subwoofer gain issue - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Ratman
  • 1 Post By DonH50
post #1 of 7 Old 02-15-2019, 03:59 AM - Thread Starter
Quoted: 24 Post(s)
Exclamation subwoofer gain issue
I have a denon avr x-1400H
and 2 subwoofers: 1 infinty beta sw 12 and 1 tannoy s-sub 15.
When i disconnect 1 subwoofer the otherone gets significantly louder... how do I fix this?
Because i want full power from both subs and not half power from both of them.
I connected them with rca's. The sw 12 to sub 1 and the tannoy to sub 2.
any help would be highly appreciated
Last edited by i-live-4-bass; 02-15-2019 at 04:02 AM. Reason: grammar errors and typo's...
i-live-4-bass is offline
post #2 of 7 Old 02-15-2019, 04:02 AM
markmon1's Avatar
Quoted: 4801 Post(s)
Liked: 3078
Originally Posted by i-live-4-bass View Post
i have a denon avr x-1400H
and 2 subwoofer: 1 infinty beta sw 12 and 1 tannoy s-sub 15.
when i disconnect 1 subwoofer the otherone gets significantly louder... how do I fix this?
because i want full power from both subs and not half power from both of them.
i connected them with rca's. the sw 12 to sub 1 and the tannoy to sub 2.
You could run the output from the receiver through a cleanbox pro.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 7 Old 02-15-2019, 06:48 AM
ChromeJob's Avatar
Quoted: 2008 Post(s)
Liked: 1068
If the subs are fed from line-level sub PRE OUTS, you’re not getting “half power,” it’s just that the input signal is quieter. Your Denon should allow you to simply up the gain from the AVR. Or increase the gain on the subs.
(after Ratman)
If there's one single volume adjustment on the AVR for the SUB OUTs, it's probably an internal Y-splitter, and meant to operate this way. Just adjust the subwoofers' gain to get volume matching to your liking.
"Sell crazy some place else -- we're all stocked up here."
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is offline
post #4 of 7 Old 02-15-2019, 08:15 AM
Ratman's Avatar
Quoted: 2242 Post(s)
Liked: 2106
Just for everyone's edification, I believe the Denon has two "sub-outs". They can be volume controlled in setup... but not independently/individually.
I could be incorrect... just took a quick look at the manual.
ChromeJob likes this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #5 of 7 Old 02-15-2019, 11:41 AM
DonH50's Avatar
Quoted: 3179 Post(s)
Liked: 3179
It's also possible there is some cancellation going in when both are operating that goes away with one... This cancellation may be to better flatten the response by bringing down a peak so is not necessarily bad.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #6 of 7 Old 02-16-2019, 11:08 AM
MTVhike's Avatar
Location: North Shore of central Long Island, NY (Stony Brook)
Quoted: 196 Post(s)
Liked: 42
What's the input impedance on each of the subs? If one has a lower impedance, then connecting it will reduce the output on the other. However, I thought all (most?) subs were driven by line-level signals which shouldn't be significantly affected by a line level input. Another thought, is one sub designed for speaker-level inputs?
MTVhike is online now
post #7 of 7 Old 02-23-2019, 02:21 PM
jcmccorm's Avatar
Quoted: 602 Post(s)
Liked: 449
I agree that this needs checking. Check phase of the subs and distance settings for the sub outputs. I think that it's more likely that some cancellation is going on.
jcmccorm is offline
