Outdoor speaker set-up/configuration - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rocky1
post #1 of 7 Old 11-24-2019, 08:55 AM - Thread Starter
monteplus3's Avatar
Quoted: 13 Post(s)
Hi,
I'm not too sure how to pose this question, but here it goes. I have two outdoor speakers hanging outside my home, about ten feet high, above my patio door, that are relatively small, with 4"woofers and 3/4" tweeters. Farther out, I will have have two TIC GS3 8" Omnidirectional speakers (just ordered) sitting on the ground.
To power these four speakers, I have a fairly basic amp, the Onkyo TX-SR494. I will not have an outdoor sub.
My question is, how should I best connect these four speakers?
Since I want the main volume to pipe through them, I figure the TIC GS3s should be connected as the fronts. Should I connect the other two, higher up speakers, as the surrounds or as the height speakers?
The main listening area will be pretty much in the middle of all four.
Any guidance is welcome, thank you!
monteplus3 is offline
post #2 of 7 Old 11-25-2019, 09:02 AM
altpensacola's Avatar
Quoted: 276 Post(s)
Liked: 162
Originally Posted by monteplus3 View Post
Hi,
Music is most all stereo, not surround, and outdoors is not usually the place.
For that scenario I would use Speakers A, and speakers B, if it has that, you can play both or just one set.
Music, more music.
altpensacola is offline
post #3 of 7 Old 11-25-2019, 03:44 PM - Thread Starter
monteplus3's Avatar
Quoted: 13 Post(s)
Thanks, unfortunately the receiver doesn't have a speaker A/B configuration. Figure my only option is to connect the smaller speakers as heights since the throughput should be about the same.
post #4 of 7 Old 11-26-2019, 05:45 AM
Liked: 0
Connecting the additional speakers to either Surround or Height, shouldn't be any different in terms of audio output (for music).
Assuming you go in the receiver's settings, set it as a 4.0 system, and when listening to music, selecting the "Extended Stereo" mode (at least that's how pioneer calls it. Should be the same as Pioneer=Onkyo).
That would give identical sounds on the FR and SR speakers, and the same for FL and SL speakers.
marios4all is offline
post #5 of 7 Old 11-26-2019, 07:26 AM
rocky1's Avatar
Quoted: 487 Post(s)
Liked: 132
Cant you connect to zone 2 (b) . That way you can play together or seperately ..thats how i have my outdoor speakers. Have a pair under patio roof next to tv and another pair under eaves by the pool ..
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is online now
post #6 of 7 Old 11-26-2019, 08:54 AM
Quoted: 276 Post(s)
Liked: 162
Looks like their zone 2 is pre amp only.
I could not find if their receiver had an all zone stereo to utilize the surround output for stereo. If not do they have to raise the gain on the output to a height connection? Or lower it? I guess they'll have to adjust it by ear since it is outside, mic won't work I'm sure.
Music, more music.
post #7 of 7 Old 11-26-2019, 09:02 AM
rocky1's Avatar
Quoted: 487 Post(s)
Liked: 132
Per the back panel in post surround back is zone B .
RayGuy likes this.
