Any such device? Optical in to stereo optical out? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Kal Rubinson
  • 1 Post By Ratman
post #1 of 17 Old 10-20-2019, 12:54 PM - Thread Starter
Redogfizbal's Avatar
Quoted: 13 Post(s)
Does anyone know if there is a device that will split the spdif signal to stereo and keep it digital? Not looking for a DAC, or a standard splitter that just outputs two identical signals. I’m hoping that there is a splitter that can send stereo L/R from an optical source and keep it digital in the output.
Redogfizbal is offline
post #2 of 17 Old 10-20-2019, 01:25 PM
m. zillch's Avatar
Quoted: 5419 Post(s)
Liked: 3906
Sorry, your question is not clear. It seems the input is an optical digital but I'm not sure what you want for the two out puts.
Two digital coax connectors, one of which is the Left channel alone and the other the Right channel alone? No such device exists.
P.S. Here is a device which translates between the two common forms of stereo digital sound connections:
https://www.amazon.com/Optical-Conve...1599595&sr=8-3
L/R stereo digital in to L/R stereo digital out.
Here's a DAC:
https://www.amazon.com/Converter-192...R4H9D2ZA72E241
For the most part you only have access to the individual channels, L and R, while in the analog domain with these types of devices. If you want to kill just the L or R you simply leave it disconnected.
m. zillch is offline
post #3 of 17 Old 10-20-2019, 01:42 PM - Thread Starter
Quoted: 13 Post(s)
Here's a DAC:
You explained it right on your first guess. Thanks for the reply. I’m surprised someone doesn’t make a simple solution for this.
post #4 of 17 Old 10-20-2019, 02:50 PM
Ratman's Avatar
Quoted: 2418 Post(s)
Liked: 2247
Why?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #5 of 17 Old 10-20-2019, 03:02 PM - Thread Starter
Quoted: 13 Post(s)
Originally Posted by Ratman View Post
Why?
Powered speakers are becoming very common. Many of them have digital inputs with DSP built specifically for that reason. Yes most have some form of wireless communication, but a direct digital connection would be the cleanest path.
post #6 of 17 Old 10-20-2019, 04:19 PM
m. zillch's Avatar
Liked: 3906
I suspect powered speakers with digital ins have a switch on the back (or in a setup procedure) where you assign the speaker to be a L or a R (or mono?). So you feed it a stereo digital signal and it takes only the channel it needs.
post #7 of 17 Old 10-20-2019, 04:33 PM
Kal Rubinson's Avatar
Quoted: 1369 Post(s)
Liked: 1313
That has been my experience.
DonH50 likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #8 of 17 Old 10-20-2019, 05:32 PM
DonH50's Avatar
Quoted: 3309 Post(s)
Liked: 3415
Ditto. I have a pair of pro monitors and several pairs of computer speakers with digital inputs. All have a switch to set each to left or right. I have never seen an application that requires S/PDIF or AES to split into L/R in the digital domain.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #9 of 17 Old 10-21-2019, 10:20 AM - Thread Starter
Quoted: 13 Post(s)
I purchased a pair of phantom reactors, they each have digital audio in. I know that when you connect them digital direct they have a 1ms latency. If they are connected through WiFi it’s 60ms.
post #10 of 17 Old 10-21-2019, 10:28 AM
Muphasta's Avatar
Quoted: 255 Post(s)
Liked: 217
Could you use this? four identical outputs, just use two of them?
https://www.monoprice.com/product?p_...gaAodMEALw_wcB
Vinyl, tape, digital... I don't care as long as I can listen to my music...
Muphasta is offline
post #11 of 17 Old 10-21-2019, 11:51 AM
DonH50's Avatar
Liked: 3415
Ask Devialet -- I couldn't find any sort of spec list or manual on their website after a quick look. It would be very unusual to accept digital inputs and not have a way to tell it which channel to use.
post #12 of 17 Old 10-21-2019, 12:07 PM
Ratman's Avatar
Liked: 2247
Using them with/for video purposes also? Using a computer or TV or something else for audio/video? If so, then use a DAC.
(Or speak with the vendor how to properly connect/setup/adjust to eliminate/reduce latency .)
If music only, latency shouldn't be an issue or concern.
(Unless when directly optically connected speaker A has latency from speaker B)
IMO, seems like a lot of "work" for expensive speakers.
Muphasta likes this.
Ratman is offline
post #13 of 17 Old 10-21-2019, 02:44 PM
Roseval's Avatar
Quoted: 69 Post(s)
Liked: 47
They probably all receive 2 channel but the app allows you to setup a stereo configuration
https://help.devialet.com/hc/en-us/a...antom-Reactor-
Roseval is offline
post #14 of 17 Old 10-21-2019, 02:59 PM
DonH50's Avatar
Liked: 3415
In that case you should not need anything special, just a normal splitter though most (all I can remember) digital-input speakers I've used have an input and output allowing you to daisy-chain them without a splitter or eating up a second digital output. Then you just need a cable (coax or optical) from one speaker to the other.
post #15 of 17 Old 10-21-2019, 03:57 PM
m. zillch's Avatar
Liked: 3906
If anyone can find a third-party frequency response graph of one of these speakers, let me know.
post #16 of 17 Old 10-21-2019, 08:04 PM
DonH50's Avatar
Liked: 3415
Found this: https://audiophilestyle.com/ca/revie...r-review-r654/
post #17 of 17 Old 10-21-2019, 09:35 PM
m. zillch's Avatar
Liked: 3906
