Subwoofers for music - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #1 of 54 Old 08-16-2019, 12:21 PM - Thread Starter
Quoted: 602 Post(s)
Liked: 89
I know folks tend to use subwoofers for movies and/or 50/50 split but what I would like to know from the experts is if there are any solid arguments for using subwoofers strictly for 2 channel.
I don't believe there is much subsonic content for music so bass extension isn't really much of an advantage in my mind, so then what is the point of using subwoofers in a stereo only system? Let's assume you have full range mains.
Any advantage/disadvantage to using subwoofers for music?
Stephan Mire is offline
post #2 of 54 Old 08-16-2019, 12:45 PM
The Ultimate chest punch!
Adamg (Ret-Navy)'s Avatar
Quoted: 943 Post(s)
Liked: 2070
Hi Stephan,
Great questions. The first and sometimes forgotten element about adding powered subs is how using the AVR crossover settings can redirect a large chunk of power offloaded from the AVR to Powered Subs amp. This results in more amp power available for the Main Speakers. Added head room and reduced distortion. In effect the low end of the FR requires the most power. So it’s like adding pre-amps to your system. Powered Subs will outperform Fullrange speaker in all cases, unless the Fullrange speakers have a power cord and a onboard amp to drive the woofers.
Powered Subs have very powerful amps just to drive that one driver. They make a huge difference. Biggest single improvement I ever experienced.
Alan P and Erod like this.
AdamG, ...out!
The government cannot give to anybody,
anything that the government does not first,
take from somebody else.
Adamg (Ret-Navy) is offline
post #3 of 54 Old 08-16-2019, 12:59 PM
DonH50's Avatar
Quoted: 3218 Post(s)
Liked: 3262
Up to you to define "much subsonic" and it depends how low, and how well, your "full-range" main speakers go.
Organ music, symphonic music, drums, piano hammer strikes, plucked strings, etc. all have content well into the subwoofer region. Most speakers distort significantly when presented with large bass signals anywhere near their -3 dB point.
I first added a DIY servo sub to my system around 1979. I had Magnepan MG-I's that spec'd 50 Hz LF corner. I found the sound and measured performance was much improved with a sub, and was still much better when I upgraded to MG-IIIa's, with a 35 Hz corner, about a decade later. More/better bass and the upper frequencies were better because it wasn't handling the deep bass. My impression did not change as I rotated through some full-range Infinity and KEF speakers during that time frame, plus a number of other speakers (B&W 800-series etc.) that were in my system for brief trials. This was all well before HT was a thing. My listening tastes were primarily classical and jazz with a fair amount of rock (mainly progressive rock like Pink Floyd and Yes) and country mixed in.
I have had sub(s) in my system most of the time since then, and the few times I have not for whatever reason, I have always been much happier when they were added again. Even with music that extra lower octave or three seems to help support the rest of the music.
Remember subs also allow the in-room response to be flatter/better; the best place for the subs and deep bass is rarely the best place for stereo imaging IME.
The biggest counter argument I have read is the limited amount of LF energy on some recordings. Maybe I just tend to get better recordings as I have not noticed a lack of sub-50 Hz bass. Note the low E on a guitar is around 40 Hz, the lowest string on a standard piano is around 27 Hz, and percussive from drums and such reach into single-digit territory, so there is stuff there to be recorded.
IME/IMO - Don
drh3b and Adamg (Ret-Navy) like this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 54 Old 08-16-2019, 01:35 PM
HarleyRider's Avatar
Quoted: 147 Post(s)
Liked: 99
I have tried to go the "purist" route and use only my towers for 2-channel music, but I always felt like I was missing something. No mater how low they were rated to go they were no substitution for my good old 15" servo controlled sub. It can be a lot of work and a lot of trial and error to get the sub(s) seamlessly integrated (at least it was for me), but the payoff is worth it.
Adamg (Ret-Navy) likes this.
Pre/Pro: Anthem AVR 60 | 5.2.4 Config: MartinLogan ElectroMotion ESL X FL/FR, ESL C Center, Motion LX16 Surrounds, Motion 4i Atmos | Subs: Velodyne DD-15, Martin Logan Dynamo 1100x | Amplification: Emotiva XPA-3 Gen 1 FL/C/FR, Emotiva A-700 Surrounds and Atmos
Dedicated ARC Genesis Thread
HarleyRider is offline
post #5 of 54 Old 08-16-2019, 01:53 PM - Thread Starter
Quoted: 602 Post(s)
Liked: 89
IME/IMO - Don
Hi Don, thanks for your post! Some people I have discussed the matter with seem to think that subwoofers are designed almost exclusively for movies. How many times have you heard someone say "subwoofers are designed for home cinema". I've heard it a lot!
I don't know where this perception came from.
A friend of mine tells me that careful placement of his speakers in his room can reduce the effect of standing waves.
post #6 of 54 Old 08-16-2019, 02:07 PM
m. zillch's Avatar
Quoted: 5094 Post(s)
Liked: 3711
Subwoofers generally cover frequencies below 80Hz or so, and are beneficial to the reproduction of sound, including all genres of music, but they aren't as necessary if one uses large, floor standing towers as they are for smaller speakers because big towers already can go well below 80Hz (although only a handful go flat all the way down to 20Hz and below like many subs can).
Erase from your mind it has anything to do with "video". That's marketing BS.
Another common ploy they use is to pooh-pooh subs because they generally make more money selling a consumer two large towers than they do a sub and two bookshelf speakers. Also having a consumer aware of the concept of "bass management" sudden kills their profits in general. If a consumer no longer feels a need to buy speakers that go much lower than 60/80Hz, or so, then the dealer ends up selling markedly less expensive speakers to them.
You need subs for jazz, rock, and classical 2ch music unless you have gigantic towers.
m. zillch is offline
post #7 of 54 Old 08-16-2019, 02:11 PM
emcdade's Avatar
Quoted: 845 Post(s)
Liked: 440
Subwoofers make big BOOM for Transformer movie. Subwoofer is good.
emcdade is offline
post #8 of 54 Old 08-16-2019, 02:18 PM
Ratman's Avatar
Quoted: 2299 Post(s)
Liked: 2156
Back in the old days, before AVR's and "home cinema"... there were subwoofers for stereo audio.
m. zillch, drh3b, DonH50 and 2 others like this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #9 of 54 Old 08-16-2019, 04:23 PM
DonH50's Avatar
Liked: 3262
Thank you and you are very welcome!
I don't either. Subs have been around (and their benefits known) for a long, long time (decades). I first heard them with ESLs and the HQD system, even before small'ish bookshelf speakers became the rage. Nor do I understand why room correction improves the sound so much for movies but is somehow detrimental to music. My room greatly benefits from treatment and room correction SW and neither it nor my ears care if it is a movie or music playing.
Moving a speaker can reduce the effect of reflections (SBIR) and room modes (true modes occur in the bass region and are related to room dimensions). The problem is that it is a rare room that speakers placed for best imaging and soundfield is also the best place to counter room modes even if the main speakers reach deep enough. I have owned planar dynamic speakers (Magnepans) most of my listening life and placement and toe-in was critical but not for room modes; more for comb-filter effects from the back wave when I couldn't (or didn't) damp it.
It is also worth remembering that crossovers do not drop to zero on ether side. Given an 80 Hz crossover there can still be significant energy in the mains down to 40 Hz and in the sub to 160 Hz (though subs tend to have sharper HF cutoffs). That is the main reason I always strive for mains that have a -3 dB corner at 40 Hz or below even with an 80 Hz crossover.
DonH50 is offline
post #10 of 54 Old 08-16-2019, 06:15 PM
m. zillch's Avatar
Liked: 3711
I get your point but I think you are being overly precautious. Heck if we had to make it a point to buy mains that go down to 40Hz or below we aren't all that far off from 20Hz so why not go to there and omit subs all together?
post #11 of 54 Old 08-16-2019, 06:48 PM
DonH50's Avatar
Liked: 3262
Yeah, probably... Practically speaking, I see a fair number of speakers rated to around 40 Hz, but far fewer to 20 Hz. Heck, just a quick check shows Polk T50's at $150 each are rated to 40 Hz at -3 dB (https://www.polkaudio.com/products/t50). I doubt they perform well there (but do not know). It does rule out most small monitors and bookshelf speakers, but I have always preferred larger speakers. That is my preference and no doubt some bias on my part; plenty of folk have smaller speakers, and a number of them extend to 40~50 Hz.
I also left out my usual preference of crossing over one octave but generally no more than 1/2 octave above the -3 dB point. It's a general rule of thumb so there are probably plenty of exceptions. I was weaned on bigger speakers and just never got away from them. The few times I have had smaller mains, like the little Mirage OMD-5's I had for a while, I have not felt the sound was as good as when I had larger mains. The big caveat is that I have rarely had larger bookshelf speakers so don't have a good reference for them. I will say Rogers LS3/5a's were not my cup of tea. Yes, could be my eyes as much as my ears, but with the type of music I like small mains would either distort badly or be crossed high enough that bass was too localized (constraining my sub's location).
And (yes, I know you know this) placement is IMO a good reason to get subs -- it is hard to balance the bass and treble in most rooms if you only have the single pair of speakers. Usually the bass suffers because the stereo image is most important. As an extreme example, I used a pair of subs with my Infinity QRS 2 system (which did reach to about 20 Hz) not because they lacked bass but because the room dimensions and layout put me in a null. I could either get a nice stereo sounds sans bass, or get bass and lousy stereo. A couple of subs nicely filled in the deep bass. And that was back in the 80's.
All of this experience and experimenting was many years before home theater was around.
DonH50 is offline
post #12 of 54 Old 08-16-2019, 07:17 PM
m. zillch's Avatar
Liked: 3711
Every single bookshelf speaker Polk currently makes, in fact.
post #13 of 54 Old 08-17-2019, 12:36 AM
Worf's Avatar
Quoted: 828 Post(s)
Liked: 552
Judging by the cars that roll down the street, music seems to have a lot of low frequency energy...
Worf is offline
post #14 of 54 Old 08-19-2019, 01:02 AM - Thread Starter
Quoted: 602 Post(s)
Liked: 89
Steve Guttenburg seems to think subs aren't needed for music :
https://www.cnet.com/news/the-case-a...ers-for-music/
What do you guys think of his argument?
post #15 of 54 Old 08-19-2019, 01:12 AM
m. zillch's Avatar
Liked: 3711
^I stopped at the first half of this sentence because it shows he's incompetent:
" . . . but music rarely has extremely deep, under-50Hz bass, and most speakers with 5-inch (127mm) or larger woofers can muster 50Hz bass in small or midsize rooms. "
This video may not play here so hit the Youtube Logo in the top center to be taken there:
Not sure if it is true of this Youtube rendition, all I have on me right now is $39 headphones, however this piece has 16 Hz content. [Notice that organ in the vid has pipes several feet wide and the entire instrument is like 3 stories tall.] Many recording engineers attempting to record this piece don't have a proper mic for the infrasonic content or they forget to disengage their low cut filter. One of the best versions of this piece is found on the BAS test disc.
SuperFist likes this.
post #16 of 54 Old 08-19-2019, 01:27 AM - Thread Starter
Quoted: 602 Post(s)
Liked: 89
I had an argument with my friend last night about this. He says and I quote "all tower speakers can be equalized, and a few can be equalized in just the bass without affecting midrange and treble. Any tower speaker with a built-in subwoofer that includes a line-level input, or any tower speaker with speaker-cable binding posts that allow the bass section to be separately amplified, can be optimized for smooth bass response in your listening chair even if the speakers are placed for the best midrange/treble performance. All you have to do is connect a low-frequency equalizer such as the Velodyne SMS-1 or the MiniDSP, then dial in the EQ for flat bass response.".
post #17 of 54 Old 08-19-2019, 01:35 AM
m. zillch's Avatar
Liked: 3711
[Guttenberg:] " . . . but music rarely has extremely deep, under-50Hz bass, and most speakers with . . .
Perhaps he's never heard of the rather exotic instrument rarely seen in most genres of music with a fundamental frequency on its lowest note of 27.5Hz. . . . It's called a "piano".*
*[special varieties even go lower than 27.5Hz, but I was citing a standard 88 key model.]
gajCA likes this.
post #18 of 54 Old 08-19-2019, 04:56 AM
sk373's Avatar
Quoted: 779 Post(s)
Liked: 1115
Tell your friend that it’s not that simple, especially if you are sitting in a null. You can easily run out of headroom trying to compensate for nulls with EQ.
My humble main system:
Vizio M75-E1; Oppo 203 universal UHD player; Denon 4300H AVR, Dual PSA S1801's; Monitor Audio Silver RX-6 mains, RX center, and RX surrounds; one pair NHT mini Atmos speakers; Home-built HTPC (Xeon E1230, 16gb RAM, Crucial M500 480gb SSD, GeForce 980Ti, Corsair CX600, CoolerMaster mini-ITX case); Roku Premiere+; Amazon 4K Fire TV
sk373 is offline
post #19 of 54 Old 08-19-2019, 06:56 AM
DonH50's Avatar
Liked: 3262
Yup, all towers, or any speaker for that matter, can be equalized. But check the frequency response to see how much EQ you need to add to get flat bass response, then look up equal-loudness curves (e.g. https://en.wikipedia.org/wiki/Equal-loudness_contour) to see how much extra power is needed in the low bass region to sound as loud as in the midrange. For a speaker rolling off at 40 Hz you probably need at least 6 dB EQ boost, a four-fold increase in power, at 20 Hz. Now add another 10-20 dB to get that bass to sound good and loud and you need another 10x - 100x, so 40x to 400x net additional power. Finally find the distortion curves for the speaker driven with that much power at 20 Hz (or even 40 Hz). Just because you can do it does not mean you should.
Speakers with built-in subwoofers area special case; yes, you can independently adjust the bass, but that still does not cover the placement issue. It doesn't really matter how much EQ you add if you are sitting in a null. Built-in subs or not.
You are unlikely to change your friend's mind and in the interest of friendship I probably wouldn't try. But decades of experience and measurements disprove his argument in the general case. He may be one of the lucky ones with a combination of built-in subs and speaker placement but the odds are against it.
IME/IMO - Don
Ratman and sk373 like this.
DonH50 is offline
post #20 of 54 Old 08-19-2019, 10:29 AM
m. zillch's Avatar
Liked: 3711
People with the rare speakers with subs built in [I've sold some from Polk, for example] have the advantage that they are exciting the room with two subs, not one, and most importantly from two different locations so the in-room response from seat to seat is more uniform and smoothed out some, compared to using just one sub.
Their disadvantage to owning two subs in the speakers is there is almost no flexibility in placement for optimal results: the location is dictated to the user based on the placement of the of the left and right edges of the sound stage, which itself is (often) dictated by the left and right edges of the chosen TV display screen location.
post #21 of 54 Old 08-19-2019, 10:58 AM
sdurani's Avatar
Quoted: 7153 Post(s)
Liked: 6163
He makes a valid point that "achieving a truly seamless subwoofer blend with the system's speakers is challenging". With "full range" models, the speaker designer has already done that for you. But his quotes from Krukowski's article complaining about too much bass don't make sense, like he's starting from the premise that the subwoofer level cannot be adjusted. The 3 main reasons to use subwoofers for music playback are: location, location, location. As Don already pointed out, the best locations in your room for bass reproduction might not be the best locations for soundstage & imaging. No way to address that with full range towers (unless you're real handy with a saw).
craig john likes this.
Sanjay
sdurani is offline
post #22 of 54 Old 08-19-2019, 11:27 AM
m. zillch's Avatar
Liked: 3711
Especially when you attempt to use the horrible, yet audiophile magazine endorsed REL subs Guttenberg mentions [I was a dealer by the way. Don't fall for their lame excuses for their horrendous performance]. Many of them are text book examples of the dreaded "one note boom" problem which gives subs a bad name because of the bad apples out there, like this $1800, one note [45Hz], piece of junk:
Competent subs which blow away this horrible design in terms of both their output and frequency response uniformity, when tested with the same magazine's methodology, cost $1000 less:
Source: https://www.soundandvision.com/conte...ers-test-bench
post #23 of 54 Old 08-20-2019, 07:18 AM
Skinfax1's Avatar
Quoted: 197 Post(s)
Liked: 65
Lightbulb
With very expensive mains you maybe can reach 30 Hz (-3 dB). Then they are already very good. A good sub with modern eletronics reaches down to 20 Hz (-3 dB) with ease and can easily deliver 500 Watts RMS for minutes at a fraction of the price just for the frequency range that needs it.
Technically a sub is an excellent solution even for stereo, even if integrating it for a flat response is not trivial: it receives all the collected bass contained in a mix. The only frequency range that really needs power, is bass. And the highly opitimized speaker for reproducing bass is equipped with that huge amount power in a sub.
Now you may say, that is only 10 Hz difference! Sure. And information in the low end can almost be ignored. True. But just the fact the speakersystem with a sub does not act as an additional highpass filter (like mains without a good sub) and therefore removing even more subbass than was already removed during mixing and mastering, improves the sound of instruments having most of their energy and fundamentals in a bass range, like kickdrums or basslines, that is significantly higher than the theoretical specs suggest.
Also don't underestimate the changing physical characteristics of a technical system operating at it's limits. There's a huge difference in the reproduction quality, if you have for example a 25% margin left (30 Hz vs 22.5 Hz) or if the system is already running at its limits to reproduce these frequencies. Not to mention amplitude (power) requirements for frequencies at the system's limits.
All these effects compound together.
Imagine you are working out and have reached 180 BPM. Compare that feeling to the intensity at 144 BPM. That's the difference a 25% margin makes - compared to a system running at it's limits.
m. zillch likes this.
Good sound is always the result of engineering. And engineering always starts with measuring. Consumer industry and mainstream will never tell customers about that: improvements in room acoustics are worth roughly ten (10!) times the amount spent on equipment like speakers and receivers. For example: only $500 in room treatment is worth more than spending $5000 (fivethousand) on equipment.
Skinfax1 is offline
post #24 of 54 Old 08-20-2019, 01:04 PM
RayGuy's Avatar
Quoted: 2790 Post(s)
Liked: 2558
Looks like the output from an $180 sub, instead of an $1800 sub.
drh3b, sk373 and m. zillch like this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #25 of 54 Old 08-20-2019, 01:10 PM
RayGuy's Avatar
Liked: 2558
As to the ops original question. With a separate sub reproducing the bass region, you can place the sub in the best position in the room for bass frequencies. That allows you to now place the L&R speakers for best imaging and soundstage. No compromise of either facet of the sound.
post #26 of 54 Old 08-20-2019, 02:37 PM
Skytrooper's Avatar
Quoted: 399 Post(s)
Liked: 387
Yep, subs are great for music. Grand Funk RR's red album. Listen to "In Need" and "Inside Looking Out". Case closed.
TV - LG 65B7P OLED / Receiver - Yamaha RX-A1040 7.2 / Blu Ray - Oppo BDP-83 / Turntable - Technics SL-3300 / Cable Box - Comcast X1 V4 4K /L & R Paradigm Studio 20 V3
Center - Paradigm CC-470 V3 / 4 Surrounds - Paradigm SA-15 V3 In Walls
Subwoofer 1 - Sunfire HRS-12 / Subwoofer 2 - Paradigm PW-2100
Skytrooper is offline
post #27 of 54 Old 08-20-2019, 02:49 PM
RayGuy's Avatar
Liked: 2558
Grand Funk, now that is a blast from the (my) past!
Skytrooper likes this.
post #28 of 54 Old 08-22-2019, 03:57 AM - Thread Starter
Quoted: 602 Post(s)
Liked: 89
Guys, thank you all for your contributions! Really appreciate it.
Now for the next question. Is there a way to determine how much bass is recorded in a music clip? Like a random pop song? I want to see for myself how low the bass goes on music tracks.
post #29 of 54 Old 08-22-2019, 11:52 AM
m. zillch's Avatar
Liked: 3711
The best tool for that is called an RTA, real time analyzer. I use a free one called "musical spectrum" which is a plug-in (add-on) which can be used in the free media player Foobar2000. Here it is in action:
post #30 of 54 Old 08-22-2019, 01:20 PM
WLDock's Avatar
Quoted: 176 Post(s)
Liked: 193
One main advantage is that the placement of the main speakers may not be the best placement to get the best bass. With a sub or two, they can be moved around the room where the bass measures and sounds best. Its takes good integration to get seamless sound.
As far as sub-bass (20Hz-60Hz) content in music that could benefit from subs in the mix to help produce clean and authoritative playback...here are a few examples.
James Taylor, Hourglass (Sony), “Line ’Em Up” This track has probably the strongest bass guitar you’ll hear on a pop recording. It’s a six-string bass that occasionally hits low Cs down at about 32 Hz. The sound, which is rich and heavy through the range from 30 to 120 Hz, is occasionally quite powerful.
Janet Jackson, The Velvet Rope (Virgin), “Go Deep” I’m no great hip-pop fan (though I like Miss J’s album art), but this track is a bass classic. It features rock-steady synth bass at around 35 Hz, with a couple of forays into super-low 25-Hz country.
https://www.soundandvision.com/conte...er-subs-page-2
John Williams, Superman The Movie Soundtrack (Rhino/Warner Records), "The Planet Krypton" this track is an excellent test of the ability of the system to play extreme low frequency information. 1.09 seconds into the track where there are a succession of eight or nine very low notes all sustained for around two seconds they should descend in order the fourth note in succession is the 18hz note when this is played correctly the music should be felt as well as heard if done correctly you should feel a small vibration and the sub may appear to flutter. All this should be done without the sub ever losing control of the notes and producing just one long continuous note. Right at the end of the track there is a crescendo from the tympani drums the strings and the organ. This should increase in volume but not get so loud that the subwoofer is the dominant speaker heard.
https://talkaudio.co.uk/iasca-new-cd...s-t116042.html
There's music out there everywhere with dynamics and content in the sub-bass range 20Hz to 60Hz. Here's a mastering studio using Rythmik Audio subwoofers: http://www.rythmikaudio.com/reviews.html
HDTV - Sharp AQUOS LC-70LE600U 70" | AVR- Anthem MRX 300 | Media Player - Fire TV Box 2nd Gen | Blu-Ray/Media/Gaming - PS3-320GB / Xbox One
Speakers - Main - Boston Acoustics Lynnfield VR965 | Center - Boston Acoustics Lynnfield VR920 | Rear - Artison Portrait LRS
| Sub - DIY Stereo Integrity HT 15 | Sub Amp - O Audio BASH 500
WLDock is offline
