AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Audio Theory, Setup, and Chat (https://www.avsforum.com/forum/91-audio-theory-setup-chat/)
-   -   Positioning for speaker with dual side firing woofers (on each side) and back ports (https://www.avsforum.com/forum/91-audio-theory-setup-chat/3085268-positioning-speaker-dual-side-firing-woofers-each-side-back-ports.html)
William Abraham 08-18-2019 10:22 AM
What is the ideal positioning for a speaker with dual side firing woofers (on each side) and back ports?
How far from back wall?
How far from each other? (for the inside mounted woofer)
How far from side walls? (for the outside mounted woofer)
Thank you
Ratman 08-18-2019 12:15 PM
What speakers?
Is there a manual?
RayGuy 08-19-2019 11:41 AM
Every room is different. There are no hard and fast rules. Experiment, let your ears decide.
William Abraham 08-20-2019 03:52 PM
Originally Posted by Ratman (Post 58440540)
What speakers?
Is there a manual?
It is a pair of JBL Loft 50s that i bought a while ago and run in my workshop. They sound great, but i have not heard of a rule that applies for dual side firing woofers in each speaker w.r.t placement. The manual did not say anything about placement if i recall (when i had it).
asarose247 08-20-2019 05:50 PM
googled up the manual- not to hard to do . . .
https://www.jbl.com/on/demandware.st...0(English).pdf
the warning about placing them adjacent to a CRT
who still uses those?
anyway
suggestion:
get REW and test placement options.
tell us about the room . . .
Ratman 08-21-2019 03:47 AM
From the manual:
"For the best performance, we recommend that you place the speakers at least 5" (130mm) away from the wall behind it to allow proper operation of the rear-panel mounted bass reflex port, and at least 20 inches (51cm) away from the side walls." (Page 3)
https://www.google.com/url?sa=t&rct=...Ti-LjjcSitb29X
William Abraham 08-24-2019 08:51 AM
Originally Posted by Ratman (Post 58452010)
From the manual:
Thank you!!
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
