Are GIK 244 bass traps supposed to be solid in the front? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By ereed
  • 1 Post By anjunadeep
  • 1 Post By Craig Peer
post #1 of 9 Old 11-05-2019, 07:45 PM - Thread Starter
Quoted: 301 Post(s)
Liked: 206
Probably a dumb question incoming:
I ordered a kit of GIK 244 bass traps, and I was planning to use them behind my mains as just large absorbers...but I noticed upon taking them out of the box they are solid in the front. Like... you can knock on their face and it's solid. I didn't order any range limiter thing or anything special, just a pair of black 244s. SKU 244.
Before I make myself look like a fool, is it normal to have a solid face? They just absorb through the back and you have to space them off the wall? It's not a scatter plate or something on these, it's completely solid. I can't feel any holes or slats.
I have a feeling I'm just asking a really dumb question, but, I figure you guys won't judge . If I were to mount this thing on the wall, it would completely block the insulation inside from being exposed to air...
Same shipment I got 224s and those are what I expected, they breathe through the front. Insulation behind it. When I talk into it, I can hear that it is absorbing. When I talk into the 244s, it shoots right back at me.
anjunadeep is offline
post #2 of 9 Old 11-06-2019, 09:48 AM
Skinfax1's Avatar
Quoted: 298 Post(s)
Liked: 93
Bass traps for low frequencies to fight room modes, like VPRs, even use metallic surface plates of 1 - 2 mm thickness. The heavier the mass, the lower the frequency they suck out. Bass traps are not working like broadband absorbers. They should dampen low frequencies the most. Wave energy is conducted from the surface plate into the trap's dampening material and eliminated there. The empty space behind the trap and the wall is to increase the low frequency energy destruction.
Skinfax1 is offline
post #3 of 9 Old 11-07-2019, 04:53 PM
Red MC's Avatar
Quoted: 304 Post(s)
Liked: 242
There are three options when ordering the 244s:
- Full Range (no membrane)
- Range Limiter (with membrane to reflect the high frequencies)
- Scatter Plate (wooden plate with slots to partially absorb and partially diffuse the high frequencies)
https://www.gikacoustics.com/product...ge-technology/
Not sure how you missed these options when ordering. When you go to add a 244 to your shopping cart, the options are right there and they default to full range.
HT: Dynaudio C2, Contour S CX, 2x BM14S, Aperion surrounds, Simaudio Titan, Marantz AV8801, Oppo 103, Linn Majik DS, and a Pioneer Kuro
Stereo: Dynaudio Focus 160, Simaudio W-5 LE or Luxman M-600A, Linn Akurate DSM, 2x Rythmik F12G
Other interests: motorcycling, skiing, being active
Red MC is offline
post #4 of 9 Old 11-07-2019, 08:39 PM - Thread Starter
Quoted: 301 Post(s)
Liked: 206
Thanks. Yeah I contacted support and they just sent me the wrong one accidentally. They shipped a replacement right away.
post #5 of 9 Old 11-11-2019, 07:23 AM
ereed's Avatar
Quoted: 2347 Post(s)
Liked: 1647
The solid hard feel is the range limiters which absorbs 400hz and below. IMO those are better than the full range option on front wall behind the speakers and absorb more low end. The mids/highs do not hit the front wall behind the speakers like low end does. Looks like GIK made a mistake with your order and looks like they did fix it. If they decide to let you keep it then use it on front wall and use the full range as first reflection point on side wall or rear wall so it absorbs mids/highs and not reflect back at you.
anjunadeep likes this.
Theater room: Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8
ereed is offline
post #6 of 9 Old 11-11-2019, 09:48 AM - Thread Starter
Quoted: 301 Post(s)
Liked: 206
My room is pretty live and have limited wall space so GIK recommended full range absorption basically where ever I could. This works out to be the front wall, corners, and some spots on the sidewalls. I was pretty surprised at what a difference just leaning those against the wall makes, I haven't had a chance to measure yet but I noticed that when I turned on a few movies demos I could actually have the volume slightly higher comfortably, I imagine simply from that energy getting absorbed. Vocals are also sounding nicer.
I have to say, probably the best value of an upgrade I've seen in a while. GIK isn't the cheapest out there, but for 244s and 224s it's not so bad considering the improvement in my room.
The did let me keep the range limited one, but since it is just one I'm probably going to put it in my office opposite side of the room, opposite corner of the subwoofer, as I notice that has a lot of standing waves there. That room is the opposite of my listening room, and is pretty dead between the carpet and bookshelves and soft goods, so it is likely a great application for that panel.
Name:	2019-11-10 11.30.49.jpg
Craig Peer likes this.
post #7 of 9 Old 11-15-2019, 08:54 AM
Craig Peer's Avatar
Quoted: 7221 Post(s)
Liked: 8645
It really is a good improvement. I installed three 242 acoustic panels at the first reflection points several years ago. I didn't tell anybody, and guests that had just been over to watch a movie a couple days prior turned to me and asked " did you get new speakers " ? Ha ! Now I'm installing GIK bass traps, and Gridfusers on my ceiling, which is making a big improvement in sound.
Craig Peer is online now
post #8 of 9 Old 11-23-2019, 01:46 PM
SJHT's Avatar
Quoted: 1156 Post(s)
Liked: 770
Craig, how are you deciding what to add to your room? I’ve sent in some info to GIK for room treatment advice, but not heard back yet. Today only have a single 24x48 panel in front of each of my main speakers. Thanks. SJ
SJHT is online now
post #9 of 9 Old 11-23-2019, 02:36 PM
Craig Peer's Avatar
Liked: 8645
I contacted them and sent dimensions, multiple photographs of the room, and also explained that it's already pretty dampened in my theater. I remember Jeff of Accucal saying " it sounds pretty good in here, but I wouldn't add any more dampening ". I'm working with John Dykstra at GIK. He's been very helpful. I can tell the enclosed side of the theater needs more bass trap treatment - it's still a bit " boomy " on that side compared to the hallway side. The bass traps on the front wall have range limiters, but all the bass traps on the sides and rear of the room have scatter plates per John's recommendation, to keep the room from sounding too dead. Bass is sounding tighter overall.
Once I get the four 1' x 4' 244 Bass Traps that are coming ( among other bass traps ), and figure out exactly where I can fit them, I'll be able to determine exactly how many more I'm going to install.
This was interesting reading here - https://ethanwiner.com/basstrap_myths.htm
SJHT likes this.
