Dobly Atmos in unfinished basement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-16-2019, 09:09 AM - Thread Starter
muohio's Avatar
We are still undecided on if we should finish the basement or not. Still throwing around the idea of moving to a new location. That being said, we have an area setup with an LG E8 OLED, Klipsch 5.1 speakers (RF-82 II, RC-62 II, RS-52 and RW-12d) and a Yamaha RX-A1080 receiver. Was thinking of getting a set of the Klipsch R-41SA on sale. Would be mounted on the wall firing at the seating position. Will this give any type of Atmos experience?
muohio is offline
post #2 of 6 Old 06-16-2019, 12:41 PM
sdurani's Avatar
Quoted: 6970 Post(s)
Liked: 5948
Depends on which wall you mount them to. If you mount them high up on the front wall, you'll get a taller soundstage, which will sound nice but won't be the overhead effect intended by Atmos & DTS:X. To get the overhead effect, mount them as high up as possible on the side walls, directly to the sides of the main listening position.
Sanjay
sdurani is offline
post #3 of 6 Old 06-16-2019, 06:14 PM - Thread Starter
muohio's Avatar
Sounds like it would be better to buy a pair of speaker for the ceiling then. The RX-A1080 on supports a single pair of overheads.
muohio is offline
post #4 of 6 Old 06-19-2019, 06:06 AM
Quoted: 12 Post(s)
Liked: 3
Nothing is going to beat an in-ceiling set. I had some SVS prime elevation to try and avoid plugging a hole in my ceiling, but it just raised the stage a bit and didnt really envelope the room. I ended up replacing those with two sets of RSL c34's in the recommended locations and it was a pretty big difference (enough that even my wife could tell).
Jon C is offline
post #5 of 6 Old 06-19-2019, 12:00 PM
ScottAvery's Avatar
Quoted: 631 Post(s)
Liked: 183
Assuming the ceiling is open joists, you could mount a piece of plywood to the ceiling in front of each of your mains then use the R 41SA to bounce off the plywood as it was designed.
ScottAvery is offline
post #6 of 6 Old 06-23-2019, 02:03 PM - Thread Starter
muohio's Avatar
I ended up mounting a pair of speakers between the joists themselves. I know it's not an ideal listening setup, but it works for what it is.
muohio is offline
