Is this possible: Speaker Wiring - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bigguyca
post #1 of 4 Old 09-28-2018, 05:10 PM - Thread Starter
Quoted: 67 Post(s)
Liked: 4
So please forgive me if this is the dumbest question ever asked here, but here we go:
Theoretically, let's say that I'm having a very hard time deciding on speakers and if some will be towers, some bookshelves, and if the latter, if they'll be wall mounted or on a stand. Let's also say that time frame for drywall going up is quick and I don't want that to rush me into a decision.
So, would it be possible, using 4 conductor speaker wire, to use 2 of the conductors that would terminate to a wall plate for wall mounting and then the other two conductors to terminate near the floor in case of tower usage? Effectively have the 4 conductor wire act as its own splitter without having to mess with anything on series/paraell? Only one "placement" would be run at a time.
If this is possible, is it advisable? Any potential downsides?
Thanks, and be gentle!
matpal is offline
post #2 of 4 Old 09-28-2018, 10:10 PM
m. zillch's Avatar
Quoted: 5741 Post(s)
Liked: 4091
Yes.
m. zillch is offline
post #3 of 4 Old 09-30-2018, 07:58 AM
Selden Ball's Avatar
Quoted: 4815 Post(s)
Liked: 2852
It's probably too late, but (if at all possible) you should consider running single-pair speaker wires wherever you think you might want to have speakers in the future. Modern 3D surround-sound speaker systems can have as many as 9 ear-level speakers, 6 overhead speakers and several subwoofers.
Selden
Selden Ball is offline
post #4 of 4 Old 10-01-2018, 08:41 AM
bigguyca's Avatar
Quoted: 1238 Post(s)
Liked: 1046
Wires are nice, but if you still have access to the wall spaces then running conduit, in this case plastic pipe from a central location in say in the attic or some other assessable location, to locations where you may want something in the future; a TV, an Ethernet drop, speakers, whatever, will give you ultimate flexibility. Just cover the conduit outlets with plastic wall plates. Plans and usage scenarios change, conduit provides a lot optionality going forward.
18Hurts likes this.
bigguyca is offline
