Problem With 5.1 Sound on Roku Ultra Device - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-17-2019, 08:37 AM - Thread Starter
Doug47's Avatar
Quoted: 14 Post(s)
I have a rather odd issue with my Roku Ultra device. On Netflix or Amazon Video, when I selected 5.1 sound, the video plays fine, but there is an up to 30 second delay before the audio (5.1) starts. This doesn't happen when I selected "stereo" sound. My Roku is connected to my NAD 777 V3 via an HDMI cable. The Roku is connected to the internet via a wireless connection.
Any suggestions?
Doug47 is offline
post #2 of 6 Old 07-18-2019, 02:38 AM
Quoted: 268 Post(s)
Liked: 135
What happens if you pause playback at start and then hit play again after a few seconds?
Have you tried a cabled connection?
Is it possible the NAD use a long time to recognize the signal type and change sound mode?
Leeliemix is online now
post #3 of 6 Old 07-22-2019, 12:04 PM - Thread Starter
Doug47's Avatar
Quoted: 14 Post(s)
Blame it on HDMI
Originally Posted by Doug47 View Post
Any suggestions?
Well, I found a solution. When I connected my Roku to my NAD, I put in a right-angle HDMI to HDMI adapter so that I could fit things behind the NAD. If I remove that adapter, the problem goes away. In my original configuration, I had multiple joints in the HDMI path. It seems HDMI sucks so much that putting connections along the path is enough to screw it up. So as long as I run a SINGLE DIRECT cable from the Roku to the NAD, everyone is happy and I get no delayed sound.
I hate HDMI....
Doug47 is offline
post #4 of 6 Old 07-22-2019, 12:43 PM
Quoted: 268 Post(s)
Liked: 135
I hate HDMI....
Great you found a solution
...and HDMI is ticklish thats for sure.
post #5 of 6 Old 07-22-2019, 12:50 PM
Ratman's Avatar
Quoted: 2358 Post(s)
Liked: 2214
Yeah... quite common unfortunately.
I hate HDMI....
If it makes you feel better, so do a million others.
EDIT:
This is good HDMI sub-forum with helpful folks.
https://www.avsforum.com/forum/168-h...nnector-world/
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #6 of 6 Old 08-26-2019, 01:50 PM - Thread Starter
Doug47's Avatar
Quoted: 14 Post(s)
Switching Sources...
I've found another solution to the HDMI cable issue. If I quickly switch my input from the HDMI source that is having issues with the Dolby sound to another one (default has been the Sat/Dish source) and then back again, the Dolby starts up almost immediately. I found this solution in another thread. The other thread says that by doing so, you "clear" the confused handshaking process. Again, HDMI is so stupid.
Doug47 is offline
