Speaker Setup Help - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By gajCA
  • 1 Post By gajCA
post #1 of 11 Old 04-26-2019, 08:30 PM - Thread Starter
Liked: 0
Speaker Setup Help
Not sure if this is the correct area to post, please let me know if it is not and I will move it to the right area.
I have a small room I am trying to convert into a small home theater room. I was wondering what is the best speaker setup I can have? I would like to have Atmos but not sure if 5.1.4 or even 7.1.4 is even possible in this room. Anyone have any suggestions on what the max number of speakers I can have?
I have attached the room layout. I only have 2 options for TV placement. It can either be on the wall to the left of the door or on the far wall with no windows. Those are 2 windows on the right. I am trying to avoid placing a speaker in the door way as it would get in the way of entering or leaving the room. I would not mind if the speaker was 1 or 2 feet into the room so it is not right at the entrance.
I am thinking I may only have enough room for 5.1.2? Is 5.1.4 possible or 7.1.4? Something like, TV on the left wall. 2 towers next to it and a center below. 2 surrounds in the top right and bottom right corners (not in the closet). And then 2 overhead speakers above my sitting location. My sitting location can be flexible, put it more into the room. Not sure I would have enough space to put the overhead speakers in front and behind the sofa even if I pushed it more into the room.
Any help or thoughts would be appreciated. Thanks!
Name:	Room Dimensions.png
dsp123 is offline
post #2 of 11 Old 04-26-2019, 08:31 PM - Thread Starter
Liked: 0
Also, the ceilings are only 8 feet tall. Not sure if that makes a difference.
dsp123 is offline
post #3 of 11 Old 04-26-2019, 10:48 PM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
What is the decor going to look like in there? Furniture?
9x10’ish Room...certainly a 5.1.2 system would work, but even Dolby recommends going with four overhead speakers.
Dolby Labs has a great web site...keep navigating through the site looking for something like “Speaker system setup”...
They have just about every speaker configuration imaginable drawn out as very nice diagrams.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #4 of 11 Old 04-27-2019, 10:53 AM - Thread Starter
Liked: 0
I will be optimizing the decor for the best TV/Sound experience. I will probably just have a 2 seat sofa. I took a look at the dolby's website but it only includes angles and not distance.
If I do 4 overhead speakers for my small room, i think I would need to put the overhead speakers over the 2 floor standing and the 2 surround speakers. One in every corner. Is that a problem? An issue?
dsp123 is offline
post #5 of 11 Old 04-27-2019, 11:09 AM
gajCA's Avatar
Quoted: 9080 Post(s)
Liked: 6221
I'd put it on the wall with no windows and get good shades for the windows; maybe fully opaque cellular shades.
Strive for this arrangement if going 5.1.4.
BluesDaddy56 likes this.
Geoff A. J., California
gajCA is offline
post #6 of 11 Old 04-27-2019, 11:12 AM - Thread Starter
Liked: 0
Thanks for the information so far. With my room being so small. There is no issue with the overhead speakers being nearly on top of my floor speakers?
dsp123 is offline
post #7 of 11 Old 04-27-2019, 11:38 AM
gajCA's Avatar
Liked: 6221
Not really.
Small room means you should be fine with a smaller sub, sealed might be the best choice.
Stick to 5.1.4 as the room is so small, the move to 7.1.4 is minimal in terms of sound and the costs rise dramatically between a 9 channel and 11 channel receiver.
gajCA is offline
post #8 of 11 Old 04-27-2019, 12:21 PM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
...please also research “Dolby Atmos Enabled” Speakers.
Some Tower speakers have them built in as part of the speaker.
Espo77 is offline
post #9 of 11 Old 04-27-2019, 08:38 PM - Thread Starter
Liked: 0
Not really.
Awesome thanks! I already have 5.1 pioneer speakers and sub. The audio sound from them are good enough for me and/or I cant tell the difference between better systems. Any suggestions on some in ceiling speakers I can use for the overhead? Not sure if it matters but I found a bunch on amazon for around $100 a pair. Not sure if that would be good enough for atmos.
dsp123 is offline
post #10 of 11 Old 04-27-2019, 08:40 PM - Thread Starter
Liked: 0
I have heard these are not nearly as good to having actual in ceiling speakers. I live alone and have no spouse so I don't have to worry about that! =)
I like to watch a lot of movies so I just want the best setup I can have.
dsp123 is offline
post #11 of 11 Old 04-28-2019, 10:18 AM
gajCA's Avatar
Liked: 6221
Anecdotally on AVS one guy who upgraded from "decent" in ceilings for Atmos to "very good" in ceilings for Atmos thought that for most a "decent" pair of in ceilings was all that might be needed.
Something from a name brand should suffice with these being a good choice.
https://www.crutchfield.com/p_107RC6...eiling+speaker
gajCA is offline
