Convert Coax Digital to Analog - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-31-2019, 12:12 PM - Thread Starter
AtomicOne's Avatar
I have this TV:https://www.lg.com/us/tvs/lg-32LF500B-led-tv
I have this amplifier: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
My inputs to the TV are antenna and a Roku stick. The TV has a coaxial audio output jack. I want to be able to convert the coax audio to analog so I can use the AUX input on the amplifier to listen to broadcast TV and the Roku device. I have tried to accomplish this using a device such as this:
This does not work. I know the TV output is OK, and I know the coax audio I'm using are good because I can connect them to a different amp, one with a coax input, and I get audio out from the amp.
Please advise- thanks for your help.
AtomicOne is offline
post #2 of 3 Old 01-15-2020, 06:26 AM - Thread Starter
AtomicOne's Avatar
After trying several devices, I finally recognized that the problem was that the TV audio was dolby 7.1. Once I found an adapter (STELLAR AV ST-DAC-71) that was able to process that audio format, I was able to route the audio from the TV to the amplifier via the TV digital audio output jack. This did not however result in any improvement in audio quality or audio level.
post #3 of 3 Old 01-15-2020, 10:18 AM
josh6113's Avatar
Quoted: 274 Post(s)
Liked: 118
Make sure your TV is outputting PCM and you Roku.
Sent from my MHA-L29 using Tapatalk
Doing what I do best...LIVIN!
josh6113 is online now
