Newbie speaker setup help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-17-2019, 11:46 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Here is my current Setup | 7.0 No Sub at the moment ...
Receiver - Onkyo NR-777
110W/Ch (8 ohms)
L/R Speakers - RTiA5:
Total Frequency Response: 30 Hz → 27 kHz
Lower and Upper -3dB Limits: 40 Hz → 26 kHz
Distance From Center Viewing: 13.7'
Center Speaker - CSiA4
Total Frequency Response: 55 Hz → 27 kHz
Lower and Upper -3dB Limits: 65 Hz → 26 kHz
Distance From Center Viewing: 12.6'
Side & Rear Surrounds (In Ceiling) - RC80i
Total Frequency Response: 35 Hz → 20 kHz
Lower and Upper -3dB Limits: 50 Hz → 20 kHz
Distance From Center Viewing: 9.8'(Sides) & 8'(Backs)
My Onkyo AccuEQ set the following up ...
Crossover
Front: Fullband
Center: 60Hz
Surround: 50Hz
Surround Back: 50z
LPF of LFE: 120Hz
I guess my question is, should I be modifying the volume of any of my speakers to be louder than another? Are the crossover frequencies correct? I feel like I'm not hearing much volume from the surround speakers but I am new to this and dont know what settings I should leave alone and what I should be playing with.
If there isnt a straight forward answer, is there a place I can go to get the basics of setting it up?
Thank you!
Zuvassin is offline
post #2 of 8 Old 10-17-2019, 12:03 PM
Quoted: 316 Post(s)
Liked: 163
110W/Ch (8 ohms)
Crossover
Front: Fullband
Center: 60Hz
Surround: 50Hz
Surround Back: 50z
LPF of LFE: 120Hz
Thank you!
Looks fine so far while you dont have a sub. We need to see the channel volume sertings to see if anything strange there. Distances could help also.
Is the volume on surrounds and back low on test tones or only when watching something?
Leeliemix is online now
post #3 of 8 Old 10-17-2019, 12:30 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
I added distances to my initial post. The test tones seem fine (I'm not at home so can't verify at the moment). If I wanted them a tad louder without turning up the rest of the speakers is there an option for that? I can't seem to find it in the Onkyo menu's ...
Zuvassin is offline
post #4 of 8 Old 10-17-2019, 12:33 PM
Quoted: 316 Post(s)
Liked: 163
I dont know onkyo but its in there, probably under speakers or test tones.
post #5 of 8 Old 10-17-2019, 02:41 PM
Alan P's Avatar
Quoted: 6543 Post(s)
Liked: 5891
You adjust individual channel levels (trims) under SETUP>SPEAKER>LEVEL CALIBRATION.
However, I would recommend you NOT do this by ear, it can be very inaccurate. You need a C weighted SPL meter to do it properly. Using the internal test tones, you want all channels producing 75dB at the MLP (Main Listening Position) with the MV (Master Volume) set to "0" (using the Relative Scale, SETUP>VOLUME>VOLUME DISPLAY).
Alan P is offline
post #6 of 8 Old 10-19-2019, 05:53 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Thanks Alan, do you have a suggested meter to use? Or would just one of the better sellers off Amazon do the trick?
I saw some Android app versions ... I assume these aren't worthwhile?
Zuvassin is offline
post #7 of 8 Old 10-19-2019, 07:06 PM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 212 Post(s)
Liked: 105
Apps are fine - they don't have to be totally accurate as you are just comparing each speaker. In other words if they show 80db at 0 Master Volume and they are really only putting out 70db then each speaker will still be putting out 70db and they will all be the same, which is what you are trying to achieve. You can then add 3db or so to the rear surrounds to adjust to suit your room/preference.
niterida is online now
post #8 of 8 Old 10-21-2019, 10:14 AM
Alan P's Avatar
Liked: 5891
Concerning basic speaker levels, what niterida said above is true...a phone app will work.
If you want to be more accurate, you need an SPL meter and good ones start around $50. If you are going to spend $50+ on an SPL meter, I recommend you just go ahead and get a MiniDSP UMIK-1 ($75) and download Room EQ Wizard (free). You will then have a very accurate SPL meter along with the ability to measure your system (and much more).
Alan P is offline
