Rear Center? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By HarleyRider
  • 1 Post By Mashie Saldana
  • 1 Post By PSRagE
  • 1 Post By Glimmie
post #1 of 12 Old 07-09-2019, 09:09 AM - Thread Starter
PSRagE's Avatar
Liked: 2
Question Rear Center?
I have recently upgraded my home theater from a 6.1 to a 5.1.4 (replace Yamaha RX-Z1 with RX-A3080). This has left me with an unused rear center speaker mounted to the ceiling. I guess this position is obsolete now? Seems a shame to abandon it - especially since I can't take it down.
PSRagE is offline
post #2 of 12 Old 07-09-2019, 10:59 AM
HarleyRider's Avatar
Quoted: 147 Post(s)
Liked: 99
I think the 6.1 formats like DTS:ES and Dolby Digital EX were more prevalent on DVD and never really caught on. Then Bluray came out and started supporting Dolby True HD (lossless)/Dolby Digital Plus (lossy) and DTS Master Audio (lossless)/DTS HD (lossy) 7.1 formats, which replaced the single mono rear center channel in favor of separate, discrete SBR and SBL channels. I don't know the exact dates, but I'm guessing the mono rear center channel has kind of been obsolete for a good 10-12 years.
PSRagE likes this.
Pre/Pro: Anthem AVR 60 | 5.2.4 Config: MartinLogan ElectroMotion ESL X FL/FR, ESL C Center, Motion LX16 Surrounds, Motion 4i Atmos | Subs: Velodyne DD-15, Martin Logan Dynamo 1100x | Amplification: Emotiva XPA-3 Gen 1 FL/C/FR, Emotiva A-700 Surrounds and Atmos
Dedicated ARC Genesis Thread
HarleyRider is offline
post #3 of 12 Old 07-09-2019, 11:23 AM - Thread Starter
PSRagE's Avatar
Liked: 2
Huh, that is what I was afraid of. Sounds about right since I originally built the HT in 2004. Its too bad though since I recently renovated and included ceiling-mounted banana jacks at each speaker's location (I'm good at cutting holes, not so good at fixing them ). Good thing my wife is pretty patient with these shenanigans!
Cool avatar, BTW. My HT is made up of Mirage Omnis (now including a spare CC)
PSRagE is offline
post #4 of 12 Old 07-09-2019, 11:30 AM
toddwz's Avatar
Quoted: 54 Post(s)
Can you do 6.1.4? I have a rear center and would like to make use of it as well.
toddwz is offline
post #5 of 12 Old 07-09-2019, 12:25 PM
Quoted: 147 Post(s)
Liked: 99
I know what you mean. It's good to have a patient wife. Mine's a saint for putting up with me always tweaking something, moving a speaker somewhere else, buying a new piece of gear.
Thanks, yeah, Mirage -- good stuff. Was really bummed when they folded. I picked up a pair of OMD-28 towers and an OMD-C2 about 12 years ago for a fraction of what they cost when they first came out. Always planned to go back and pick up some Omnis or OMD-R's to round out the rest of the surround channels for home theater but waited too long. So now the OMD-28's are in storage until I get around to redoing my living room and setting up a 2-channel music-only rig. They're just too cool to part with.
post #6 of 12 Old 07-09-2019, 12:55 PM
LastButNotLeast's Avatar
Quoted: 2518 Post(s)
Liked: 2151
In my early car stereo days, I had the left + and right + hooked up to a center. AIUI, the center would play the DIFFERENCE between the other two speakers. Since you're already wired, you might want to try something like that.
Michael
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #7 of 12 Old 07-12-2019, 01:02 PM
RayGuy's Avatar
Quoted: 2852 Post(s)
Liked: 2619
5(7).1.6, with the two rear Atmos channels merged and fed to the one speaker?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #8 of 12 Old 07-17-2019, 01:51 AM
Mashie Saldana's Avatar
Quoted: 1210 Post(s)
Liked: 1052
Now that is a name I have not seen in a great many years.
As for what to do with your rear center, I would say put it to use. I take it you are using the room correction software in the RX-A3080 so that rules out Dolbly PLII center extraction using an old AVR. What you will need is a line level mixer and then a suitable amplification for the speaker.
You want each signal sent to the rear centre reduced by about 3dB.
It is a lot of talk about centre extraction in this thread where it is used to expand 4 hights to 6 and add front wide speakers as well.
PSRagE likes this.
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is online now
post #9 of 12 Old 07-17-2019, 09:53 AM - Thread Starter
PSRagE's Avatar
Liked: 2
A great many years is right, good to "see" you again!
This sounds like a solid plan. I'll give that thread a read.
Mashie Saldana likes this.
PSRagE is offline
post #10 of 12 Old 07-18-2019, 11:25 AM
Glimmie's Avatar
Quoted: 1079 Post(s)
Liked: 1000
DIY Rear Center
I have been running a synthesized rear center since 2002!
Basically all you do is mix the rear left and rear right in an L-R to get a difference signal. That's your rear center. I initially used an old junked Lexicon CP1 processor which could do that.
Today MiniDSP makes a board and has specific software for a rear center channel.
How does it sound? Hard to tell, The effect is very subtle, probably not worth the effort unless you already have the speaker mounted in place.
https://www.minidsp.com/products/plu...channel-detail
PSRagE likes this.
Glimmie is offline
post #11 of 12 Old 07-18-2019, 02:45 PM - Thread Starter
PSRagE's Avatar
Liked: 2
Yeah, that is the thing. It is mounted and is pretty permanent - it may as well do something:
I figure I'll use Mashie's mixer connected to the Surround Back pre-outs and the output from that will go to an old Yamaha AVC-30U amplifier I have in storage.
Huh, [IMG] tags not working? Pic here: http://www.houseofrage.com/images/Room1.jpg
PSRagE is offline
post #12 of 12 Old 07-18-2019, 03:49 PM
Liked: 1052
The [IMG] tags should work, however they seem to be broken right now.
