Center Channel inside a fireplace - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 2 Post By Blacklightning
  • 1 Post By kjfalls
  • 1 Post By RayGuy
  • 1 Post By kagtha
post #1 of 20 Old 05-20-2019, 01:19 PM - Thread Starter
mikemoss1@gmail.'s Avatar
Quoted: 24 Post(s)
I'm stuck with an dilemma in my new town house in that a fireplace is where I'd like my HT to be.
Hears a picture showing that the TV would be too high with the center channel in a typical mantle position.
The best I can do to bring my TV down to a halfway decent height is to put my center channel literally inside my (nonworking) fireplace. I thought I'd construct a way to hang it at the top within the fireplace cavity.
Question is If it's place at the front of the cavity, would you expect to hear any audible impact?
The picture shows Black - the TV too high with center channel. Orange - Putting TV as low as possible with center channel Inside the fireplace cavity.
Name:	OVER FIREPLACE.jpg
Sony XBR A1E OLED, Pioneer Elite SCLX502 AVR, ATV4K, Sony UBP800 BR, PS3, KEF Reference 2, 5.1, HSU Sub
[email protected] is online now
post #2 of 20 Old 05-20-2019, 01:24 PM
Madmax67's Avatar
Quoted: 1978 Post(s)
Liked: 2291
Works for me. Better to have the TV lower. Hide those long matches though.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #3 of 20 Old 05-20-2019, 01:26 PM
Madmax67's Avatar
Liked: 2291
You could also mount the center above the TV as well. Just angle it down a bit towards your head if possible. There's users who do this to get the sound as close to where the actors heads are for dialogue.
Madmax67 is offline
post #4 of 20 Old 05-20-2019, 03:21 PM
RayGuy's Avatar
Quoted: 2529 Post(s)
Liked: 2279
MantleMount ...
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #5 of 20 Old 05-21-2019, 09:03 AM
Quoted: 692 Post(s)
Liked: 213
If the fireplace is truly not workable, the way you have drawn the yellow marks looks the best aesthetically and sonically. But if at all possible, I would love to have a working fireplace. In that case, moving the TV a bit higher will be the most aesthetically and sonically pleasing. It will be only a few inches higher (try to get a thin center speaker) and may not change the viewing angle too much depending in how far from the TV you sit.
Hope it helps.
SouthernCA is offline
post #6 of 20 Old 05-21-2019, 09:18 AM - Thread Starter
Quoted: 24 Post(s)
Thanks all for the feedback and suggestions. The fireplace would need to be relined and I'd be afraid to have the TV above it anyway because of heat. I think I'll try the orange height and hope my neck adapts!
I'm thinking of hanging the center channel at the face of the fireplace hole. I believe the easiest way to do it is wire looped on each end. I assume it would be hard to see the wire or fish line, but I wonder if a speaker that is not firmly on a shelf would have any big audio impact. Doubt it but if anyone has a strong feeling on it like to hear.
post #7 of 20 Old 05-21-2019, 09:32 AM
pjp
pjp's Avatar
Quoted: 393 Post(s)
Liked: 277
pjp is online now
post #8 of 20 Old 05-21-2019, 12:09 PM
m. zillch's Avatar
Quoted: 4671 Post(s)
Liked: 3466
Question is If it's place at the front of the cavity, would you expect to hear any audible impact? Orange - Putting TV as low as possible with center channel Inside the fireplace cavity.
I think it will work as long as you bring the center's face up to the front and don't tuck it into the fireplace. The large hole/cavity below it may not be ideal but maybe you could fill the hole with a box? Maybe a subwoofer?
m. zillch is offline
post #9 of 20 Old 05-21-2019, 12:38 PM
Blacklightning's Avatar
Quoted: 998 Post(s)
Liked: 850
I know some like to run the center a little hot but this is taking it to the next level.
Leeliemix and Madmax67 like this.
Blacklightning is offline
post #10 of 20 Old 05-21-2019, 09:10 PM
asarose247's Avatar
Quoted: 1184 Post(s)
Liked: 1044
+1 for @m.zilch
is there room for a 12" /15" /18" Sub / MBM that just may also be a good shelf for the CC
what are the dimensions of the cavity there?
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #11 of 20 Old 05-22-2019, 11:51 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 323 Post(s)
Liked: 113
If center or sub are ported the fireplace may act as a horn and give some unwanted effects.
Espo77 likes this.
kjfalls is offline
post #12 of 20 Old 05-23-2019, 12:03 AM
Quoted: 692 Post(s)
Liked: 213
Hope it helps.
On second thought, I really think that putting the center channel in the fire place will look odd and unpleasing to the eye.
So placing a thin center channel above the fireplace and then the TV above that is the only solution that may work and may be aesthetically pleasing.
By the way, I also have my TV above a working fireplace for the last 10 years and never felt TV to be warm .
post #13 of 20 Old 05-23-2019, 05:46 AM
kagtha's Avatar
Quoted: 85 Post(s)
Liked: 105
I demoed my mantle and installed a horizontal 1099. Sounds Amazing, and believe it or not the gas fireplace does not even warm up the bottom of the LCD.
Sent from my Pixel 3a using Tapatalk
Bedroom Audio: Two Shallow Under Bed PA310-8 12's energized by an SPA250DSP Plate Amp. Two BST-1s. 75 Watt 7.1 Onkyo AVR with Five Martin Logan MLT-2 LCR & Surrounds.
Living Room Audio: One Behringer NX6000D flexing four PA460-8's in a contemporary VBSS credenza build, 100 Watt 5.1 Sony AVR zapping Three horizontal Elusive 1099s LCRs and Two Martin Logan MLT-2 Surrounds. Two BST-1 Bass Shakers charged by the MLT-2 Sub Amp.
kagtha is offline
post #14 of 20 Old 05-23-2019, 05:55 AM
eljaycanuck's Avatar
Quoted: 1848 Post(s)
Liked: 2596
My preference would be:
- to lower the TV down to the mantle-top; and
- empty out the fireplace and put a nice CC speaker stand (with CC speaker on top) just outside of the opening.
eljaycanuck is offline
post #15 of 20 Old 05-23-2019, 06:49 AM
pjp
pjp's Avatar
Quoted: 393 Post(s)
Liked: 277
Why wouldn't one of the low-profile centers work between the mantle and the TV?
My sister-in-law has the TV directly above a working fireplace that is used often and there is no heat issue at all.
https://www.crutchfield.com/p_109SA1...eaker&skipvs=T
29-3/8"W x 4-1/8"H x 7-5/16"D
https://www.crutchfield.com/p_107SIG...ck-Walnut.html
24-7/16"W x 4-3/16"H x 6-1/8"D (placed horizontally)
JBL:
Polk:
pjp is online now
post #16 of 20 Old 05-23-2019, 12:35 PM
Quoted: 692 Post(s)
Liked: 213
Looks great. What are the two white elements on the two sides of the fireplace. Speakers?
post #17 of 20 Old 05-23-2019, 12:37 PM
RayGuy's Avatar
Liked: 2279
Another option:
https://www.crutchfield.com/p_893R22...ck.html?tp=189
Or:
https://www.crutchfield.com/p_265C10...ck.html?tp=189
One more:
https://www.definitivetechnology.com...s/mythos-seven
pjp likes this.
post #18 of 20 Old 05-23-2019, 07:12 PM
kagtha's Avatar
Quoted: 85 Post(s)
Liked: 105
The LR mates to the Center 1099. They are toed-in and up just a bit.
The horizontal placement is not generally accepted by audiophiles, so I was very lucky to have help from Erich and Michael Hurd on final LCR guidance.
In combination, they all sound phenomenal seated anywhere.
eljaycanuck likes this.
kagtha is offline
post #19 of 20 Old 05-23-2019, 08:36 PM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
...I wonder what the center channel speaker would sound like if you mounted it all of the way up to the top of the chimney, pointing down?
There’s a lot of good ideas from others, but...
This is what I would do:
The goal is to get the tweeters from all three front speakers in line.
First I would fill the fireplace in with some sort of blanket insulation or whatever, or room treatments. There’s several benefits here.
It would be interesting to see if you can hear audio from outside...neighbors? hehe
Next I would find a TV stand and push it back to the fireplace opening, where the TV and the front speakers can be level with each other.
Most people tend to mount their TV’s too high. You have the opportunity to have the screen more at eye level now.
Just get creative as to what type of TV stand.
Espo77 is offline
post #20 of 20 Old 05-23-2019, 08:55 PM
m. zillch's Avatar
Liked: 3466
How about a fake fireplace which when you power on the TV it flips around and exposes the center speaker? I bet they exist. I'll go look. . . .
Hmm.
