REW ASIO NVIDIA issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-02-2018, 09:10 PM - Thread Starter
soccerTOOLsu's Avatar
I have a clean install of REW (V5.20 Beta 1), ASIO4ALL (V2.14), NVIDIA driver (391.35 for GeForce GTX 550 Ti).
REW with ASIO drivers does not show the NVIDIA Audio drivers in the WDM Device list. This prevents me from picking any playback device to run REW on my HTPC. On the JAVA soundcard, the DENONAVR shows up as the playback source. This allows for a Channel L and/or R test to be performed.
Anyone know how to get REW + ASIO to read NVIDIA HD Audio in the WDM Device List section of preferences so that I can run a 5.1 system scan.
I think this might be an NVIDIA + ASIO issue. Rolled back ASIO install once and rolled back NVIDIA drivers several times and no such luck.
soccerTOOLsu is offline
post #2 of 4 Old 07-14-2019, 12:38 PM
squish72's Avatar
sorry to bump an old thread but i have the same issue. Anyone know of a fix? tried flexasio and couldnt get it figured out to work
squish72 is offline
post #3 of 4 Old 07-22-2019, 03:54 AM
Skinfax1's Avatar
Quoted: 286 Post(s)
Liked: 90
https://www.avsforum.com/forum/91-au...l#post58321916
Good sound is always the result of engineering. And engineering always starts with measuring. Consumer industry and mainstream will never tell customers about that: improvements in room acoustics are worth roughly ten (10!) times the amount spent on equipment like speakers and receivers. For example: only $500 in room treatment is worth more than spending $5000 (fivethousand) on equipment.
Skinfax1 is offline
post #4 of 4 Old 07-22-2019, 04:54 AM
squish72's Avatar
Thank you so much!
squish72 is offline
