dual zone receiver cabling - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Wayne A. Pflughaupt
post #1 of 6 Old 11-25-2019, 11:56 AM - Thread Starter
sdavs's Avatar
I'm looking to buy a dual zone receiver to provide decent audio to two different rooms without requiring two receivers.
Zone 1 has a new tv with one arc hdmi port. I plan to buy two bookshelf speakers. It has a firestick 4k.
Zone 2 has a and old tv with hdmi (no arc) and optical output. The room has 5 speakers but no subwoofer yet. The receiver will go in this room. It has a firetv 2 and an xbox 360.
The receiver I am looking at is https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1, but feel free to suggest something of better value.
Question #1 : How do I connect the tv in zone 1 to the receiver in zone2? Which ports? This is in two different rooms, do I need to get an hdmi cable through the walls. I'm thinking 1 inch conduit is not enough? And then I would also need two pairs of speaker wires for the bookshelf speakers correct? And if I want a subwoofer here, I would need an lfe cable as well?
Question #2 , Does the firestick 4k get plugged into the tv in zone1 or the receiver in zone2? I don't really understand ARC, so this part is confusing.
Question #3 . How do I connect zone tv equipment, tv, firetv and xbox 360 to the receiver?
Question #4 . Any advantages to gettin an arc capable tv on zone #2 ?
sdavs is offline
post #2 of 6 Old 11-25-2019, 02:52 PM
Darren Chan's Avatar
Quoted: 108 Post(s)
Liked: 34
First question is do you have an easy way to get cabling between the zones? If you have to open and patch a bunch of drywall, it'll be cheaper to get a 2nd receiver.
Edit: actually, just took a look at the receiver you're considering. It doesn't appear to have a zone 2 and only one HDMI out so you couldn't do what you proposed anyway.
Marantz SR7013, Polk Signature S60s/S30/S15s/HTS12s, Polk MC80 (x4), AC Infinity T9/S9, AAB4 HTPC, Panasonic DP-UB420K...still to come - 82"-85" 4K QLED or eqv.
Darren Chan is offline
post #3 of 6 Old 11-26-2019, 07:52 AM - Thread Starter
sdavs's Avatar
Thanks, I thought it was a dual zone receiver. Needing a second hdmi out makes more sense! IS this a dual zone: https://www.amazon.com/gp/product/B0...E7U53NWQ&psc=1 ? There appears to be two hdmi outs, but I can't tell.
As far as the rooms, they are one on top of the other so I could get wiring between them with about 14 ft of wire. Still, I have a feeling a second receiver or a cheap $30 amp would be a better solution. Just want to get a clear picture of the logistics and benefits of a dual zone receiver.
sdavs is offline
post #4 of 6 Old 11-26-2019, 10:18 AM
Quoted: 108 Post(s)
Liked: 34
Yes. This one has a zone 2 but it is audio only. Still only one HDMI out. You're better off getting 2 avrs.
post #5 of 6 Old 11-26-2019, 12:05 PM
Wayne A. Pflughaupt's Avatar
Quoted: 468 Post(s)
Liked: 391
I don’t see how the proposed system can work well.
The proposed Zone 2 will only work if it is configured as Zone 1. That’s the only way you’ll bet a subwoofer connection, because Zone 2’s never have subwoofer capability, or bass management for that matter.
The proposed Zone 1 (which should really be Zone 2) with the TV, you’ll have to go back to the AVR to change the source input.
Wayne A. Pflughaupt
sivadselim likes this.
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #6 of 6 Old 11-30-2019, 04:51 PM
RayGuy's Avatar
Quoted: 3111 Post(s)
Liked: 2899
Just get a cheap used older receiver for $50 or $75 bucks .... for the second zone. Simplifies a lot of issues, including remote control.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
