Advice: Audessey DSX to Atmos Conundrum - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By giomania
  • 1 Post By SteveCallas
post #1 of 8 Old 10-18-2019, 01:55 PM - Thread Starter
Mani4's Avatar
I recently bought the Marantz SR7013 on sale at Bestbuy and it came in yesterday. I'm contemplating whether to open the box or return it to BestBuy. Here is my situation:
1. I am currently running a 9.2.2 setup using Audessey DSX Front Wides and Heights + regular 7.2 and really love the front wides. AVR is 4311CI, with AudessyXT32 and using a yamaha AVR (Direct mode) as external amp for Front Heights
2. My HT is 13' x 22' with 2 row seating;1st row is 10 ft from the screen and 2nd row is ~16 ft and with Atmos 7.2.4 (max with SR7013), I can add either rear heights or Top Rear ceilings along with the Front Heights.
3. I'd definitely like to keep the Front Wides so I can use the Pre-out on SR7013 and connect to 7.1 analog In on the 4311CI.
4. Based on some research on this and other forums, with 2 row seating, 7.2.6 with Top Middle is the preferred Atmos configuration. I cannot do that with the SR7013. What I can do is to keep on using the DSX Front heights and use the SR7013 for Top Middle and Top Rear for Atmos but I'm not sure if that's the correct way to go (2 different technologies -DSX Heights vs Atmos and it may not sound nice- haven't read much about using this combo so feel free to chime in)
5. My existing projector is a BenQ W1070 (1080p) and I'm pretty happy with that.
6. No need for 4k, HEOS as such till the time I upgrade my projector which hopefully shouldn't be for 2 to 3 years.
So based on all this, I'm wondering if I should hold off going to Atmos for a while till some Manufacturer hopefully offers an 11 ch onboard with 7.2.6 pre-outs so I can do 6 atmos (FH, TM, TR). SR7013 is seeming more like an impulse buy to me . Is the SR7013 a significant upgrade from the 4311CI?
Thank you for your help.
RTI-A9s (FL/FR), RTI-A5s(FW), RTI-A3s (SR), RTI-A1s (FH), IP PC351 (C), B&W Matrix S2 (SS), SVS PB12-NSD, Denon AVR4311CI, Yamaha RX-V571, Denon X3000W, BenQ 1070w
Mani4 is offline
post #2 of 8 Old 10-18-2019, 02:15 PM - Thread Starter
Mani4's Avatar
Originally Posted by Yervais View Post
Isnt Audyssey a bit outdated?
It still sounds great with 5.1 or 7.1 content
Mani4 is offline
post #3 of 8 Old 10-18-2019, 03:45 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 673 Post(s)
Liked: 422
I had the exact same set up as you (speaker configuration and receiver) and I went to a Marantz AV 8805 and 7.2.4. I have two rows but never really considered 6 height channels. I think their results are pretty good.
Mark
Sent from my iPhone using Tapatalk Pro
kagtha and Mani4 like this.
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #4 of 8 Old 10-18-2019, 03:52 PM - Thread Starter
Mani4's Avatar
Thank you Mark. Your setup looks cool. So, you don't miss the front wides?
My only thought is that manufacturers may offer 5.2.6 or 7.2.6 in the lower models in the coming year or so and I really don't have the need for 4k, HEOS etc. So is it better to wait, or .4 atmos is much better than DSX FH+FW?
Mani4 is offline
post #5 of 8 Old 10-20-2019, 10:25 PM
SteveCallas's Avatar
Quoted: 856 Post(s)
Liked: 784
I use a Marantz 8012 to do 7.2.4 with zone 2 hdmi out to an older Onkyo that does wides, front heights, and two discrete BOSS systems. That gives me an effective 11.2.4 or 9.2.6 depending on how you want to look at it.
Onkyo stays in DTS Neo X permanently. Marantz uses either Atmos, DTS neural X, or an upmixing solution. Sounds great, go for it.
Mani4 likes this.
SteveCallas is offline
post #6 of 8 Old 10-21-2019, 02:47 AM
Skinfax1's Avatar
Quoted: 298 Post(s)
Liked: 92
Lightbulb
What DTS Neural X does to the sound is absolutely horrible:
https://www.avsforum.com/forum/90-re...test-file.html
Skinfax1 is offline
post #7 of 8 Old 10-21-2019, 05:01 AM
Quoted: 856 Post(s)
Liked: 784
I meant to say DTS X, but nueral X would be one of the upmixing solutions I was referring to right after that.
I perused that thread - i don’t know that a stereo to 7.x.4 upconversion is a good example of anything. Stereo music belongs in stereo. But a 5.1 mix from a dvd, as an example, should be upmixed to utilize all the speakers in a theater room.
post #8 of 8 Old 10-21-2019, 08:49 PM - Thread Starter
Mani4's Avatar
Thank you.
So you use the .4 as Top Middle and Top Rear in Atmos with 8012?
Mani4 is offline
