Hearing aid audio connection issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-26-2019, 12:41 PM - Thread Starter
Liked: 0
I have a Phonak Audeo-M hearing aid and a Roger Direct device that, with the aid of a docking station, can let me hear TV directly in my ear. However, the docking station requires an Optical In connection but my system lacks an Optical Out.
I have a set-top box that connects via HDMI to my receiver, which then distributes sound to various speakers as well as the TV. The receiver does not convert from digital input to analog output, so using a digital-to-analog converter from RCA Out to connect my docking station does not work.
Does anyone have any suggestions? If it means buying a new receiver that would be possible, although I believe Optical Out is rare.
Sonacoach is offline
post #2 of 6 Old 11-26-2019, 12:52 PM
Quoted: 377 Post(s)
Liked: 206
Optical out im not sure they are allowed to do, at least not without limitations. You might be able to do zone 2 analogue out or something, or there are devices i think that can split HDMI into optical.
Hopefully you get a reply from someone who knows for sure.
Leeliemix is offline
post #3 of 6 Old 11-26-2019, 12:52 PM
Quoted: 377 Post(s)
Liked: 206
Does the TV have an optical out?
post #4 of 6 Old 11-27-2019, 12:23 AM
Worf's Avatar
Quoted: 862 Post(s)
Liked: 591
There are HDMI audio extractors that can take HDMI and give you an optical out.
They will reduce audio quality since they bring it down to stereo. You might be able to connect it between your receiver and tv, if your receiver can pass audio throught it's output.
Worf is offline
post #5 of 6 Old 12-03-2019, 06:16 AM
AtlantaAllen's Avatar
Quoted: 131 Post(s)
Liked: 79
My Comcast DVR has an Optical out? Link to image below:
https://www.google.com/url?sa=i&sour...75465060437038
Sony ES600VW Projector, 110" motorized screen, Yamaha 2060 AVR, Parasound Halo Hint, KEF LS50s, Focal 926 Arias, PS Audio Power Plant, Velodyne 12" Sub-Woofers (2), PSB In Wall Surrounds (4), Music Hall 7 Turntable, Grado Gold, Apple TV, Sonos (6 Zones), , 55" Samsung Q6F, Klipsch Forte IIIs, 75"Sony 940E , Crown Li1500 power amp...330WPC @ 8 ohms
AtlantaAllen is offline
post #6 of 6 Old 12-03-2019, 06:18 AM - Thread Starter
Liked: 0
Thanks everyone for your responses
I tested the device on a friend's DVD player with an optical out and it sounds wonderful, so I'll have to find a way to use this with TV. I'm planning to replace my TV but I believe Optical Out connections are rare, so that may not help. I may also replace my receiver and try to find something that splits Optical out from HDMI.
In any case thanks for responding. I appreciate it.
