Help with 5.2.2 surround placement - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By sdurani
  • 1 Post By sdurani
  • 1 Post By sdurani
  • 1 Post By RayGuy
  • 1 Post By RayGuy
  • 1 Post By RayGuy
post #1 of 12 Old 06-03-2019, 08:50 PM - Thread Starter
Liked: 2
Hi, we recently moved and I am working on getting my media room setup as best I can. The room poses a number of problems, most of which won't be able to resolved without construction.
I'm currently addressing the limitations of the built in by pulling out all of the speakers. This has helped a lot already.
With such a short and unusual layout, I am effectively limited to a 5.x.2 setup. Anything more and I fear I will lose adequate separation between the surrounds and heights. Maybe I'm wrong.
I have a pair of RBH SV-61R's on the way for my surrounds, but need help with appropriate placement. The red blobs on the pics is where I'm planning placing these bad boys, but wanted to see if any of you have any tips for the best results.
I have a tons of additional pics and can supply whatever data would be helpful, just let me know.
Thank you
Sent from my SM-N950U using Tapatalk
bretcoe is offline
post #2 of 12 Old 06-04-2019, 11:45 AM - Thread Starter
Liked: 2
Hmm...is there a more appropriate place for me to ask this question?
bretcoe is offline
post #3 of 12 Old 06-04-2019, 01:10 PM
sdurani's Avatar
Quoted: 6970 Post(s)
Liked: 5951
If you're going to do a 5.1 set-up with a single pair of Surround speakers, they would be less distracting if placed in the back corners of the room, a foot or so above seated ear height, aimed towards the listening area. With your seating away from the back wall, you're an ideal candidate for a 7.1 set-up, with the Side speakers slightly forward of the listeners and Rear speakers in the back corners. In fact, on the right side, I would place the speakers just above the light switch plates (and copy those locations on the left side). This will give you wrap-around envelopment and side-vs-rear separation in the surround field that is not possible with only one pair of Surrounds.
If doing one pair of height speakers, then mount them on or in the ceiling a couple feet or so forward of the listening area. Again, with your seating away from the back wall, you are an ideal candidate for two pairs of height speakers, with each pair at roughly 45 degrees elevation forward & rearward of you (measure from your ears to the ceiling, that same distance forward & rearward of you on the ceiling is 45 degrees elevation). One pair of heights will let you hear left-vs-right movement overhead. Two pairs of heights will let you hear left-vs-right AND front-vs-back movement above you.
So even if you stick with a 5.2.2 set-up, keep in mind that your choice of seating location makes it easy to do a 7.2.4 set-up and take good advantage of what the additional speakers bring to the table.
bretcoe likes this.
Sanjay
sdurani is offline
post #4 of 12 Old 06-04-2019, 01:32 PM - Thread Starter
Liked: 2
Hi @sdurani ,
I appreciate your response, it is very helpful.
I want to make sure I understand what you are saying. The left side is the real problem because of the distance to the wall. Is this kind of what you are talking about?
bretcoe is offline
post #5 of 12 Old 06-04-2019, 01:58 PM
sdurani's Avatar
Liked: 5951
Didn't realize the left wall was so far away. In that case. probably better to do a single pair of Surround speakers and place them like in your 5.2.2 drawing. However, I would still take advantage of your couch being away from the back wall by doing 4 height speakers (5.2.4 set-up).
bretcoe likes this.
Sanjay
sdurani is offline
post #6 of 12 Old 06-04-2019, 02:33 PM - Thread Starter
Liked: 2
I'll get some distances to the wall.
Are the areas for the x.x.4 IC's about right?
bretcoe is offline
post #7 of 12 Old 06-04-2019, 03:10 PM
sdurani's Avatar
Liked: 5951
Did you follow the instructions from my earlier post for height speaker placement?
robbyc30 likes this.
Sanjay
sdurani is offline
post #8 of 12 Old 06-04-2019, 03:53 PM
RayGuy's Avatar
Quoted: 2604 Post(s)
Liked: 2355
Light Blue dots in the diagram. This more defines the diagonal speaker placement scenario. Five channel configuration.
bretcoe likes this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #9 of 12 Old 06-04-2019, 09:38 PM - Thread Starter
Liked: 2
Hi Ray,
Thanks for the drawing!
I'm racking my brain coming up with good solutions. I did redo a gorilla style drawing with the couch for scale, and a better representation of the built ins angle.
I can't see anyway to cram 7 bed channels, or 4 heights and still have adequate separation. The room is just too small.
It seems like I'll need a stand for the left, and then just make the right match.
bretcoe is offline
post #10 of 12 Old 06-04-2019, 10:08 PM
RayGuy's Avatar
Liked: 2355
Given that the angle is not as great as originally thought, that config looks to be more than adequate. Just experiment and see what works best. Let your ears decide.
bretcoe likes this.
post #11 of 12 Old 06-15-2019, 07:25 AM - Thread Starter
Liked: 2
This where I'm at now, 5.2.4
I'm having trouble with the low end now though. I'll get some REW graphs to show what I mean, but in general the 5.x.4 piece is performing pretty well.
I was hoping I could get away without needing the minidsp sub eq, but now am going to get one ordered. Plus, it's time to evaluate the replacement options for my Sunfire hrs-12's. I'm leaning toward dual svs sb3k's.
I think my ceiling area is just a bit too cramped for x4 overheads, and am leaning toward 5.x.2 again. It seems like there is not enough separation between the bed and overhead channels to ensure solid definition.
bretcoe is offline
post #12 of 12 Old 06-15-2019, 03:27 PM
RayGuy's Avatar
Liked: 2355
I would try two things for the surround speakers. First, try them toed-in a bit more, so they are almost facing each other. The other thing to try is having them raised a bit higher. Both these options are an attempt to avoid the "speaker in your ear" effect that you get when seated close to one or the other surround.
Given you are having bass issues with the subs in their current positions, it might make some sense to try separating them, perhaps one in the back and one in the front? This might give you a more even frequency response across a broader area of the room. Another option would be to have them on the sides of the room, facing each other. Given the non-rectangularness of the room, placing the subs is more of a challenge and experimentation is definitely in order.
bretcoe likes this.
