Converting a 5.1 setup to 5.1.4 Atmos questions... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 36 Old 11-29-2019, 11:41 AM
RayGuy's Avatar
Quoted: 2968 Post(s)
Liked: 2738
Originally Posted by archiguy View Post
Thanks for "punting" those to me Ray
RSL's - Very similar in look & function to the Polks I referenced, but more expensive. I may end up getting a second sub at some point so that should help with the localization issue.
OWM3 - Out. No aimable bracket/base. And too expensive.
CA Minx Min - No included aimable bracket (must buy separately). Which makes it too expensive. (you're probably seeing a pattern here...)
Gallo - Gorgeous! And I'm all 'bout dat! But...yikes!
Doesn't everyone here try to inflate the budget? You should expect that, by now! The problem is, as the speakers get smaller, they have to use better quality parts to approximate the performance of larger speakers, thus, they are more expensive. I think you will be fine with the polks, at that price point. All these ancillary speakers are just not all that important, given the usage % in HT. Consequently, a good place to save a few $.
Have you perused the used market? Might find a deal on Minx with bracket or Gallo ...
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #32 of 36 Old 11-29-2019, 08:28 PM - Thread Starter
archiguy's Avatar
Quoted: 6308 Post(s)
Liked: 6963
I'm probably going to pull the trigger on those Polks. They'll be fine. I'll wait 'till Monday to see if I can wheedle a few more bucks off the price. I'll use the interim time to try and figure out the most unobtrusive way to run the speaker wire. Need to find some high-quality but flexible wire to run though white plastic, self-adhesive wire mold. Some of it I'll have to paint the wall color.
This is exciting! Going Atmos! Whoo-hoo! I've only seen one movie with it in a real cinema, one of the Star Wars movies, and remember the sound track as particularly good, quite clean & clear, but not too much in the way of whiz-bang overhead effects and what not.
RayGuy likes this.
archiguy is online now
post #33 of 36 Old 11-30-2019, 11:55 AM
Darren Chan's Avatar
Quoted: 87 Post(s)
Don't get your hopes up too high. Some Atmos mixes are excellent, others are lacking.
Marantz SR7013, Polk Signature S60s/S30/S15s/HTS12s, Polk MC80 (x4), AC Infinity T9/S9, AAB4 HTPC,...still to come - Panasonic DP-UB820K, 82" 4K QLED or eqv.
Darren Chan is online now
post #34 of 36 Old 11-30-2019, 12:04 PM
m0j0's Avatar
Quoted: 752 Post(s)
Liked: 820
Or, maybe this is the answer! Pretty affordable at $120 a pair, and they're on a bracket so they're easy to aim. Plus, if my roof/ceiling ever leaks, no problemo! Anybody have any experience with these bad boys?
https://www.crutchfield.com/p_107ATR...um4-White.html
You might go for these instead. You can use four of them for your atmos and have one left over as a spare.
https://www.crutchfield.com/S-ZVW0Vi...ack-Black.html
m0j0 is online now
post #35 of 36 Old 11-30-2019, 04:02 PM - Thread Starter
archiguy's Avatar
Liked: 6963
No, thanks, I'm good now. I can get 4 of those Polks for $240 and be all set. They're really perfect for what I need.
I thought I could find some round surface mount ceiling speakers for dedicated Atmos upgrades that would look sort of like a Roomba vacuum. That's what I envisioned. But nobody makes those. However, these Polk Atrium4's are really better because they can be precisely aimed and they're decent looking. And the price is right too.
post #36 of 36 Old 11-30-2019, 04:06 PM
m0j0's Avatar
Quoted: 752 Post(s)
Liked: 820
Yes, I agree, you could do that. Just be sure to read lots of reviews as you don't want to invest the time and effort into mounting them only to find out they don't measure up to the rest of your system. I had similar concerns and really for me, it came down to the Focal Sibs and Prime Elevations, but I liked the flexible mounting options with the Sibs so took a chance. Hope it works out for you.
archiguy likes this.
m0j0 is online now
