Cable advice? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 53 Old 09-16-2019, 01:01 AM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
Cable advice?
Working on setting up my 2ch (but likely to be 2.1ch) music area - have most of it on its way, but I just wanted some advice on some cables. I have speaker wire to make my own cables for that, but I'm needing to get a subwoofer cable and a digital coax to connect the CD player to my amplifier. I'm just not sure whether it's better to spend a bit of money on those cables or just get ones that are fairly inexpensive. I do not want to spend hundreds of dollars on cables, though, so "a bit of money" would probably be somewhere in the $50-60 CAD range as a max. The digital coax, I would like to keep to under 3' in length if possible, and the subwoofer cable would probably not need to be any longer than 6'. Both cables single male to male, but there's a chance that the subwoofer I end up choosing will have the regular RCA input, so a Y cable for that wouldn't be off the table.
I know this shouldn't be a difficult decision, but I also don't want to end up with a garbage cable or ripped off, either.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is online now
post #2 of 53 Old 09-16-2019, 04:26 AM
Ratman's Avatar
Quoted: 2362 Post(s)
Liked: 2215
https://www.monoprice.com/product?p_...SABEgJAKfD_BwE
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 53 Old 09-16-2019, 08:15 AM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
Originally Posted by Ratman View Post
Thanks - I've looked at the monoprice, but for some reason couldn't find the single male to male ones in my search yesterday (though my eyes probably just glazed right over it).
It's annoying more than double the price in CAD, though.
post #4 of 53 Old 09-16-2019, 08:41 AM
Ratman's Avatar
Liked: 2215
So $9.00 CAD is still quite a bargain!
https://www.primecables.ca/p-312763-...in+1#sku312763
Ratman is offline
post #5 of 53 Old 09-16-2019, 09:04 AM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
$14, actually
And I never really look at customer reviews, but when I see a bunch that say that the connectors aren't great or that they're too tight, and have damaged the connector on the device they're attached to, it gives me pause. I don't discount user error, either, but I think it's pretty damned impossible to screw up plugging in an RCA cable.
I'll keep it on the list as I don't believe that I need anything crazy for connecting my CD player - for that, I think I just need something that's GE without being from the dollar store. If I were to spend any money, it'd be on the subwoofer cable, specifically.
I'm not one to argue that spending more money on a cable is going to result in better sound (I make my own speaker cables that perform just as well as cables that cost 100's of dollars, IMO, for a fraction of the cost), but half of my brain is thinking that spending a bit more on that particular cable would be beneficial unless I can even just make my own cable using some of the 12AWG speaker wire I already have, and just getting a pair of solderless connectors?
post #6 of 53 Old 09-16-2019, 09:42 AM
sk373's Avatar
Quoted: 804 Post(s)
Liked: 1142
AmazonBasics 4 ft RCA coaxial digital cable, $7.31 CDN
AmazonBasics 8 ft RCA coaxial digital cable (perfectly fine to use as a subwoofer cable), $8.44 CDN
My humble main system:
Vizio M75-E1; Oppo 203 universal UHD player; Denon 4300H AVR, Dual PSA S1801's; Monitor Audio Silver RX-6 mains, RX center, and RX surrounds; one pair NHT mini Atmos speakers; Home-built HTPC (Xeon E1230, 16gb RAM, Crucial M500 480gb SSD, GeForce 980Ti, Corsair CX600, CoolerMaster mini-ITX case); Roku Premiere+; Amazon 4K Fire TV
sk373 is offline
post #7 of 53 Old 09-16-2019, 10:41 AM
Ratman's Avatar
Liked: 2215
$14, actually
Did you open the second link I provided?
That's why you shouldn't read them and/or take them as gospel.
Mon$ter cables get the same complaints at 5x the price.
Or any RCA cable laying around in a box with spare cables.
EDIT:
Here is a link for cables that are less expensive and would probably be fine at 3' and 6' lengths.
https://www.primecables.ca/p-310410-...gths#sku310410
Ratman is offline
post #8 of 53 Old 09-16-2019, 11:27 AM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
EDIT:
Yeah, I clearly overlooked the second link you sent!
When I do, I generally only really look at the negative ones since they tend to be a bit more honest than the ones that are gushing over how good the product is.
Oh god, I would not get a Monster cable.
I don't have any spare digital coax/subwoofer cables lying around, which is why I'm having to look into buying or possibly making my own. I would honestly prefer to make my own if it's easy to do (at least for the subwoofer cable) because I could at least customize the length instead of it either being too long or too short.
I've got my eye on the PrimeCables, too. I've gotten a few things from them, and have been happy with the quality.
The jist of it seems to be to not spend much money on cables, even if they're RCA.
post #9 of 53 Old 09-16-2019, 11:41 AM
Ratman's Avatar
Liked: 2215
Try ANY cable. A yellow composite video cable will be fine for digital coax. For a sub... use the red or white. Don't make your own! It's not worth the effort.
Review the 2nd link (in post 7). Get a 3' and 6' for a total (including shipping) of <$13 CDN.
Speedskater likes this.
Ratman is offline
post #10 of 53 Old 09-16-2019, 11:45 AM
HarleyRider's Avatar
Quoted: 147 Post(s)
Liked: 99
Another option are Mediabridge Ultra series subwoofer cables from Amazon. I've got two 25-footers I've been using for a couple years. Decent stuff for the price.
https://www.amazon.com/Mediabridge-U.../dp/B003FVX9FO
Pre/Pro: Anthem AVR 60 | 5.2.4 Config: MartinLogan ElectroMotion ESL X FL/FR, ESL C Center, Motion LX16 Surrounds, Motion 4i Atmos | Subs: Velodyne DD-15, Martin Logan Dynamo 1100x | Amplification: Emotiva XPA-3 Gen 1 FL/C/FR, Emotiva A-700 Surrounds and Atmos
Dedicated ARC Genesis Thread
HarleyRider is offline
post #11 of 53 Old 09-16-2019, 02:58 PM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
I'll more than likely go with the $3 PrimeCables S/PDIF cable. I can wait on the subwoofer cable since I'm still in the process of deciding which one I'll go with, if at all. I still like the idea of making my own subwoofer cable, and have no problem with the time it takes. I enjoy doing that kind of thing anyway, and it looks really straightforward.
post #12 of 53 Old 09-16-2019, 03:15 PM
Ratman's Avatar
Liked: 2215
They're the same cable!
Why purchase 6' of RG59 or RG6 coax, buy connectors, buy a stripper, buy a compression tool for one cable???
Do as you wish. But, I think it's a waste. If you're going to the expense effort, make both cables.
Ratman is offline
post #13 of 53 Old 09-16-2019, 05:04 PM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
Well, I am not entirely set on making it myself (I don't have a subwoofer yet, either). Speaker wire is fine for that anyway: https://www.techwalla.com/articles/h...s-to-rca-plugs so no RG59/RG6 cable (which I would have anyway) or stripper (which I have anyway because I've cut my own coax cable for my cable box before) or compression tool. I already have all of the tools necessary to make it work, I would only need the connectors.
I am less precious about the cable connecting the CD player, so I have to qualms about getting that for $3. I only wish they came in lengths shorter than 3' because I don't need that much cable (I would probably only need 6 - 12").
post #14 of 53 Old 09-17-2019, 04:02 AM
Ratman's Avatar
Liked: 2215
Since you have the coax tools... Get 4 of these and some coax and make your own, any length you want, whenever you want.
https://www.techtoolsupply.com/Holla.../slc59-rca.htm
Ratman is offline
post #15 of 53 Old 09-17-2019, 04:29 AM
Ratman's Avatar
Liked: 2215
https://www.mycablemart.com/store/ca...iABEgJ_m_D_BwE
Ratman is offline
post #16 of 53 Old 09-17-2019, 05:03 AM
sk373's Avatar
Quoted: 804 Post(s)
Liked: 1142
I wouldn’t use speaker wire for a low-level line signal. Speaker wire is unshielded and you will get noise. If you are dead set on making your own, RG59/RG6 is the way to go. I would go RG59 because it’s more flexible.
Ratman likes this.
sk373 is offline
post #17 of 53 Old 09-17-2019, 01:02 PM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
I'm not dead set on making the cable, I was contemplating it as being an option. If I can get a good quality cable for dirt cheap, I'll go that route instead. The suggestions in this thread have been very good, so I've got great options to choose from.
As a matter of simply playing devil's advocate, what would the argument be for not spending a bunch of money on a subwoofer cable - apart from the notion that it's probably the same quality wire used in the expensive ones version the ones you can get for less than $5? This isn't flip flopping, I would be curious - I personally think it's silly to spend hundreds of dollars on a regular speaker cable when you can make one yourself for pennies on the dollar in comparison (especially if it's using the exact same gauge/wire composition).
post #18 of 53 Old 09-17-2019, 01:09 PM
Ratman's Avatar
Liked: 2215
... what would the argument be for not spending a bunch of money on a subwoofer cable.
Because it's not necessary, just use the right cable.
(as opposed to speaker wire with RCA connectors)
sk373 likes this.
Ratman is offline
post #19 of 53 Old 09-17-2019, 01:49 PM
sk373's Avatar
Quoted: 804 Post(s)
Liked: 1142
Like Ratman says, it's not necessary. Any decently constructed RCA cable will work well, as long as it's properly shielded. Which is why if you're going to make your own, don't use speaker wire with RCA ends--use RG59 or RG6.
sk373 is offline
post #20 of 53 Old 09-17-2019, 01:50 PM
m. zillch's Avatar
Quoted: 5341 Post(s)
Liked: 3850
I use this. It's perfect and extremely well shielded since it is made from RG59:
https://www.monoprice.com/product?p_id=2982
m. zillch is offline
post #21 of 53 Old 09-17-2019, 02:29 PM
Ratman's Avatar
Liked: 2215
I guess you missed the first few posts. The OP started with 3' and 6'. Then desires 6"-12" for the CD player. I think 50' is a bit much.
Ratman is offline
post #22 of 53 Old 09-17-2019, 02:41 PM
m. zillch's Avatar
Liked: 3850
I linked to what I actually own but there are tick boxes for various lengths of the same stuff on the page I linked to.
post #23 of 53 Old 09-17-2019, 02:50 PM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
To be fair, 3' is a bit much if the connectors of the two audio devices are within 12" of each other. I have a rat's nest of wires behind my TV stand, I would rather not have the same behind my 2ch music set up.
I cited 3' since that was the shortest that I could find at the time (and often that's the shortest length available for most cables anyway) - I've since seen 18", and even a Canadian source for the My Cable Mart 6" cable. 6' for the subwoofer cable will probably be fine. I just hate having an excessive amount of extra cable dangling around, which is also why I almost prefer making my own since I can customize it to fit the specific placements.
It's fine if you want to get cheeky, but don't be condescending about it.
post #24 of 53 Old 09-17-2019, 03:10 PM
m. zillch's Avatar
Liked: 3850
The rule I use, learned from professional installers, is: "never use less than 2M (~6ft)."
Reasons:
A. The notion shorter line level interconnect cables [1m vs. 2m] sound better is a myth. They sound the same.
B. A 2M meter cable can connect any two components that a 1M cable can but also introduces the possibility of connecting more further spread apart devices down the road which the 1M may not reach.
C. The up-charge for the longer cable, if buying the correct kind from a non-rip-off source, is inconsequential [81 cents in the example of what I linked to].
D. A 2M cord allows enough slack to let one pull a full size component, straight forward, out of a rack to then spin it around and put it back in but reversed, to examine/make/break/check connections, making the setup much easier to troubleshoot or upgrade even if you don't have easy access from the rear of the rack, such as with a bookcase or heavy/large rack pushed up against the wall.
post #25 of 53 Old 09-17-2019, 03:19 PM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
The rule use, learned from professional installers, is: "never use less than 2M (~6ft)."
Reasons:
A. The notion shorter line level interconnect cables sound better is a myth.
D. A 2M cord allows enough slack to let one to pull a full size component, straight forward out of a rack to then spin it around and put it back in but reversed, to make/break/check connections, making the setup much easier to troubleshoot or upgrade even if you don't have easy access from the rear of the rack, such as with a bookcase.
To be very clear: I don't believe that a shorter cable would make it sound better at all. That's not why I would be using a shorter cable for connecting my CD player to my amp. For my speaker cables, I always allow as much as two extra feet of slack.
post #26 of 53 Old 09-18-2019, 03:58 AM
Ratman's Avatar
Liked: 2215
I did provide you a link for a 6" cable. And my intent was was not to be condescending. It was merely a response to the poster I quoted.
Ratman is offline
post #27 of 53 Old 09-18-2019, 07:44 AM
MTVhike's Avatar
Location: North Shore of central Long Island, NY (Stony Brook)
Quoted: 210 Post(s)
Liked: 48
I think for the short lengths you are talking about, any shielded cable with RCA connectors will work; flexibility is probably the most important feature, especially for a short cable. RG6 and RG59 tend to be fairly stiff.
MTVhike is offline
post #28 of 53 Old 09-18-2019, 08:07 AM
Ratman's Avatar
Liked: 2215
True... but keep in mind that "digital coax" (S/PDIF) recommends 75Ohm impedance. So, as suggested a few times, by a few posters, RG59 would be a good choice in terms of specs and flexibility.
(And before you chime in MZillch, YES! We all know RCA/cinch connectors are not "true" 75Ohm. So.... no need for clarification. )
Ratman is offline
post #29 of 53 Old 09-18-2019, 08:25 AM - Thread Starter
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
It read a bit like a snide jab, so my apologies if that was not your intent.
I still have to figure out the placement of things, but I can easily see only really needing the 6" cable if I happen to stack the amp on top of the CD player. There is an 18" option that I could use if I needed a bit more flexibility.
If I even go the DIY route, RG59 is likely the way I would go. I have RG6 cable, but it's quite stiff, and I wouldn't necessarily use it for making a cable.
post #30 of 53 Old 09-18-2019, 08:34 AM
Quoted: 390 Post(s)
Liked: 321
I actually did laugh out loud.
On another note I've purchased Monoprice 14AGW speaker cable with banana plugs on multiple occasions, excellent quality BUT for some reasons they come without the red and black aluminum cap screwed on.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Current system:
Sony 75X900e/Sony STR-DN-1080, CS-3/CS-8/CS5
Sony X800 4K blu-ray player/Dish Hopper3
Roku 4 Premier/Sony PS-4
Cheddarhead is offline
