AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Audio Theory, Setup, and Chat (https://www.avsforum.com/forum/91-audio-theory-setup-chat/)
-   -   Center channel placement (https://www.avsforum.com/forum/91-audio-theory-setup-chat/3078038-center-channel-placement.html)
Patrick Flaherty 07-12-2019 05:15 AM
Just started setting up my first PJ screen and now looking at speaker setup. The issue I have is a tight space (7' ceilings) and the PJ screen leaves only about 1' maybe a few more inches. Is this going to be too low for a center channel or is it not too noticeable? I have the Emotiva c1. Looking for input, would consider maybe downsizing the screen if needed.
torii 07-12-2019 05:20 AM
I always want my center speaker as close to eye level as I can get...if I must I have it lower and aim a bit higher. havent had a problem with boston acoustics, klipsch, or focal centers.
Patrick Flaherty 07-12-2019 06:33 AM
Yeah, I just did a bit of reading. I can place lower if I need just sounds like suggestions to angle up toward head level.
HarleyRider 07-12-2019 06:53 AM
Being that low, you will definitely want to angle it up toward the listening position. I would say to try that first before getting a smaller screen. I think you'd have to go quite a bit smaller with the screen to make any real difference. For example, the height difference between a 110" 16:9 and a 100" 16:9 screen is only about 5".
Another option, not sure if it's feasible for you, is to get an acoustically transparent screen and place the speaker(s) behind the screen.
Patrick Flaherty 07-12-2019 07:47 AM
Dont think acoustically transparent will work with my setup. Do you have any recommendations for some sort of wedge or mount that can tilt the speaker up? I am thinking something like this otherwise might work on each end with the back on the floor.
https://www.worldwidestereo.com/prod...BoCfmYQAvD_BwE
Squirrel! 07-12-2019 07:49 AM
Scrap the center and go phantom. You'll enjoy it more.
Patrick Flaherty 07-12-2019 08:00 AM
Why would I enjoy it more?
HarleyRider 07-12-2019 08:06 AM
I don't see why that wouldn't work. Short of building something yourself, the only other thing I would suggest is something like this that's used to angle a guitar amp:
https://www.americanmusical.com/Item...-AMPWEDGE-LIST
The nice thing about this one is that it allows for some angle adjustment. It's not quite as wide as your speaker, but you still might be able to get by with just one. But you might want to cover it so you don't have to look at the "WWW.AMPWEDGE.COM" advertisement stamped across the front... :)
Patrick Flaherty 07-12-2019 08:17 AM
I actually just found this. Like it much better than both if it will work. Thanks for the suggestion though.
https://www.amazon.com/Hamilton-Uni-...s%2C148&sr=8-3
HarleyRider 07-12-2019 08:28 AM
I'm not sure that's going to work. Looks like it's made for speakers/amps that are 18" to 32" tall. Your C1 is only about 8.5" tall. I don't think the angles are going to work out right.
Patrick Flaherty 07-12-2019 08:37 AM
Hm okay. Ill have to look into it more. Any recommendation for bookshelf speaker stands? I thought the b1's were wall mountable but it doesnt seem like they are. Should have done my research :frown:
HarleyRider 07-12-2019 09:30 AM
Yeah, your B1's are rear ported, so you don't want them up against the wall. Need to give them some room for the ports to breathe. I've used Sanus stands in the past. Relatively inexpensive, decent quality for the price. Most stands are over-priced, in my opinion.
Before you buy anything, measure your ear height when you're sitting in the main listening position. Then go to your B1 and measure the height of the tweeter from the bottom of the speaker. Subtract that from your first measurement and that's around the height of the stand you want. When you place the speakers on the stand, you want the tweeters to line up at ear height as closely as possible.
Check out what Crutchfield has. Something like the Natural Foundations stands that come in several heights and a couple different finishes. I like these because they have a larger top plate than some of the others, approx. 7.5" X 7.5".
https://www.crutchfield.com/p_051NF1...k-lacquer.html
Alan P 07-12-2019 09:49 AM
If the CC is going to be on the floor and angled up, why not do the same with the FR/FL? To me, this would probably sound better than having such a large discrepancy in vertical space. Panning sounds that go from FR>CC>FL or FL>CC>FR wouldn't seem to move up>down>up.....
Squirrel! 07-12-2019 03:30 PM
1 Attachment(s)
Well, it eliminates any concern you may have about location, angling, etc...Not to mention it will make your space sound more like an actual theater. It costs absolutely nothing as well. :cool:
Or you can insist on there HAVE to being more to it and listen to everyone else. ;)
Bubba_Buoy 07-23-2019 05:07 AM
I have had to do a steep angle in the past on my center channel and generally found it to be just fine...it still looks like the voices are coming from their mouths as they should.
I also have found that when I experiment during movies by unplugging certain speakers to hear what's going on in the other channels, I am amazed both by what does, and what does NOT, come out of each one.
Phantom mode, assuming that means the voices are evenly split between the front RL speakers, is a very good option for people with excellent speakers that image well, and who don't have room or whatever for a center speaker.
Can't lose!
Skinfax1 07-23-2019 05:46 AM
Man, do you suggest he doesn't receive best advice here? ;)
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
