How much difference does banana plug quality do? - AVS Forum | Home Theater Discussions And Reviews
 42Likes
post #1 of 44 Old 04-19-2019, 07:57 AM - Thread Starter
Liked: 0
Hello!
I bought 5m of QED Reference xt40 and QED Airlock bananaplugs 4mm but the website I bought em from didn’t tell me that I needed a special tool to fit my cables in the QED airlock. I am now stuck with my old banana plugs which I bought from a local electronics store which I assume isn’t of very good quality. SO I am wondering, am I bottlenecking the crap out of my speaker cables by using a, I assume, bad set of banana plugs.
Thank you for reading.
Mat-tias is offline
post #2 of 44 Old 04-19-2019, 08:12 AM
mattztt's Avatar
Quoted: 356 Post(s)
Liked: 356
Assuming a good interface between the wire and the plug and between the plug and the jack you shouldn't be able to hear any difference.
m. zillch and sigpig like this.
mattztt is offline
post #3 of 44 Old 04-19-2019, 08:28 AM - Thread Starter
Liked: 0
Alright, awesome. Yeah they’re in a good spot! Thank you for the reply.
Mat-tias is offline
post #4 of 44 Old 04-19-2019, 09:00 AM
Glimmie's Avatar
Quoted: 1074 Post(s)
Liked: 988
Yep, purely mechanical. If they fit firmly and aren't corroded, they'll work as good as any. Audiophile grade plugs may look nice but they offer no sonic benefits over good commodity grade plugs.
Glimmie is offline
post #5 of 44 Old 04-19-2019, 02:57 PM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1494
If your paying much more than $10 for 5 pair ... well your paying too much!
I’ve used these in 10 pair of speakers ... zero issues
Plus I held a audio gtg 4/13, they worked fine for that event to help swapping
smcmillan2, fill35U and Archaea like this.
mtbdudex is offline
post #6 of 44 Old 04-20-2019, 09:42 AM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
Originally Posted by Mat-tias View Post
Hello!
I've found there is a difference, which is mostly manifested in the high frequencies. The better or higher quality the banana plug adapter, the smoother and less harsh the highs (I've found at least). I was using monoprice and found the highs overly emphasized and fatiguing. Moved to RadioShack brand, which are more expensive and which seemed to be of higher quality material (don't know the differences, but they were heavier and seemed better made). I also have some spade to banana adapters of decent quality from Apollo AV, but upgraded to Vampire brand and the highs were smoother and less emphasized at the same volume setting. Better overall listening experience. For me, it was worth it, but the only way to tell is to try different ones. And more expensive might not mean better or more preferable.
The monoprice ones were dirt cheap. The RadioShack were like $7-8 per single pair (and no longer made or available to buy). The Apollo AV ones were like $11 per single pair, and the Vampire ones were $22 per single pair.
However, all this being said the ones you have may be perfectly fine, and even concerning any potential audible differences, none would be describable as bottlenecking anything.
RWetmore is offline
post #7 of 44 Old 04-20-2019, 09:48 AM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
I should point out the Monoprice ones I was using were like from 10+ years ago, so the ones now are likely different and may be better.
RWetmore is offline
post #8 of 44 Old 04-20-2019, 11:47 AM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1494
As long as they fit snug, and grip the wire good, that’s it.
Don’t overthink any more than that.
mtbdudex is offline
post #9 of 44 Old 04-20-2019, 11:51 AM
Quoted: 56 Post(s)
Liked: 106
Yeah, no, I don't think so.
sigpig, mattztt, BGLeduc and 6 others like this.
Graustark is offline
post #10 of 44 Old 04-20-2019, 12:32 PM
m. zillch's Avatar
Quoted: 4852 Post(s)
Liked: 3606
Bananas can sound fine but it is important to give them a slight twist as you insert them: rotating 90 degrees clockwise if you live in in the Northern hemisphere and 90 degrees counter-clockwise if you live in the Southern hemisphere. [This is because people in the Southern hemisphere are essentially upside down, they just don't realize it. ]
I'm of course assuming the polarity of your music is not inverted.
m. zillch is offline
post #11 of 44 Old 04-23-2019, 01:09 PM
Glimmie's Avatar
Liked: 988
Well if the old plugs had corrosion, there could be diode effects that could cause HF distortion.
But beyond that I see no reason for any differences heard.
Glimmie is offline
post #12 of 44 Old 04-23-2019, 01:17 PM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
There was no corrosion.
RWetmore is offline
post #13 of 44 Old 04-23-2019, 01:17 PM
m. zillch's Avatar
Liked: 3606
Monoprice makes at least two very distinctly different ones and the more affordable one has a nasty habit of guillotining a good percentage the wire strands so you end up having a rotten connection [and it is completely hidden from view so you don't realize it] .
post #14 of 44 Old 04-23-2019, 01:34 PM
Marc Alexander's Avatar
Quoted: 5336 Post(s)
Liked: 4836
I'm not a big fan of the Monoprice plugs pictured. Had issues with both the set screws and the plug itself loosening over time at my dad's and a neighbor's places. I avoid them.
Many connectors are made by the same OEM. Nakamichi was the first name brand I remember when I first saw BFA plugs (my favorite type). Whoever makes the Nakamichis also makes GLS Audio, Sewell, Mediabridge, etc. I have bought GLS via Amazon in a pinch when I needed quick delivery. I find it easiest to browse connector types as well as order from here:
http://www.nakamichiplugs.com/
Marc Alexander is offline
post #15 of 44 Old 04-23-2019, 03:51 PM
Glimmie's Avatar
Liked: 988
Well it could have been poor plating under the surface you can't see. If the connector did what you stated, there's a scientific reason why. And upon examination it would be revealed.
There is no magic in electronics. Just science and physics.
Glimmie is offline
post #16 of 44 Old 04-23-2019, 05:14 PM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
Well yes, of course. I don't know the reason. Only what I heard.
Many would disagree, but I suggest everyone not skimp on the quality of the bananas and splurge for some really high quality ones, like these from Vampire (but heavily discounted somewhere, which they often are):
https://www.vampirewire.com/product-page/gb
I have the SBs and use them for a spade to banana adapter in my two systems. They just scream super high quality and craftsmanship (especially the quality of the gold plating, but everything really), and I heard virtually immediately smoother, less harsh and a little less emphasized highs with them at the same volume level. Heard no difference in the mid or low frequencies compared to the previous Apollo AV ones, which seemed fairly good quality themselves.
Just my opinion and experience.
RWetmore is offline
post #17 of 44 Old 04-24-2019, 10:51 AM
Glimmie's Avatar
Liked: 988
Don't be fooled by shiny gold plating, or more accurately gold flashing which can be rubbed off with your finger! A lot of so called audiophile connectors especially from Amazon and Ebay are actually cheap off shore junk. Yes they look good and sturdy but there is no traceable specifications.
Banana plugs have been around since the 1930s. There are established vendors that have made these parts for over 80 years. And some of these established vendors do make audio specific products that will accept heavy speaker wire. Buy those and you won't go wrong.
Glimmie is offline
post #18 of 44 Old 04-26-2019, 07:42 AM
DonoMan's Avatar
Quoted: 238 Post(s)
Liked: 191
What you heard and what your brain thinks you heard aren't the same thing. You have to do a scientifically valid test that accounts for psychoacoustics or your results don't mean a thing. You cannot overcome the placebo effect with willpower. You have to overcome it with testing methodology. Now, I don't mean to pick on you specifically. This is true for all of us. The human brain is not as precise with details as many people think. It only takes a matter of seconds to forget a lot of the details about what you hear or see.
m. zillch and Archaea like this.
DonoMan is offline
post #19 of 44 Old 04-26-2019, 09:12 AM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
No, one would have to perform scientifically valid test to establish at a scientific level that a difference is heard. This is an absurd and impractical standard, especially the individual level, and because ultimately the hi-fi listening experience is a subjective experience. I'm not into this hobby to prove at the scientific level what I hear, nor do I have the time or money to conduct such a test. And it's absurd to think everyone should be doing such testing in order accept/validate any differences they hear. It's laughably absurd, IMO.
RWetmore is offline
post #20 of 44 Old 04-26-2019, 09:19 AM
DonoMan's Avatar
Quoted: 238 Post(s)
Liked: 191
You like what you like, but here you are on a forum advising other people about products. What you like for yourself and what you tell other people aren't the same thing. It's irresponsible to give purchasing advice that does not correspond to reality. Yes, people could just ignore your advice when they decide what to buy (and in this case that is what people should do). The burden of proof that people should buy more expensive products does lie with those who claim they are better. You don't have to prove anything, you don't have to use the same products that I or other people do... and you also don't have to tell people that $20 banana plugs sound better than $2 banana plugs. You're welcome to your opinion, though, and so are the rest of us. Now, if your opinion is that you think science is not capable of describing audio properly, that is what I would call a laughably absurd argument.
dTorC4, sigpig, Archaea and 1 others like this.
DonoMan is offline
post #21 of 44 Old 04-26-2019, 09:31 AM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
Yes.
Yes they are.
That's your opinion.
No it doesn't. I've given my reasons why. You are not obligated to agree with them or believe them.
Of course I don't have to, but I did because it was my experience.
Again of course.
RWetmore is offline
post #22 of 44 Old 04-26-2019, 11:19 AM
m. zillch's Avatar
Liked: 3606
If I heard a difference between different brands of banana plugs I would be confident it was just my imagination. [Further testing under controlled conditions of course would be in order.]
DonoMan and sigpig like this.
post #23 of 44 Old 04-26-2019, 11:32 AM
Ratman's Avatar
Quoted: 2237 Post(s)
Liked: 2100
If you use bare wire, you don't have to worry about the qualities or deficiencies of banana plugs.
sigpig likes this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #24 of 44 Old 04-26-2019, 11:34 AM
m. zillch's Avatar
Liked: 3606
NAKED wire?! Please, this is a family friendly web site.
post #25 of 44 Old 04-26-2019, 11:35 AM
torii's Avatar
Quoted: 3420 Post(s)
Liked: 1902
i have banana plugs that have gotten loose over time and a few were a spline? broke...this more quality issue than sound imo.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #26 of 44 Old 04-26-2019, 12:59 PM
CruelInventions's Avatar
Quoted: 1209 Post(s)
Liked: 1418
Appreciate you, "fightin' the good fight" and all, but RWetmore is one of those long-time members who's withstood all manner of quality oppositional argument from several members over many years with respect to these types of topics. He's impervious to them all as he places MUCH higher value upon his own subjective impressions and holds them sacrosanct. As such, there will never be any counter-argument that will be compelling enough to even give him a second's pause.
tl;dr: Save your breath, he's impervious.
fill35U, CharlesJ and DonoMan like this.
The first principle is that you must not fool yourself and you are the easiest person to fool. ~ Richard P. Feynman
CruelInventions is offline
post #27 of 44 Old 04-26-2019, 02:16 PM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
I'm not impervious. If I actually participated in a blind test and couldn't distinguish something I thought I was hearing, I would of course question whether or not I was actually hearing it. Any rational person would.
My point is it is absolutely absurd and impractical, especially at the individual level in an ultimately subjective hobby like this, to think that one should go through the trouble and expense to conduct such testing for everything he or she is hearing in order to prove (at the scientific level) that he or she really hearing it. It's also absurd to think that no one can offer such listening experiences as advice to other unless they've done so.
Moreover, I'm not suggesting anyone spend major bucks on bananas because they will sound 'better'. I even said they may not sound any better, and the ones the OP has may be just fine. I recommended bananas from Vampire that can be had for $10 per pair, which is hardly a lot of money. Yes, ones can be had for a less, but jeez -- I'm hardly advocating anything unreasonable here. IMO at least.
RWetmore is offline
post #28 of 44 Old 04-26-2019, 02:25 PM
m. zillch's Avatar
Liked: 3606
People have every right to make posts based on their sighted listening tests just like others have every right to question if sighted testing is flawed.
fill35U likes this.
post #29 of 44 Old 04-26-2019, 02:27 PM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
Moreover still, even if I claimed I performed such testing and was able to hear a difference, you most likely wouldn't believe it anyway, right? Which just further illustrates the absurdity and impracticalness of all of this. You and anyone else is of course free to not believe my or anyone else's reported listening experiences unless you see 2nd party verified double blind testing of each individual's various claims, but again I think this is absurd. But that's your business and you're entitled to that opinion or view point.
Had DonoMan simply stated this I wouldn't have even bothered to respond, as I have no problem with it.
RWetmore is offline
post #30 of 44 Old 04-26-2019, 02:31 PM
RWetmore's Avatar
Quoted: 625 Post(s)
Liked: 388
Yes, of course. And yes, sighted testing doesn't eliminate potential listener bias and doesn't establish and prove at the scientific level that someone has actually heard and/or audibly perceived something. I'm not disputing this and never have.
RWetmore is offline
