Tivo and Yamaha RX-V383 no 5.1 Surround - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-13-2019, 11:43 AM - Thread Starter
bobheck's Avatar
Post Tivo and Yamaha RX-V383 no 5.1 Surround
No matter what I do I cannot get surround sound from the Tivo Bolt.
I have read through many forums and I cannot find an answer.
Here are the details:
I have a Tivo Bolt and a Yamaha RX-V383 receiver.
1. Have tried both HDMI and Optical outs on the Tivo Bolt.
2. Tivo output mode is set to Dolby.
3. "Signal Info" on RX-V383 receiver shows DD, 3/2/0.1, so it is getting a digital surround signal.
4. Ran several surround tests, all sounds from front speakers. Even when surround test shows rear speakers should be sounding, sound comes from front speakers.
5. Running the Tone Test from Yamaha menu, sound comes from each speaker as expected, including the rear speakers, no problem. So the rear speakers are connected and working. I have to assume this is a decoding or signal problem.
6. I have connected my Samsung TV optical audio out directly to Yamaha using same Optical cord that I use on the Tivo and 5.1 sound goes through just fine using Antenna or any of the TV apps, no problem. So I know the Yamaha and speakers are set up correctly.
7. Updated Yamaha firmware to 1.08. Did not help.
8. I have rebooted both boxes. Did not help.
Any suggestions or advice is greatly appreciated
bobheck is offline
post #2 of 4 Old 04-13-2019, 12:05 PM
Quoted: 498 Post(s)
Liked: 253
I dont know much about newer yamahas but what sound mode do you use?
Have you tried several different programs/channels?
Leeliemix is online now
post #3 of 4 Old 04-15-2019, 11:20 AM
Quoted: 149 Post(s)
TiVo still exists? Thought it was just called a dvr now
Totemtimer is offline
post #4 of 4 Old 04-15-2019, 12:13 PM
Ratman's Avatar
Quoted: 2543 Post(s)
Liked: 2354
Kleenex still exists? I thought it was just called tissue now.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
5.1 , surround , theatre , tivo bolt , yamaha rx-v383
