Anti-mode Dual Core 2.0 and Audyssey XT32 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-29-2016, 05:21 PM - Thread Starter
Quoted: 43 Post(s)
Liked: 6
Hi all,
I am wondering what the recommendations are for using the Anti-mode Dual Core 2.0 combined with Audyssey MultEQ XT32. I have a Marantz AV8802A in a 5.1 setup and using the Dual Core for the sub (PSA V3600i).
Should I:
(1) use Dual Core first then Audyssey?
(2) Audyssey first then Dual Core?
(3) Just use the Dual Core?
I remember reading something on this topic previously however I cannot for the life of me find the posts.
Any input appreciated.
timi2fly is offline
post #2 of 9 Old 06-29-2016, 07:32 PM
m. zillch's Avatar
Quoted: 4671 Post(s)
Liked: 3470
(1.)
Audyssey needs to see hear what delay times the electronic processing of the sub has applied before it can advise you on setting overall delays for all speakers when seen as a complete system.... I thought Audyssey explained this once at their "zendesk" FAQ pages but at the moment I can't find the reference. This is however how I remember it as being.
m. zillch is offline
post #3 of 9 Old 06-30-2016, 12:00 PM
Alan P's Avatar
Quoted: 6144 Post(s)
Liked: 5366
There are two schools of thought on the "EQ Before/After" Audyssey question:
1) EQ before Audyssey to provide Audyssey with the flattest possible response so it has less work to do
2) EQ after Audyssey to not only flatten the response, but to be able to tailor the response to your personal preference
I do not own a AM, but I don't think it allows you to create custom curves, or to modify the curve at all after running it ("tailoring" the response). If that is the case, I would recommend running the AM before Audyssey.
That being said, personally I would try it both ways and go with whichever sounds best to your ears.
Alan P is offline
post #4 of 9 Old 06-30-2016, 12:34 PM
m. zillch's Avatar
Liked: 3470
Originally Posted by m. zillch View Post
(1.)
Found it! Regarding Velodyne subwoofer room correction processing:
"We recommend that you first run the Velodyne process and then run MultEQ in the Marantz. "
"All non-Audyssey processing should be done prior to running Audyssey."
- Chris Kyriakakis, cofounder and I believe chief architect of all Audyssey processing, including all varieties of room correction such as MultEQ XT32.
Source: https://audyssey.zendesk.com/entries...ass-correction
post #5 of 9 Old 06-30-2016, 01:20 PM
lizrussspike's Avatar
Quoted: 1105 Post(s)
Liked: 1639
Cool Thanks for that info m. zilch.
lizrussspike is offline
post #6 of 9 Old 06-30-2016, 01:54 PM
Alan P's Avatar
Liked: 5366
Well, some of us respectfully disagree with Mr. Kyriakakis.
Alan P is offline
post #7 of 9 Old 06-30-2016, 03:07 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3015
Originally Posted by timi2fly View Post
Should I:
Get a USB measurement mic from MiniDSP. Use REW. Try (a) and try (b) and see which gives you the best measurements
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #8 of 9 Old 06-30-2016, 08:07 PM
Quoted: 20 Post(s)
Audassy xt32 by it self does a pretty good job.
I got a pretty good results by bypassing my Paradimg,s pbk kit.
Bbos37
B SUBASCHANDRA BOS is online now
post #9 of 9 Old 07-06-2016, 08:49 AM
FargateOne's Avatar
Quoted: 107 Post(s)
Liked: 29
Hi all,
Should I:
I owned AM 2.0 a couple of years ago with a Yam receiver. It worked very well. I let Anti mode do all the EQ for the sub and YPAO do the rest. You can changed the target curve in AM easily. Also, John M has added very recently EQ filters for Antimode in his marvelous REW software. With a Umik-1 mic and Rew you should do marvels with it. I would have kept mine if I knew that was coming !
My system 5.1 :ROTEL RSX-1562 /Fronts: B & W 804 D2; surround : B&W 704 and center B&W HTM4d2 /sub SVS PC 2000 / TV Samsung UN55ES8000
/BD player Cambridge CXU/ set-top (cable box) rented from cable co. PEQ by nanoAvr-DL Dirac Live between CXU and receiver
Bis Audio cables and power bar from the wall to the receiver
My room:15'4" x 11' 6" x 7'6" tv near the center of the long side wall
FargateOne is offline
