Vaulted Rear speaker setup recommendations - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Skrimpz
post #1 of 3 Old 08-03-2019, 09:12 AM - Thread Starter
Liked: 1
Greetings all,
We recently moved into this home and are slowly rebuilding our home theater. Unfortunately the speaker placement options are limited for the rear. We have a vaulted ceiling with prewired access... one is about 11 foot high the other close to 13Click image for larger version
ID:	2597822 foot high. What do you recommend I use as a speaker here for rear channel use? Wide made a stipulation that it must be white and she prefers a in ceiling mount. Any advice/feed back is appreciated
ID:	2597824   Click image for larger version
Skrimpz is offline
post #2 of 3 Old 08-03-2019, 12:15 PM
gajCA's Avatar
Quoted: 8809 Post(s)
Liked: 5990
Originally Posted by Skrimpz View Post
Greetings all,
We recently moved into this home and are slowly rebuilding our home theater. Unfortunately the speaker placement options are limited for the rear. We have a vaulted ceiling with prewired access... one is about 11 foot high the other close to 13Attachment 2597822 foot high. What do you recommend I use as a speaker here for rear channel use? Wide made a stipulation that it must be white and she prefers a in ceiling mount. Any advice/feed back is appreciated
Well you can get in ceiling speakers (down firing or angled) or pendant speakers.
These might be a good choice as you can angle them towards the main listening position as both the tweeter and midwoofer are angled unlike pretty much every other in ceiling which just allows you to aim the tweeter.
https://rslspeakers.com/c34e-ceiling-speaker/
Pendant speakers.
There is a larger version too.
https://www.crutchfield.com/S-PSYLyk...BoC0rUQAvD_BwE
Geoff A. J., California
gajCA is offline
post #3 of 3 Old 08-04-2019, 03:37 PM - Thread Starter
Liked: 1
Those speakers look like a great compromise. Much appreciated advice
gajCA likes this.
Skrimpz is offline
