REW output channels not displaying properly - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-09-2016, 01:09 PM - Thread Starter
turbonut's Avatar
Quoted: 47 Post(s)
Liked: 47
I've spent lots of time trying to figure out this problem, and have repeated every step in the guide about 5 times now. Regardless, I'm still having 2 showstopping problems with REW:
1. REW only shows 2 channels in the Output drop down. I've set up the proper surround (5.1) in the Sounds section, and am able to successfully play videos in full surround from my computer and get sound through all of the speakers.
2. If I try to do a sweep in REW on HD Audio Output 1, only my PC speaker plays..... no sound at all through the front left speaker.
Obviously I'm missing something here.... Can someone please point me in the right direction?
turbonut is offline
post #2 of 10 Old 01-10-2016, 09:15 AM
windshear's Avatar
Quoted: 82 Post(s)
Liked: 34
My system will do the same but only if my Receiver is in standby. As it then uses the passthough function in HDMI. Once switching on my receiver, if I don't close and restart REW it wont automatically update and reflect the proper channel configuration.
Classe CA2300 CA5300 CA2100
Classe CP800 "2.6". Marantz AV8805 "7.6.4"
B&W 2x800Di HTM1D 4xSCMS 4xCCM7.4
2x Dual Opposed DIY HST18's
2x Triangular DIY UM18-22's
windshear is offline
post #3 of 10 Old 01-11-2016, 04:36 AM - Thread Starter
turbonut's Avatar
Quoted: 47 Post(s)
Liked: 47
Ahhh okay thanks for the insight! My receiver is on when I've tried this, and the strange thing is when I play a youtube/Netflix/whatever video through my laptop I get full surround sound from the HT speakers.
It's just REW that won't play properly..... man I'm about to give up on this and just sell the UMIK-1. It's been very frustrating. I've seen countless people getting it to work properly, so it must either be inherent to my laptop or complete idiocy on my part (the latter being more likely lol).
turbonut is offline
post #4 of 10 Old 01-11-2016, 11:06 AM
Alan P's Avatar
Quoted: 7000 Post(s)
Liked: 6838
When you are playing the Youtube or Netflix videos, what surround mode is your AVR in?? My point is, your PC may only be outputting 2 channels but you have it matrixed to 5 in the AVR (Dolby PLII for example).
If your PC is indeed outputting 5.1, you should be able to put your AVR into MULTI-CH IN mode and hear sounds from all 5 speakers + sub.
This would be the first thing to test, then we can go from there.
Alan P is offline
post #5 of 10 Old 01-11-2016, 02:28 PM
krauley's Avatar
Quoted: 122 Post(s)
Liked: 122
turbonut, im going to try to help you because i was fighting the same problem you are. I got past it today so maybe i can help you. No matter what i tried, REW would not recognize my 7.1 hdmi port. I deleted both REW and ASIO4ALL and called it quits last night but today the bug was still biting so i tried again.
What i did was uninstall both programs, shut down my laptop and then hook up to the avr via hdmi. Started up the laptop and make sure that i was outputting at hdmi in 7.1 mode. checked using setting under playback devices and then ran a youtube video to test the speakers. Then i disabled the pc speaker in playback devices so the only thing showing was my hdmi port.
After doing that, i then installed REW and ASIO4ALL. Went into preferences and set it up as shown in all the posts i have read on it and low and behold, all 8 channels available for testing. now i just need to get a mic. I think the keys is to make sure to disable anything but the hdmi port under playback devices. Dont forget that if you use the laptop without having it hooked up to the receiver you will have to reenable the pc speakers under playback devices. I know now i can get my REW to the next step. Good luck and i hope this helps
krauley is offline
post #6 of 10 Old 01-14-2020, 12:24 PM
powerdubs's Avatar
Quoted: 254 Post(s)
Liked: 221
Having the same problem. Trying to find a resolution.....UGH.
powerdubs is offline
post #7 of 10 Old 01-19-2020, 05:40 AM
ellisda1's Avatar
Quoted: 94 Post(s)
Liked: 56
Try these options:
1) Try another HDMI port on your AVR. The front HDMI port on my Denon tends to fail (can be "reactivated" by system reset), and then you get the symptoms you describe.
2) Try another HDMI cable from PC to AVR.
I often have problems making my AVR the "active" output. Make sure it shows up when you launch ASIO4all
Denon AVR-X3400H, Chane A5.4 LR, Chane A2.4 center, Polk RC85i in-wall side-surround, NHT Super One rear surround, SVS PB-12 NSD, HSU-VFT-1, LG OLED 55B6A
ellisda1 is offline
post #8 of 10 Old 05-23-2020, 11:29 AM
pbc
pbc's Avatar
Quoted: 503 Post(s)
Liked: 223
Thought I'd try to use REW today after a few years of not having used it. Bought a UMIK-1, set up the calibration file, installed ASIO4All, and opened REW with the laptop (Dell Latitude 7400 2-1).
Selected Preferences, chose ASIO4All instead of Realtek ASIO (gave me some odd message warning me that it was using the same calibration file as the UMIK, just hit yes). Clicked on the control panel, enabled UMIK-1 (as per attached pic).
Restarted REW, but the "output" section of the parameters only shows "1. Not connected" and "2. Not Connected".
The laptop is displaying on my AVM60 through my display just fine. Any ideas? Is this the same issue you guys are referring to?
ID:	2731236   Click image for larger version
My DIY Subs ... https://www.avsforum.com/forum/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #9 of 10 Old 05-23-2020, 11:29 AM
pbc
pbc's Avatar
Quoted: 503 Post(s)
Liked: 223
If I click Measure, it just says "Signal Generator Audio Output not available"
Should I be selecting something in this menu?
pbc is offline
post #10 of 10 Old 05-24-2020, 04:10 PM
sirjaymz's Avatar
Quoted: 524 Post(s)
Liked: 647
Couple of things I would suggest for all of you, as I just went through this on a laptop.
First and foremost, make sure you are running the latest drivers for you Windows computer, especially you BIOS and your video driver, as the HDMI driver for that controls what REW is going to recognize, and how your computer see's you AVR. These 2 things absolutely are critical.
Second. Get the ASIO driver. I run my Dell E6430, and this works perfectly for it.
3rd, post some screen shots of your setup, and the forum here will be able to help you along ...
EDIT: One last thing, ... double check your Audio Drivers as well. Be helpful to make sure they are all updated.
HT1.0 | HT2.05 | Bass EQ for Filtered Movies
JVC RS-2000 / Seymour AV Center Stage 130"diag, 2.35 / nVidia Shield
11.2(22).6 Atmos / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD / DIY treatments
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
Klipsch RF-82II/RC-64II/RS-42II/RS-41II/RB-61II/CDT3800-C-II
sirjaymz is offline
