Speakers Small with Crossover vs Speakers Large with LFE+Main/Extra Bass/Double Bass - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 2 Post By sivadselim
  • 3 Post By sivadselim
  • 1 Post By mthomas47
post #1 of 8 Old 05-30-2018, 03:12 PM - Thread Starter
Liked: 0
We all know the coveted HT rule: Set your speakers as small/limited range with a 80-100Hz crossover, even if you have tower speakers, spare your amp and speakers the extra work, and let your sub take care of the lows.
Here's my thing...what do you tell the person who's a "purist" and only runs 2.0 audio? That he HAS to get a subwoofer? Likewise, what do you tell someone who has a stereo amp with a sub pre-out? No stereo amps, if not very few, have an internal crossover for the mains. Do you tell him he HAS to get an AVR so he can set a crossover for his mains?
I do agree that most times deciding not to run your mains full-range is best. But honestly, for those who don't have the space or money to have a second subwoofer, that may be the best way, the ONLY way, to get even bass distribution.
When are these rules applicable? Music, games, movies, all of the above? Or are we just blindly following rules?
Last but not least, isn't .1 discreet info ONLY sent to the sub in 5.1 content? Is it correct to say LFE+Main or not, your mains are never going to get that content when you're using the LFE line out connection?
cstutts1808 is offline
post #2 of 8 Old 05-31-2018, 11:34 AM
ChromeJob's Avatar
Quoted: 2089 Post(s)
Liked: 1095
You tell him nothing. A purist surely knows what he’s doing, or think he/she does.
This has been discussed thoroughly on the forums, not sure what your “new” question might be.
“Extra bass” settings are for doofuses, certainly not someone who understands how ULF works.
"Exceedingly odd," said the butler.
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is online now
post #3 of 8 Old 05-31-2018, 12:21 PM
sivadselim's Avatar
Quoted: 443 Post(s)
Liked: 390
Correct. The LFE channel is still not sent to the fronts when the double bass (LFE+Main) setting is used. LFE always goes to the sub out unless the AVR is configured as having NO SUB. The double bass (LFE+Main) setting duplicates the front channel bass (below a certain low-pass) at the sub.
A better way to look at the double bass (LFE+Main) setting, IMO, is that (essentially; see below) the same exact thing is sent to the sub as would be were the speakers set to SMALL. The only difference is in what is sent to the front speakers. They still get a full-range signal.
Now, depending upon the AVR, the low-pass on the front channel bass that is duplicated at the sub with that setting can vary. I believe that nowadays, with most AVRs, the front channel crossover setting is still available when the double bass (LFE+Main) setting is used and that setting dictates the low-pass that is used to determine what front channel bass is sent to the sub (just as it would be were the speakers set to SMALL). On some AVRs that low-pass may be fixed at something like 80Hz with the front channel crossover setting no longer being available.
Madmax67 and mthomas47 like this.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #4 of 8 Old 05-31-2018, 12:24 PM
holl_ands's Avatar
Quoted: 957 Post(s)
Liked: 527
A STEREO Purist would only have TWO Speakers...with LARGE Woofers [i.e. 12-15+ in] that do the WORK of TWO separate Sub-Woofers....and would only listen to Discrete or Down-Mixed Stereo. Which I gave up doing a couple Decades ago....when I repurposed my Large, Antique 15-in Altec Voice Of The Theater Speakers as my two Sub-Woofers (for better Transient Response I changed from Bass Reflex to Sealed Box....with 1/3-Octave Band Equalizer for flatter Room Response).
But back to your Original Question: If you listen to a signal recorded in SURROUND that is Down-Mixed in an AVR to STEREO, it usually will NOT include the Down-Mixed Sub-Woofer Track....so your SW Channel is silent and the STEREO Low Freqs sound quite thin.
Which is where LFE+MAIN aka EXTRA BASS aka DOUBLE BASS selection in AVR can TRY to come to the rescue, redirecting SW Channel into the L/R Channels....where the STEREO may STILL sound quite thin if they CAN'T reproduce Lowest Freqs without audible Distortion. Unfortunately, you might want to remember to turn it OFF if you decide you want to listen to a Surround Track, including the SW Channel....cuz the (perhaps wimpy, wimpy) L/R Speakers will STILL try to pump out Distorted Low Freqs.
And as always....IT'S YOUR CHOICE....whether you want to enable the BASS Redirection to L/R....and also if you want to spend $$$'s on a pair of Large L/R Speakers rather than one (or two) Sub-Woofers.....
holl_ands is offline
post #5 of 8 Old 05-31-2018, 01:03 PM
sivadselim's Avatar
Quoted: 443 Post(s)
Liked: 390
Incorrect. Almost all (if not all) AVRs are capable of redirecting the LFE channel to the front channels if configured as having NO SUB connected.
DVD and Blu-Ray players often DO drop the LFE channel altogether from a 2-channel downmix. But not AVRs.
This is incorrect, too. That is not how the double bass (LFE+Main, Plus, LFE+, etc.) setting works. As I stated in my post above, the SW channel (the LFE channel would be the correct way to say it) is NOT redirected into the L/R channels with the double bass (LFE+Main, Plus, LFE+, etc.) setting. The only way to get an AVR to send the LFE channel to the front channels is to configure the AVR as having NO SUB connected.
Madmax67, ChromeJob and deafenears like this.
post #6 of 8 Old 05-31-2018, 04:41 PM
RayGuy's Avatar
Quoted: 2859 Post(s)
Liked: 2631
So, what's the point of this thread? Are you a "purist" wanna-be, or just making light of that market segment? Why would you even care what others think? Just set it up in whatever configuration is best for your system, room, and taste. If you are not sure, then try out all the options and keep your favorite. What others do with their systems is completely irrelevant, and their personal decision, as it is yours.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #7 of 8 Old 06-01-2018, 01:44 PM
holl_ands's Avatar
Quoted: 957 Post(s)
Liked: 527
SORRY.....I remembered it back-***-wards....
When Selecting DOUBLE-BASS (Onkyo), SW-PLUS (Pioneer, aka PLUS), EXTRA-BASS (Yamaha) or LFE+MAIN (Denon/Marantz), Bass Freqs from L/C/R are ALSO output via SW, see my earlier more detailed post...and subsequent supplemental posts:
https://www.avsforum.com/forum/89-spe...l#post55258498
So this ensures that SW contributes to reproduction when JUST playing a 2-Channel STEREO program....but in and of itself, does NOT Re-Direct Low Freqs AWAY from L/C/R in order to reduce Low Freq Distortion from those speakers....for that you need to set speakers to "Small" and let Bass Re-Direction do it's job. PS: Off-hand, I don't remember how BOTH features interact, incl. Room Equalization....some experimentation may be required...and may be different in different AVRs...
A 2-Channel STEREO program does NOT have any signals on the SW Channel and will sound "thin" compared to Surround Programs if "Large" is set for L/C/R, since the SW is silent [no Bass Re-Direction]. When the LFE+MAIN (et.al.) function is enabled, STEREO program material finally comes ALIVE.
BTW: As I recall, I THINK that some of my Pioneer Synthetic Surround Modes MIGHT also activate the SW when playing back STEREO programs....but I'm unsure, so do your own investigation.....
post #8 of 8 Old 06-01-2018, 01:52 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5490 Post(s)
Liked: 10483
Hi,
I think that it is perfectly fine to listen to music, or anything else, without subwoofers--if that's what someone wants to do. But, in my opinion, it is important to be well-informed about the basic principles of bass-management. You have already gotten some good explanations. If you want more detail, you can find it in the direct link to an article on the subject here:
https://www.avsforum.com/forum/113-su...erences.html#D
Mike
ChromeJob likes this.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
crossover , large , lfe , small , speakers
