Acoustic absorption behind screenwall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-17-2019, 03:43 AM - Thread Starter
Bruach's Avatar
Quoted: 21 Post(s)
Hi folks
So im in the process of building a new theatre room witg a 150" spandex cinemascope screen. The screen wall is 800mm off the end wall and the room dimensions are 5.2m x 8m.
I am looking for a solution to treat the wall behind the screen for sound absoption.
The goto diy material in the theater build forum is linacoustic. 2 layers with plastic in the middle for max low frequency absoption.
I cant get my hands on linacoustic in oz and have struggled to even find a duct insulation alternative. So Im thinking of using some rockwool bats or blanket and covering it with black carpet. Can anyone comment on the use of carpet for sound absorption, taking into account it is coupled with 50mm rockwool bats and will be 70mm off the wall.
Sent from my SM-N960F using Tapatalk
Bruach is offline
post #2 of 7 Old 06-17-2019, 05:42 AM
SteveCallas's Avatar
Quoted: 738 Post(s)
Liked: 679
Can you get 4” wedge acoustic foam? Its absorption properties measure quite high despite what misinformation has been posted in the past.
SteveCallas is offline
post #3 of 7 Old 06-17-2019, 07:45 PM - Thread Starter
Bruach's Avatar
Quoted: 21 Post(s)
I can source acoustic foam on ebay but didn't think it was any good. I have some that is very light weight so just assumed it wouldn't absorp much. Maybe i should test it.
Anyone know how I can setup a test? I have a dayton mic and have played with rew a little in preperarion for room testing.
Bruach is offline
post #4 of 7 Old 06-17-2019, 08:01 PM
Quoted: 738 Post(s)
Liked: 679
I dont know about stuff on ebay, but foam factory had theirs tested
post #5 of 7 Old 06-19-2019, 02:11 PM
ScottAvery's Avatar
Quoted: 628 Post(s)
Liked: 182
at 800mm you could use full bales of insulation still wrapped in plastic. Stack two high in each corner, at minimum, for a floor to ceiling bass absorber.
ScottAvery is online now
post #6 of 7 Old 06-19-2019, 02:21 PM - Thread Starter
Bruach's Avatar
Quoted: 21 Post(s)
Yeah good idea i was definetely going to do this in the corners but i hadn't considered leaving them in the bags.
I wont have that room all the way across with the speakers and subwoofers in place so I'm looking at treating the wall right across.
Bruach is offline
post #7 of 7 Old 06-19-2019, 02:35 PM
ScottAvery's Avatar
Quoted: 628 Post(s)
Liked: 182
Yeah, for that I used duct liner which you said you cannot find. Maybe the locals just call it something different.
