ripping to high res mp3 or flac - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By Worf
  • 1 Post By altpensacola
  • 1 Post By SmittyJS
  • 2 Post By crn3371
  • 1 Post By Kal Rubinson
  • 1 Post By Worf
  • 1 Post By velocci
post #1 of 18 Old 11-24-2019, 08:21 AM - Thread Starter
velocci's Avatar
Quoted: 602 Post(s)
Liked: 43
Hi all, I know this is probably in the wrong forum but I couldn't figure out which forum is best for this. I'm looking for the best and free software to rip audio CDs to really high resolution mp3 or flac files for my car. anyone know of any?
thanks
Family Room: Onkyo TX-NR 646 AVR, Polk Audio RtiA3 fronts, Polk Audio CSiA4 center, BIC America F12 sub, Polk Audio RC-65i rears
Basement: Denon AVR-X3400 AVR, Klipsch RP280f fronts, RP450c center, SVS PB-2000 sub, Polk Audio RC-85i rears & surrounds
Www.jvpix.com
velocci is offline
post #2 of 18 Old 11-25-2019, 12:10 AM
Worf's Avatar
Quoted: 858 Post(s)
Liked: 591
Just use Exact Audio Copy and the standard FLAC encoder. If you must use mp3 use lame. EAC can call each to encode.
m. zillch likes this.
Worf is offline
post #3 of 18 Old 11-25-2019, 08:45 AM - Thread Starter
velocci's Avatar
Quoted: 602 Post(s)
Liked: 43
can people generally tell the difference between an mp3 file using bitrate of 320 vs flac?
Www.jvpix.com
velocci is offline
post #4 of 18 Old 11-25-2019, 08:53 AM
altpensacola's Avatar
Quoted: 275 Post(s)
Liked: 162
Depends on what you are listening to it on,
in my home; HELL YES!
None of the artist I listen to deserve mp3 anything.
In a car, no, cars are too noisy.
SinGA likes this.
Music, more music.
altpensacola is offline
post #5 of 18 Old 11-25-2019, 10:37 AM
SmittyJS's Avatar
Quoted: 458 Post(s)
Liked: 655
No.
Blind tests have pretty well established this, but there are plenty on the Web to try for yourself. I did pass one, but I identified "tells" on two of the snippets, so I don't count that.
But I rip to FLAC anyway because space is cheap and maybe there will be one someday that I can tell the difference, and it eliminates any doubt.
SmittyJS is offline
post #6 of 18 Old 11-25-2019, 10:46 AM - Thread Starter
velocci's Avatar
Quoted: 602 Post(s)
Liked: 43
what's the bitrate on flac?
Www.jvpix.com
velocci is offline
post #7 of 18 Old 11-25-2019, 02:10 PM
DreamWarrior's Avatar
Quoted: 1062 Post(s)
Liked: 633
Variable, and mostly meaningless since it's lossless (unless you want to estimate space requirements, in which case, the variability will make your estimates less accurate).
DreamWarrior is offline
post #8 of 18 Old 11-25-2019, 07:12 PM
crn3371's Avatar
Quoted: 316 Post(s)
Liked: 273
Unless you have storage constraints, I see no reason to rip to any lossless format.
Kal Rubinson and sivadselim like this.
crn3371 is offline
post #9 of 18 Old 11-25-2019, 07:22 PM
Kal Rubinson's Avatar
Quoted: 1384 Post(s)
Liked: 1322
Even if you do, you may regret in the future not ripping to a lossless format.
SinGA likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #10 of 18 Old 11-26-2019, 12:23 AM
Worf's Avatar
Quoted: 858 Post(s)
Liked: 591
Always rip to lossless, this way you have the absolute best quality rip to start from. The thing is, quality only stays the same or goes down. If you want mp3s, you can encode them from your lossless rips. There will be quality loss, even if it's inaudible.
If later on you want a different format, say AAC, you can convert from your lossless rips to AAC and again, you'll lose a bit of quality, but you started with the best quality file, so any loss of quality from your mp3 will not be present.
But if you decided to convert from mp3 to AAC, you will incur more quality loss, and potentially sounds far worse than it should as mp3 artifacts start interacting with AAC artifacts.
FLAC typically compressed to about half size. The only reasons to not use lossless formats is if your player can't play lossless, or if you're storage constrained in your player (e.g., a phone with limited storage). If you don't keep lossless rips, then you will have to rerip the files when you want a other format, which is inconvenient.
SinGA likes this.
Worf is offline
post #11 of 18 Old 11-26-2019, 02:52 AM
Liked: 0
thanks
If you're using Windows, then yeah, exact audio copy as others mentioned. If you're on a mac, XLD is the way to go.
Generally, no. With high end equipment and optimal conditions, yes. But we're talking thousands and thousands worth of equipment. With a €2000 system for example, I don't think you can really tell.
Having said that, in a moving car? No way. Too noisy as previously mentioned.
I guess you mean "I see no reason to rip to any lossy format?
I personally rip my Audio CDs in both FLAC and mp3 320kbps.
FLAC goes on cold storage (NAS and external backup of NAS), and the mp3s go to my SDCard on my phone and to listen on the laptop.
The point of FLAC is not so much for quality, but really to have a digital copy for the future.
If in 10 years we have an mp3 alternative that is 1/10 of the size with the same or better quality, with FLAC you will be able to encode all your flac music to the new format, without any loss of quality.
Or when your CDs stop working for any reason, you can always burn them back to a new CD with not even a bit lost.
marios4all is offline
post #12 of 18 Old 11-26-2019, 06:52 AM - Thread Starter
velocci's Avatar
Quoted: 602 Post(s)
Liked: 43
thanks everyone for your awesome input. I'm going to rip everything to flac.
SinGA likes this.
Www.jvpix.com
velocci is offline
post #13 of 18 Old 11-29-2019, 11:58 AM
MTVhike's Avatar
Location: North Shore of central Long Island, NY (Stony Brook)
Quoted: 232 Post(s)
Liked: 50
Do both - some cars won't read FLAC!
MTVhike is offline
post #14 of 18 Old 12-01-2019, 02:16 PM - Thread Starter
velocci's Avatar
Quoted: 602 Post(s)
Liked: 43
i'm using exact audio copy and chose flac when installing it. but when I'm ripping a CD, its using .wav for the files. how do I have it use .flac?
Www.jvpix.com
velocci is offline
post #15 of 18 Old 12-02-2019, 01:21 AM
Worf's Avatar
Quoted: 858 Post(s)
Liked: 591
Did you install the FLAC encoder? It doesn't come with one and you need to install it.
The other thing is you need to make sure you tell it not to create a WAV riff header. WAV is a container format and I think by default it is set to wrap FLAC in a WAV file.
Worf is offline
post #16 of 18 Old 12-02-2019, 05:52 AM
Quoted: 128 Post(s)
Liked: 61
No, blind trials have shown this, 320kbps MP3 and flac sound identical, certain tracks may reveal differences ('tells' as another poster put it), but the quality/cost of the system doesn't matter. Anyone who says "you might not hear the difference on your system but I can on my system because my system is better and cost $$$$" is best ignored.
But there are still many other good reasons to rip to FLAC (or an alternative lossless format) so I would strongly recommend 16bit/44KHz FLAC for all your ripping needs.
Personally I keep FLACs on my PC and then re-encode them to 160-224kbps VBR mp3 for my phone.
Uncompressed (.wav) 16bit/44KHz audio (like you get from a CD) has a standard bitrate of 1411kbps. FLAC compresses this without losing any audio information (hence 'lossless'), the final bitrate varies depending on the track, usually in the range 900-1300 kbps.
HD/hi-res FLAC files (24bit/96KHz and higher) will have higher bitrates, some are 2300kbps and higher. I consider these to be wholly pointless, 44Khz is perfectly adequate to encode everything a human can hear, higher bitrate FLACs are a scam pure and simple.
Source: Gaming/HT PC, i7 3770K, 16GB DDR3 2400Mhz, 2x GTX 980Ti SLI, MPC-HCx64 w/ MadVR & SVP frame interpolation
Display: Panasonic VT30 55" Plasma ::: Receiver: Denon AVR-1910
5.1 Speakers: Behringer B215XLs
Subwoofers: 4x SI HT18 D4 open baffle powered by iNuke NU4-6000 (1 driver per channel at 2ohm)
Ormy is offline
post #17 of 18 Old 12-02-2019, 12:55 PM - Thread Starter
velocci's Avatar
Quoted: 602 Post(s)
Liked: 43
no to both questions. during the installation of EAC, it asks what format you want to rip in. I chose flac. after ripping some CDs, I just changed the .wav to .flac and it still works and my car can read them.
do I still need to install the flac encoder and not create this wav riff header?
Www.jvpix.com
velocci is offline
post #18 of 18 Old 12-03-2019, 12:37 AM
Worf's Avatar
Quoted: 858 Post(s)
Liked: 591
Well, if it works, don't break it. You might find an option to change the extension so you don't have to rename the extension.
Worf is offline
audio , flac , mp3 , ripping
