Connecting headphones to my jack-less TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-05-2017, 01:24 PM - Thread Starter
kihi.lind's Avatar
My LG 32LN5300 TV lacks a headphone jack, but I want to connect my headphones to it. It has a bunch of outputs on the back (see attached spec sheet for connection options), including optical connections. Any advice on how I can do that?
kihi.lind is offline
post #2 of 14 Old 01-05-2017, 01:51 PM
Ratman's Avatar
Quoted: 2159 Post(s)
Liked: 2008
Ratman is offline
post #3 of 14 Old 01-05-2017, 04:45 PM - Thread Starter
kihi.lind's Avatar
I honestly don't know :-) Would the headphones plug into the AUX jack?
post #4 of 14 Old 01-06-2017, 08:46 AM
Wayne A. Pflughaupt's Avatar
Quoted: 409 Post(s)
Liked: 332
The 3.5 mm jack on the left, but I doubt it will work well because there is no volume control. You’ll probably have to send the signal from the converter to a headphone amplifier.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #5 of 14 Old 01-06-2017, 09:40 AM
Ratman's Avatar
Liked: 2008
Perhaps providing the make/model number of the headphones being used would help.
Ratman is offline
post #6 of 14 Old 01-06-2017, 11:00 AM - Thread Starter
kihi.lind's Avatar
Sennheiser PXC 450: https://en-us.sennheiser.com/noise-c...travel-pxc-450
post #7 of 14 Old 01-06-2017, 12:21 PM
JohnFR's Avatar
Quoted: 17 Post(s)
Looks like you just need an adapter that accepts the headphone jack and splits it into the two red & while RCA plugs that you plug into the tv audio-out sockets on your set. You can find these at Radio Shack or an electronics store.
Like this:
https://www.walmart.com/ip/3.5mm-Fem...&wl13=&veh=sem
JohnFR is offline
post #8 of 14 Old 01-06-2017, 01:07 PM - Thread Starter
kihi.lind's Avatar
Like this:
That's what I thought as well, so I bought it, but it didn't work. I figure there must be another solution.
post #9 of 14 Old 01-06-2017, 06:14 PM
Quoted: 409 Post(s)
Liked: 332
It didn’t work because the adapter in question converts digital optical to an analog line-level signal. Typically that won't drive headphones.
Your “other solution” can be found in Post #4.
Wayne A. Pflughaupt
Equipment List
post #10 of 14 Old 01-07-2017, 08:17 AM
Ratman's Avatar
Liked: 2008
The headphones in question are "active" and have volume control.
Ratman is offline
post #11 of 14 Old 01-07-2017, 10:01 AM
Quoted: 409 Post(s)
Liked: 332
Isn’t the “active” part merely for the noise cancelling feature? I can’t see in the documentation that they also have built-in amplification. Until that can be confirmed, I’m sticking with my previous recommendation.
Wayne A. Pflughaupt
Equipment List
post #12 of 14 Old 01-07-2017, 10:46 AM
Ratman's Avatar
Liked: 2008
You may be correct. Why call it "volume control".
Line level outputs should provide some sound even with passive headphones, albeit low volume. Then your suggestion is quite right.
OTOH, perhaps there are some setup options in the TV that need to be adjusted in order for the optical to provide a signal (speakers off, PCM only, bitstream off).
Ratman is offline
post #13 of 14 Old 01-15-2017, 09:17 AM - Thread Starter
kihi.lind's Avatar
Smile
Problem fixed! I got one of these: https://www.amazon.com/gp/product/B0...ilpage_o05_s00. Thanks for everyone's help!
post #14 of 14 Old 01-15-2017, 09:33 AM
Ratman's Avatar
Liked: 2008
Hm-m-m... quite similar to the device suggested in post #2.
Glad it worked out and thanks for the update!
Ratman is offline
headphone jack , headphones , optical audio , optical output , television
