Do AVR processors compress the audio if select NONE for center channel speaker? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By sdurani
  • 1 Post By craig john
post #1 of 8 Old 09-15-2019, 06:08 PM - Thread Starter
mtrot's Avatar
Quoted: 583 Post(s)
Liked: 245
Question Do AVR processors compress the audio if select NONE for center channel speaker?
It seems like I read some time back that the absence of a center speaker will cause some sort of compression in multi-channel film tracks. I'm not sure if this was with DTS or Dolby, or both. Anyway, I was watching Jurassic World Fallen Kingdom recently, and it seemed like the T-rex roar was just not as loud as it should have been, considering the volume setting. I do not have a center speaker at this point and selected "NONE" in the setup for center channel speaker. Any info much appreciated.
FAMILY ROOM--Legacy Signature II tower speakers(Front L/R), PSB Image 5T tower speakers(Surrounds), Denon AVR-X5200W, Krell FPB 400cx, AR ES-1 turntable w/ Audioquest 404-B cartridge, Oppo UDP-203 UHD Blu-ray Player, RCA HD-DVD player, Samsung HL67A 750A TV
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Yamaha RX-V1800 receiver, Sherbourn 5/1500A 5-channel amp, Oppo BDP-83 Universal Disc Player, Panasonic 60-ST60 plasma TV.
mtrot is offline
post #2 of 8 Old 09-16-2019, 01:19 AM
Quoted: 272 Post(s)
Liked: 138
Afaik the AVR just puts the center info in both left and right main speakers at the correct combined volume.
How impressive the roars are depend a lot on your speakers and sub but they also differ in the mix so some are louder then others.
Leeliemix is offline
post #3 of 8 Old 09-18-2019, 11:46 AM
JonfromCB's Avatar
Quoted: 217 Post(s)
Liked: 159
As much as I'd like to think processors and manufacturers licensed to process specific recorded codes are standardized, reality tells me they are not. I generally agree with Leeliemix...but I have wonder how much the AVR processors differ and/or how they process source materials. For example; when a source was recorded in say Dolby Digital surround and then processed through an AVR for playback on one of manufacturer's playback effects such as "rock", "jazz", "small club", "opera house", "stadium" "neural surround" "multi-channel"...yada yada yada, that clearly are not that AVR's default "DDS" setting one can only guess what the AVR is doing to the signal. And that raises the same question of how any given AVR/manufacturer decodes and up or down mixes some other source material typically recorded and coded in 2 or 3 channels and then decoded and processed for playback in any other format different from the primary code of source material...ie, stereo, DTS, THX, multi-channel stereo. I'm guessing there is a lot "going on" with the signals except perhaps except for simple stereo recordings played back through what most AVRs refer to as "direct", "pure" or "stereo" mode. What we know for sure is that any source recording with center channel content that is being played back through a system without a center channel is down-mixing that information somehow and I doubt that signals are just removed because there is no speaker to send it too. Best advice I have is let your ears be your guide as to what you like, just know that except for 2 channel only recordings or FM, far and away the majority of video source material including streaming and broadcast/cable include center channel signal material.
JonfromCB is online now
post #4 of 8 Old 09-18-2019, 01:12 PM
sdurani's Avatar
Quoted: 7262 Post(s)
Liked: 6301
If you split the info in the Centre channel to the Left & Right speakers, then it has to be lowered (compressed?) by 3dB to keep that info at its original level since it's now being reproduced by 2 speakers.
Also, the newly created Left & Right channels now have 2 channels worth of info downmixed into them: new Left channel = Left+Centre info and new Right channel = Right+Centre info. If, for example, the Left info and Centre info happen to peak simultaneously, then the downmixed Left channel is going to overload (distort). So the original Left & Right info have to be lowered 3dB as well.
Your receiver should automatically raise the L/R speaker trims to compensate for lowering the L/C/R channel info.
Raise the volume setting till it's as loud as it should have been.
craig john and Alan P like this.
Sanjay
sdurani is offline
post #5 of 8 Old 09-18-2019, 04:14 PM - Thread Starter
mtrot's Avatar
Quoted: 583 Post(s)
Liked: 245
I understand all of what you guys have posted, but the question is if the Dolby processor compresses the audio by default when the center channel is not active. I read that somewhere a few years ago, but cannot find that info now. This is with Dolby True HD if I remember correctly.
mtrot is offline
post #6 of 8 Old 09-18-2019, 04:26 PM
sdurani's Avatar
Liked: 6301
Yes, happens by default, for all audio sources, not just Dolby (it's not like DTS codecs or even uncompressed PCM are somehow immune to overloading/clipping when two channels are combined).
Sanjay
sdurani is offline
post #7 of 8 Old 09-18-2019, 05:50 PM
craig john's Avatar
Quoted: 1339 Post(s)
Liked: 1578
All codecs will reduce the levels. However, this is not the same as DRC or Dynamic Range Compression, (aka "Night Mode.") As Sanjay described it is a level reduction of the individual channels to accommodate the additional signal, so as not to overdrive the channels. The overall dynamic range of the *system* is NOT reduced.
sdurani likes this.
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #8 of 8 Old 09-18-2019, 08:18 PM - Thread Starter
mtrot's Avatar
Quoted: 583 Post(s)
Liked: 245
I knew I had read something about Dynamic Range Compression when no center channel speaker is present. Here is an AVS thread that touches on it.
https://www.avsforum.com/forum/89-sp...om-center.html
mtrot is offline
