFE LPF is 120Hz.
jaddie is offline
post #26 of 39 Old 04-30-2015, 07:22 AM
kbarnes701's Avatar
Liked: 7046
In real life, there is very little content up to 120Hz in the LFE channel, according to professional film mixers. But yes, there could indeed be.
The issue is whether that content is so important that having it negates any 'issues' which may arise from using a LPF of LFE of 120Hz. I find, for example, that what seems to be in the LFE channel above 80hz is mostly "mush" (I have dual Seaton Submersives so my bass performance is very good and very revealing). By using an LPF of LFE of 80hz I seem to be able to eliminate the mush without having any negative impact on the real bass content.
It seems less than productive, to me, to follow a mantra (the only correct setting is 120Hz) if actual experience shows that better results are obtained by not following it. This is, of course, assuming one understands all the issues involved in any decision made.
I set my LPF of LFE at 80Hz years ago and have never felt any need to revisit it. Of course, YMMV.
post #27 of 39 Old 05-01-2015, 05:51 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 527
I use the same LPF as I would set to L/R ie if I were to use small 70hz for L/C/R, I use 70hz for subwoofer. LPF functions for all content- PCM- so for music it's too bloaty. Lexicon pre.
I don't like LPF to 120hz for movies either.
fatbottom is offline
post #28 of 39 Old 10-14-2015, 04:45 AM
irishluck73's Avatar
Quoted: 291 Post(s)
Liked: 195
That link is golden! Great info, thanks!
kbarnes701 likes this.
irishluck73 is offline
post #29 of 39 Old 10-14-2015, 07:15 AM
Bill Fitzmaurice's Avatar
Liked: 5778
+1. Also, with respect to LFE track material being directionally locatable, the LFE track is brickwall filtered at 120Hz, so regular program material harmonics that can be directionally locatable even with an 80Hz low pass of the other channels aren't present. If you have the ability to set the normal program low pass frequency and LFE channel low pass frequencies independently the difference that would probably be heard between 80 and 120Hz with the regular program probably would not be heard with the LFE track.
Bill Fitzmaurice is offline
post #30 of 39 Old 10-14-2015, 07:52 AM
kbarnes701's Avatar
Liked: 7046
Thanks Bill. With your permission, I will add that additional insight to the Audyssey FAQ answer which deals with this issue.
