Use a old pre pro and a modern AVR to get 4volts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-13-2019, 06:36 AM - Thread Starter
lemonslush's Avatar
Quoted: 986 Post(s)
Liked: 476
I was curious if this is logical or if its just incorrect. I have pro crown amps that really want a higher voltage input to sing. My av denon 3600 marks them at +12 for level and then I manually up the gains on the amps. They range from half to 75 % depending on my speakers.
Would it be worth picking up say a marantz 7702 that has 7 channel INs. Using the RCA outs from the 3600 to those ins for the 7 channels. Then using the 7702 preouts balanced to my crown amps and getting a full 4 volts.
My speakers are all 95db sensitivity or higher and I really dont need much power to be honest. Or do I say forget it all and just use the internal amps on the 3600 to power the 9 speakers and maybe use my old denon x4000 to power the spare two channels. I figured I could use one of those energy saver control power strips to auto turn the x4000 on.
The system works and sound good as it stands now. I do hear a slight hiss from the noise floor on the amps but I think that would stay the same regardless of what amp I use.
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #2 of 3 Old 11-14-2019, 08:10 PM
Wayne A. Pflughaupt's Avatar
Quoted: 468 Post(s)
Liked: 390
What Crown amplifier do you have that requires 4 volts?
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #3 of 3 Old 11-15-2019, 12:02 PM
m. zillch's Avatar
Quoted: 5747 Post(s)
Liked: 4096
I used to sell devices which converted lower voltage preouts into higher voltage preouts of 4V or more. Generically these devices are sometimes called "line amps" or "line drivers". Brands I would recommend include the Phoenix Gold PLD1 and AudioControl units. Although they were meant for car use I'm confident that with a 12VDC wall wart (transformer) they would work fine for home use. [I use other AudioControl gear this way with great success. Don't let the "car" aspect throw you. Their specs show they are state of the art.]
https://www.audiocontrol.com/car-aud...verdrive-plus/
m. zillch is offline
