House wired with 12awg audio cable but system is 22 awg? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By DonH50
  • 1 Post By DonH50
  • 1 Post By CharlesJ
post #1 of 15 Old 06-19-2017, 09:57 AM - Thread Starter
Liked: 3
Hi all, I'm a total noob here requesting help. Our new house has 12 awg audio cable running in the walls and we want to connect our old Panasonic system which has 22 awg cables and 8mm connectors. Anyone can help? I need the connectors, and I'd like to know if going from 12 awg to 22 awg cable would work?
2JZGTE- is offline
post #2 of 15 Old 06-19-2017, 10:12 AM
Bill Fitzmaurice's Avatar
Liked: 5768
You can always use larger gauge wire. 22ga is marginal at best, so in that respect you're better off.
Bill Fitzmaurice is offline
post #3 of 15 Old 06-19-2017, 04:54 PM - Thread Starter
Liked: 3
Thanks. Do you know how I could fit that 12 gauge wire into a tiny 8.2mm connector that originally fits 22 gauge wire?
2JZGTE- is offline
post #4 of 15 Old 06-19-2017, 05:00 PM
DonH50's Avatar
Quoted: 3140 Post(s)
Liked: 3099
You could just carefully snip off strands until the 12 AWG fits. You could use banana plugs or pin plugs if they would fit. Or you can get wire nuts and splice in a couple of inches of 22 AWG wire to the end of the 12 AWG wire.
2JZGTE- and kfh227 like this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5 of 15 Old 06-19-2017, 05:29 PM - Thread Starter
Liked: 3
Sorry again I'm a total noob, but here's what I have now in the back of my receiver (click)
And I got 12 awg coming out of the wall. I need a female connector to put at the end of the wire to be able to connect it there... or any other way to connect. Banana plugs and pin plugs don't look like they would work?
Thanks for the info
2JZGTE- is offline
post #6 of 15 Old 06-19-2017, 07:01 PM
Liked: 5768
Originally Posted by DonH50 View Post
You could just carefully snip off strands until the 12 AWG fits. Or you can get wire nuts and splice in a couple of inches of 22 AWG wire to the end of the 12 AWG wire.
+1, whatever those are on your receiver they're not generic connectors, they're something proprietary to Panasonic.
post #7 of 15 Old 06-19-2017, 07:54 PM - Thread Starter
Liked: 3
So I could use the original wire/connector that came with the system and cut the (22 awg) wire a couple inches from the connector, and splice the 12 awg with the 22 awg with wire nuts. Does that make sense?
Another question : on the other end, where the 12 awg wire would go inside the speaker itself, the wire is (again) too big to fit in, so I could snip off a few strands? I'm not sure how that kind of signal works, but would I lose some sound quality, or since 12 is larger than 22 it's ok?
2JZGTE- is offline
post #8 of 15 Old 06-19-2017, 08:47 PM
DonH50's Avatar
Liked: 3099
Yes, just use the wire nuts. No, you won't lose any sound quality to speak of snipping strands at the other end.
2JZGTE- likes this.
DonH50 is offline
post #9 of 15 Old 06-20-2017, 07:31 PM
CharlesJ's Avatar
Quoted: 785 Post(s)
Liked: 533
So you have an HT system in a box with those connectors at both ends, receiver and speaker?
And, you want to speakers further than the 22ga will reach and want to use the in wall wires.
If you will splice the cable from the connector give yourself more than a couple of inches to work with, say cut 6" away and splice. Make sure you connect the two wires in phase, same color at each end with the connectors.
2JZGTE- likes this.
CharlesJ is offline
post #10 of 15 Old 06-20-2017, 08:03 PM - Thread Starter
Liked: 3
No I have a connector only at the end that connects to the receiver. The end that goes into the speaker is just the wire that you insert, no connector, hence the idea to snip off a few brands to make the 22ga fit into the speaker.
2JZGTE- is offline
post #11 of 15 Old 06-21-2017, 04:15 PM
CharlesJ's Avatar
Quoted: 785 Post(s)
Liked: 533
OK, have the picture.
But, instead of cutting wire strands, I'd use something like this:
https://www.parts-express.com/cat/sp...terminals/1891
CharlesJ is offline
post #12 of 15 Old 06-21-2017, 07:36 PM - Thread Starter
Liked: 3
Thanks, that's a great idea. So I just squeeze the wire into the female end, and the male end goes into the speaker? I'm guessing there's a way to stabilize/tighten the wire in the connector so that it doesn't fall off easily? Do you just use pliers?
2JZGTE- is offline
post #13 of 15 Old 06-22-2017, 06:02 AM
DonH50's Avatar
Liked: 3099
Those are what I called "pin plugs" in my first post. They come in various types, from solder to screw-on to using little set screws to hold the wire. Just follow the link @CharlesJ provided and read the various descriptions to see what would work best for you.
DonH50 is offline
post #14 of 15 Old 06-24-2017, 10:26 AM
ChromeJob's Avatar
Quoted: 1988 Post(s)
Liked: 1054
Your image didn't work for me.
I'd use connectors that you fit onto the 12awg wire permanently. Sewell sells sets on Amazon (banana plug, others), as an alternative to those sold by Parts Express and Monoprice.
Didn't notice anyone asking, how LONG are your speaker runs? A HTiB may not have sufficient power to go a long distance efficiently.
"Sell crazy some place else -- we're all stocked up here."
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is offline
post #15 of 15 Old 07-24-2017, 07:30 PM - Thread Starter
Liked: 3
Very sorry for the delay, I was away.
I have approx 30 feet of wire. What do you think?
2JZGTE- is offline
