Newbie Subwoofer User - Sealed Rear Port? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-12-2020, 03:32 PM - Thread Starter
DerbyDad03's Avatar
Liked: 2
I bought a Samsung HW R550 soundbar/subwoofer combination. The woofer came with a piece of thick plastic over the rear port.
The manual that came with the unit doesn't say anything about it in the set-up section but when I chatted with Samsung support they said that I can remove it. I'm just not confident that he knew what he was talking about, based on some other comments he made.
Here is what I am talking about:
is that supposed to be removed?
DerbyDad03 is online now
post #2 of 4 Old 01-12-2020, 03:35 PM
Quoted: 435 Post(s)
Liked: 238
That looks like shipping/storage protection not a «plug» which are usually made from foam and go a ways inside to block the port to make it work more like a sealed sub.
Leeliemix is online now
post #3 of 4 Old 01-13-2020, 07:13 AM - Thread Starter
DerbyDad03's Avatar
Liked: 2
Just looking for clarity here...
Are you implying that I can/should remove the plastic?
"looks like shipping protection" is what I thought, but I haven't heard anyone say, with 100% certainty, that it is. It appears to be held on with a thick bead of adhesive, similar to what they use to hold plastic sheeting on under door panels in cars. The plastic on the subwoofer is just as thick which makes me wonder if it really is just packing material.
Any further thoughts?
post #4 of 4 Old 01-13-2020, 07:56 AM
Ratman's Avatar
Quoted: 2508 Post(s)
Liked: 2322
Take it off. It's just a shipping cover.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
