Help! Subwoofer issues! - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 31 Old 08-11-2017, 05:43 AM - Thread Starter
Quoted: 32 Post(s)
Hello,
I've noticed over the past few weeks on odd sound that I thought was just my walls rattling. I decided to run a frequency test and found that around 45-25hz my subwoofer makes a disturbing fluttering sound. If you put your hand behind the port it feels like several high puffs of sound. It's not a pleasant sound at all and i'm not sure how to fix it. I'm using a Klipsch Reference 10" R-10SW with my Denon X2300W. I've noticed that even if I manually turn the gain down it still reproduces this sound, just at a lower volume. Is this normal? It doesn't happen often, but it does happen a lot during heavy bass/battle scenes and is pretty jarring. Wondering if there is anything I can do from the Denon end to fix it? Any advice is appreciated.
Lou
louballs is offline
post #2 of 31 Old 08-11-2017, 06:10 AM
Bill Fitzmaurice's Avatar
Liked: 5768
I'd say it's just from trying to get too much out of a single 10 inch sub.
Bill Fitzmaurice is offline
post #3 of 31 Old 08-11-2017, 06:24 AM - Thread Starter
Quoted: 32 Post(s)
How so? Even with the gain turned very low, it still produces this sound, so it's not like it's being overdriven. Are you suggesting that if I attached a second sub it wouldn't create the sound anymore?
louballs is offline
post #4 of 31 Old 08-11-2017, 07:32 AM
Liked: 5768
I surmised you don't have enough subbage when you said 'It doesn't happen often, but it does happen a lot during heavy bass/battle scenes and is pretty jarring.'
If it's something that's happening at low levels that points to something wrong mechanically inside the sub.
post #5 of 31 Old 08-11-2017, 08:04 AM - Thread Starter
Quoted: 32 Post(s)
Well, I guess I should have said it only happens at low frequencies. During my test it started happening around 40hz or so.
louballs is offline
post #6 of 31 Old 08-11-2017, 08:29 AM
Liked: 5768
The demands on sub woofer drivers and amps go up as frequency goes down, so it's low frequencies that will reveal if you don't have as much sub as you need.
post #7 of 31 Old 08-11-2017, 09:39 AM - Thread Starter
Quoted: 32 Post(s)
Would this be subwoofer "chuffing"? Is there any thing that can be done to reduce it? I may be running too hot, but not sure how to reduce that. I'm not well versed in this stuff.
popalock likes this.
louballs is offline
post #8 of 31 Old 08-11-2017, 10:01 AM
gajCA's Avatar
Quoted: 8559 Post(s)
Liked: 5759
I put some low density foam in the port plugs of my small subs in my secondary sub, so that might be worth a try.
Snoogleheimer likes this.
Geoff A. J., California
gajCA is offline
post #9 of 31 Old 08-11-2017, 11:49 AM
Liked: 5768
Chuffing is noise made by air vibrating in the port at high velocity. That velocity is based on the excursion of the driver cone. Excursion goes up as frequency goes down, especially below the tuning frequency of the cab, so not only is it annoying to hear, it also could mean the driver is in danger of mechanical damage from over-excursion.
Go to a larger sub or add another, both if you're into big bass.
post #10 of 31 Old 08-11-2017, 11:58 AM
torii's Avatar
Quoted: 3318 Post(s)
Liked: 1871
not all subs are created equal. and your sub just might not be capable of playing sounds below 40hz well.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #11 of 31 Old 08-11-2017, 12:17 PM - Thread Starter
Quoted: 32 Post(s)
Ok, and that may be the route I go, but in the mean time is there a way to reduce it? How can I reduce the strain on the sub? Even if I turn the gain down on the sub, I still get the sound, just quieter. I can't imagine that there is no way to reduce the strain, even if it means sacrificing some of the bass until I either upgrade or add another.
louballs is offline
post #12 of 31 Old 08-11-2017, 12:42 PM
torii's Avatar
Liked: 1871
does the sub have a crossover filter on it which will prevent it from playing anything too low? I know older subs in the 90's had options like that, but many of the new stuff probably dont maybe others can help.
torii is online now
post #13 of 31 Old 08-11-2017, 12:50 PM - Thread Starter
Quoted: 32 Post(s)
It doesn't, just an LPF knob.
louballs is offline
post #14 of 31 Old 08-11-2017, 01:20 PM - Thread Starter
Quoted: 32 Post(s)
Ok, so after doing some research, it seems it is a common problem with this sub. I'm going to have to upgrade. Probably to an svs pb1000 or pb2000. Not sure which yet. Frustrating as I can't take it back anymore, so I'm going to have to try to sell it locally as shipping will be a fortune on it.
louballs is offline
post #15 of 31 Old 08-11-2017, 02:17 PM
gajCA's Avatar
Liked: 5759
Your sub's spec is 32hz; all of these play deeper, even the least expensive one.
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
150watts 28hz $199 EMOTIVA BASX S8
200watts 27hz $299 EMOTIVA BASX S10
300watts 25hz $399 EMOTIVA BASX S12
250watts 22hz $423 HSU VTF 1 MK3
300watts 19hz $499 SVS PB1000
300watts 19hz $549 RHYTHMIK LV12R
350watts 18hz $604 HSU VTF2 MK5
SEALED SUBWOOFERS $600 AND BELOW, DELIVERED
300watts 24hz $499 SVS SB1000
300watts 18hz $539 RHYTHMIK L12
gajCA is offline
post #16 of 31 Old 08-11-2017, 02:33 PM
popalock's Avatar
Quoted: 1490 Post(s)
Liked: 2088
I mean, if you could somehow seal the port it would mitigate the port chuffing. Most likely wouldn't have to worry about mechanical damage to your driver, but thermal damage could still be a possibility. That said, since your sub is active, I'm not sure what kind of built in xover it has.
Would be nice if you had some way to measure your frequency response, just to see if there is any objective measurable benefit to sealing up your sub (besides loosing a ton of output at port tune...lol).
popalock is offline
post #17 of 31 Old 08-11-2017, 05:24 PM - Thread Starter
Quoted: 32 Post(s)
I was able to reduce some of the chuffing by reducing the output from the avr, down to -9db, and turning off dynamic eq, but I still don't like it. Upgrading seems inevitable as I guess the speaker just can't handle it. It's too bad but I'll have to deal with it for now.
louballs is offline
post #18 of 31 Old 08-11-2017, 05:50 PM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
If you wanted to keep your sub, your best solution would have been an outboard crossover like a miniDSP where you can manually set the crossover and eliminate the chuffing. As it stands, upgrading to at least two subs 12" or larger each will pay many dividends in the long-run. As far as your choice, I like the SVS that you have chosen but you need more than their PB line. Generally for home theater with today's soundtracks, you are looking at $1000+/each for something long-term. Keep in mind that SVS also has outlet sales on their website where you can save quite a bit on the right sub.
Jish9 is offline
post #19 of 31 Old 08-11-2017, 06:14 PM - Thread Starter
Quoted: 32 Post(s)
I'll keep an eye on the outlets. Unfortunately, I just don't have the funds to spend 2k on subs at this time. I wanted something decent and I'm happy with my setup for the most part (other than this issue). I would think that 2 of their higher end model would be overkill for my setup, but maybe overkill doesn't exist...
louballs is offline
post #20 of 31 Old 08-11-2017, 06:54 PM
Liked: 5768
It would also change the response of the cab, and not for the better, as the bottom octave would be lost.
post #21 of 31 Old 08-12-2017, 03:42 AM
popalock's Avatar
Liked: 2088
Agreed. That being said, sounds like his lowest octave is ***** right now with all of the chuffing.
I agree with your earlier comment Bill. The OP just needs more woofage if he isn't happy with his existing plight...
popalock is offline
post #22 of 31 Old 08-12-2017, 05:45 AM - Thread Starter
Quoted: 32 Post(s)
Seems that way. Now I wonder if I will be happy with an 800 dollar pb 2000 or do I really need to spend 2k+, which is not in my current budget as my wife will kill me.
louballs is offline
post #23 of 31 Old 08-12-2017, 06:27 AM
Liked: 5768
Price alone isn't an indicator of subwoofer performance. There are ID options in the $800 range that should do quite well for you.
post #24 of 31 Old 08-12-2017, 06:39 AM - Thread Starter
Quoted: 32 Post(s)
Is ID generally better performing that SVS for that price point?
louballs is offline
post #25 of 31 Old 08-12-2017, 09:47 AM
Liked: 5768
SVS is an ID (internet direct) source.
post #26 of 31 Old 08-12-2017, 12:40 PM
popalock's Avatar
Liked: 2088
Careful with a statement like that. I thought I would be happy with 16 18's, but found I still wanted more.
Do you have facilities / means to build your own? Would the wifey mind if you had a larger box than what your Klipsch currently is? You could get some pretty CRAZY performance for well under $2K!
2 Martys and a iNuke would ruin your life... Just destroy reality as you currently know it...
I'll leave it at that for now, but if you can DIY, it opens up:
popalock is offline
post #27 of 31 Old 08-12-2017, 12:42 PM
popalock's Avatar
Liked: 2088
Spend sometime on this site.
http://www.data-bass.com/systems
If you have heard any of those subs, use your experience as a point of reference, so you can draw your own conclusions...
popalock is offline
post #28 of 31 Old 08-12-2017, 03:19 PM - Thread Starter
Quoted: 32 Post(s)
Unfortunately, I haven't really heard much at all other than what you see in big box stores, so my point of reference is pretty minimal. I do have the capacity to do a DIY, but never have before. I'm pretty handy and good with wiring/soldering. Where do I begin with something like that? I'd love to do a project like that. Though I fear if I build an awesome sub it will make the rest of my speakers sound subpar lol.
popalock and 18Hurts like this.
louballs is offline
post #29 of 31 Old 08-12-2017, 04:37 PM
popalock's Avatar
Liked: 2088
Common misconception...With the right tools (DSP) you can easily tune your subs to integrate seamlessly with whatever mains you may have.
Seriously, if tuned properly you literally cannot have too much wooferdom...lol.
Here is where you start:
https://www.avsforum.com/forum/155-di...tysub-faq.html
BTW. By quick calculation, one full Marty will out perform a Klipsch SW-311 by about 24db at 20Hz....
Klipsch SW-311 = 84db @20hz
Full Marty w/SIHT18 =108db @20hz
Meaning it would take about 16 of the SW-311's to provide similar output as one of the Marty subs @20hz ...
Enjoy your joruney.
popalock is offline
post #30 of 31 Old 08-13-2017, 06:36 AM - Thread Starter
Quoted: 32 Post(s)
Enjoy your joruney.
Thanks for your help!
louballs is offline
