New TV + Old AV Receiver - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Roger Dressler
post #1 of 3 Old 01-09-2020, 04:16 PM - Thread Starter
Liked: 0
Hi all.
First post here. Looking for some advice on audio setup.
I have an old Yamaha RX-V12000RDS AV Receiver that can handle Dolby Digital and DTS. It has Optical + Coax inputs, no HDMI. I plan to use it to set up a 5.1 system.
I recently bought a new TV (LG 55UM7450PLA). Still in the box waiting for the room to be redone. The TV has HDMI/ARC and optical out and will output DD over both of these. So it seems I can at least get Dolby Digital 5.1 from the TV to the receiver.
Just wondering if there are other possibilities for improving the sound. The TV will output DD+ over HDMI/ARC. The receiver has 6 channel input.
I can set the TV to output PCM. So wondering if this will allow me to get DD+ sound quality. I guess I would need a HDMI extractor to convert the PCM into 6 channels and then connect to the receiver.
Alternatively if I set the TV to output DD+ over HDMI ARC could I use an external decoder to convert this to 6 channel PCM. I have been looking for a decoder that can do this but I haven't found anything that clearly does this. Most of the inexpensive HDMI extractors I've seen seem to only offer passthrough.
Attached is a summary of the audio out possibilities.
Name:	LG Sound Options.jpg
Neutron_Star is offline
post #2 of 3 Old 01-12-2020, 03:27 AM
Roger Dressler's Avatar
Quoted: 3101 Post(s)
Liked: 1855
DD+ does not necessarily sound better than DD, it just uses a lower bitrate (and optionally, Atmos encoding which is not at issue here). Also, the way DD+ devices "transcode" DD+ signals to the legacy DD output preserves the quality of the DD+. You might be surprised.
If you set the TV to output PCM it will be limited to stereo rather than 5.1, in case that matters.
Neutron_Star likes this.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is online now
post #3 of 3 Old 01-12-2020, 02:22 PM - Thread Starter
Liked: 0
Thanks Roger.
I did some searching and found a few threads on here which basically say the same as what you have said. I'm looking forward to setting this system up in our newly refurbed room.
