Does this cable exist ? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Ratman
  • 1 Post By MRAYB
post #1 of 18 Old 12-09-2019, 01:00 AM - Thread Starter
Jim McC's Avatar
Quoted: 522 Post(s)
Liked: 137
I'm trying to find a cable that has optical digital on one end, and coaxial digital on the other end.
I know there are converters, but I'd rather find a cable, if possible.
Jim McC is online now
post #2 of 18 Old 12-09-2019, 03:49 AM
markmon1's Avatar
Quoted: 5711 Post(s)
Liked: 3773
No, it's not possible for this to just be a cable. Digital optical is fiber, coaxial is metal wire. They don't work the same, which is why you actually need a device to receive one format, and output the other.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 18 Old 12-09-2019, 09:19 AM
m. zillch's Avatar
Quoted: 5799 Post(s)
Liked: 4140
It requires electricity so at the very least you need a transformer plugged to the wall no matter how small you make it. If you cracked one open you could possibly use electrical tape to bind the circuitry tightly to a wire?
https://www.amazon.com/Monoprice-Opt...SIN=B002HWZN4W
m. zillch is offline
post #4 of 18 Old 12-09-2019, 10:08 AM
Ratman's Avatar
Quoted: 2511 Post(s)
Liked: 2326
Can't happen. One is optical (light), the other electrical (wire). That's why they make "converters".
EDIT:
Also, they are not bidirectional. Compare the link above to the link below.
https://www.monoprice.com/product?p_...SABEgJxG_D_BwE
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #5 of 18 Old 12-09-2019, 10:20 AM
m. zillch's Avatar
Liked: 4140
post #6 of 18 Old 12-09-2019, 10:46 AM
Ratman's Avatar
Liked: 2326
Okay.... there may be some that are bi-directional with a switch.
Just making the OP aware.
EDIT:
Surprised it wasn't pointed out that the labeling on the link above is not accurate.
Both coax and optical are S/PDIF.
Ratman is offline
post #7 of 18 Old 12-09-2019, 10:49 AM
m. zillch's Avatar
Liked: 4140
Also keep in mind some are PCM (2ch music ) only whereas some others are 5.1, Hi-res sampling rates, etc..
post #8 of 18 Old 12-09-2019, 12:16 PM
Ratman's Avatar
Liked: 2326
True for S/PDIF to analog converters.
Not so sure about optical to coax or coax to optical. S/PDIF to S/PDIF should carry the PCM or bitstream signal supported at each end of the connections (S/PDIF compliancy of course.)
Ratman is offline
post #9 of 18 Old 12-09-2019, 12:28 PM
MRAYB's Avatar
Quoted: 347 Post(s)
Liked: 795
MRAYB is offline
post #10 of 18 Old 12-09-2019, 12:31 PM
Ratman's Avatar
Liked: 2326
Originally Posted by MRAYB View Post
Question?
Confusion?
Please expand on your response.
Ratman is offline
post #11 of 18 Old 12-09-2019, 02:14 PM
MRAYB's Avatar
Quoted: 347 Post(s)
Liked: 795
Originally Posted by Ratman View Post
Question?
Confusion?
Thanks, but I am just trying to follow along. Would never have dreamed of an optical to a coax. Most of those converter type boxes are not worth a darn either, correct?
MRAYB is offline
post #12 of 18 Old 12-09-2019, 02:29 PM
Ratman's Avatar
Liked: 2326
No, incorrect. They work.
I've been using one from Monoprice for quite a few years.
Ratman is offline
post #13 of 18 Old 12-09-2019, 02:35 PM
MRAYB's Avatar
Quoted: 347 Post(s)
Liked: 795
Cool. Just seems like it would not be possible to work. That is why I come here and learn something new every time.
MRAYB is offline
post #14 of 18 Old 12-09-2019, 02:47 PM
Ratman's Avatar
Liked: 2326
But it is possible!
It's not a new gadget.
Ask before posting "???????????? "
It may be misinterpreted.
MRAYB likes this.
Ratman is offline
post #15 of 18 Old 12-09-2019, 02:49 PM
MRAYB's Avatar
Quoted: 347 Post(s)
Liked: 795
But it is possible!
Will do.
Ratman likes this.
MRAYB is offline
post #16 of 18 Old 12-09-2019, 03:28 PM
A9X-308's Avatar
Quoted: 1860 Post(s)
Liked: 1583
It's an incredibly simple circuit either way. ie O-C or C-O.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #17 of 18 Old 12-09-2019, 03:57 PM
Ratman's Avatar
Liked: 2326
That why the prices are $10-15 USD. The plastic case and power supply are 85% of the cost.
Ratman is offline
post #18 of 18 Old 12-09-2019, 07:48 PM - Thread Starter
Jim McC's Avatar
Quoted: 522 Post(s)
Liked: 137
Thanks all
