Samsung smart TV optical out is distorted - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-28-2019, 11:23 AM - Thread Starter
qguy's Avatar
Quoted: 205 Post(s)
Liked: 106
Scenario 1 :Samsung Smart TV - optical out to Topping D30 DAC, I get distorted sound.
Scenario 2: Laptop optical out to Topping D30 DAC and it works, everything is the same except for source
Scenario 3: Samsung smart TV to a Bose system with its own cable and DAC to the smart TV and it works
Scenario 3: Samsung smart TV to a Bose optical cable to Topping D30 DAC and I get distorted sound
So why is the Smart TV not working with the Topping DAC ?
qguy is offline
post #2 of 8 Old 11-28-2019, 11:43 AM
Quoted: 377 Post(s)
Liked: 206
Check cable if its ok.
Check sound output settings on the TV.
Leeliemix is offline
post #3 of 8 Old 12-02-2019, 06:11 AM
Quoted: 128 Post(s)
Liked: 61
What type of cable is this in scenario 3? Is it an optical cable or an analog cable?
Sounds like the optical output of the TV is clipping the input of your DAC. There may be settings either in the TV or the DAC that can help, if not there's not much you can do. I doubt using a different optical cable will make any difference but they're cheap so its worth a try.
Source: Gaming/HT PC, i7 3770K, 16GB DDR3 2400Mhz, 2x GTX 980Ti SLI, MPC-HCx64 w/ MadVR & SVP frame interpolation
Display: Panasonic VT30 55" Plasma ::: Receiver: Denon AVR-1910
5.1 Speakers: Behringer B215XLs
Subwoofers: 4x SI HT18 D4 open baffle powered by iNuke NU4-6000 (1 driver per channel at 2ohm)
Ormy is offline
post #4 of 8 Old 12-03-2019, 08:16 PM - Thread Starter
qguy's Avatar
Quoted: 205 Post(s)
Liked: 106
Optical cable of Bose
qguy is offline
post #5 of 8 Old 12-04-2019, 03:56 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 481 Post(s)
Liked: 14367
Kind of a "is it plugged in?" question. Is the TV outputting PCM?
Make me grow brainiac fingers, but with more hair!
PooperScooper is offline
post #6 of 8 Old 12-04-2019, 04:15 AM - Thread Starter
qguy's Avatar
Quoted: 205 Post(s)
Liked: 106
Optical output is PCM, no other options available
qguy is offline
post #7 of 8 Old 12-04-2019, 09:10 AM
m. zillch's Avatar
Quoted: 5554 Post(s)
Liked: 3986
You haven't told us the model number but here's a quote from a 2019 owner's manual regarding its optical out, p29:
"Digital audio is only available with 5.1 channel broadcasts."
This would suggest to me there is, in at least in some scenarios, a Dolby option, i.e. not PCM, which the Topping won't work with and will likely cause distortion.
m. zillch is offline
post #8 of 8 Old 12-04-2019, 10:31 AM - Thread Starter
qguy's Avatar
Quoted: 205 Post(s)
Liked: 106
Makes sense why the Bose works, The BOSE is 5.1
qguy is offline
