Optical cable question - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By sivadselim
post #1 of 21 Old 01-28-2020, 05:18 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 44
I currently don’t have a 4 K receiver. I want to upgrade but in the meantime use my current non 4K 7.1 receiver.
How do I run my current receiver and still get 4K?
My plan is to run an HDMI from my Directv box to my 900F and then run an optical cable from my TV to my current non 4K receiver.
But I was at BB today and the salesman said that an optical cable will only run a 5.1 audio system and not a 7.1 system.
Is that correct? Someone please clear this up for me.
Pittfaninloco is offline
post #2 of 21 Old 01-29-2020, 10:59 AM
sivadselim's Avatar
Quoted: 523 Post(s)
Liked: 446
There is a high likelihood that the TV won't even pass a 5.1 signal; only a 2-channel downmix.
Does the DirecTV box have an optical or coax audio output, too? If so, it will probably be active simultaneously with the HDMI output. And, if so, you could try connecting it directly to your AVR.
And, btw, does the DirecTV broadcast 7.1 audio, anyway?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 21 Old 01-29-2020, 11:07 AM
Quoted: 1117 Post(s)
Liked: 635
Correct that max signal a optical cable can pass is 5.1 considering your situation I would do what you are planning.
liffie420 is offline
post #4 of 21 Old 01-29-2020, 11:25 AM
torii's Avatar
Quoted: 3909 Post(s)
Liked: 2283
this is how I run my system. I only have 5.1 tho
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #5 of 21 Old 01-29-2020, 12:33 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 44
The Directv box has a digital audio RCA output, no optical
post #6 of 21 Old 01-29-2020, 12:41 PM
Liked: 635
It does have HDMI out though right? IF you run the HDMI to your tv and an optical form the TV to the AVR you will (should) get 5.1 sound, it would depend on the source material of course, tv shows vs movies.
post #7 of 21 Old 01-29-2020, 12:49 PM
Rgb
Rgb's Avatar
Quoted: 753 Post(s)
Liked: 1004
Technically, an optical cable can run discrete (Lossy) 6.1
https://en.wikipedia.org/wiki/DTS_(sound_system)#DTS-ES
FOr anything higher than lossless 2ch, optical can only carry lossy compressed 5.1/6.1 (DD/DTS)
Need HDMI for lossless >2ch
Rgb is offline
post #8 of 21 Old 01-29-2020, 01:44 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 44
Yes on the HDMI. From my Directv box can I run the HDMI to my TV for 4K and run the RCA to my receiver for 7.1?
post #9 of 21 Old 01-29-2020, 02:01 PM
sivadselim's Avatar
Quoted: 523 Post(s)
Liked: 446
And does your AVR have a coax ("digital audio RCA") input? If so, I would use it. Use PLIIx to upmix the 5.1 to 7.1.
Again, does DirecTV even do 7.1 audio? Even if capable, most stuff probably isn't 7.1, anyway.
post #10 of 21 Old 01-29-2020, 02:01 PM
sivadselim's Avatar
Quoted: 523 Post(s)
Liked: 446
Most TVs do not pass multichannel audio except from OTA sources.
Some might be able to but it is only 5.1.
Alan P likes this.
post #11 of 21 Old 01-29-2020, 02:12 PM
Ratman's Avatar
Quoted: 2536 Post(s)
Liked: 2350
If I may elaborate (with my additions in bold)
Most TVs do not pass multichannel audio (of any type) except from OTA sources from the TV's internal tuner.
Some might be able to but it is only lossy DD/DTS 5.1. Check your user's manual.
S/PDIF (optical/coax) does not carry lossless formats.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #12 of 21 Old 01-29-2020, 02:16 PM
Liked: 635
No the RCA will only pass 2 channel signals. You want to run the optical out from your tv to your avr. Alternatively you could get a box that strips the audio channel out of the HDMI signal from your direct tv box and run that audio only HDMI to the receiver.
post #13 of 21 Old 01-29-2020, 02:26 PM
Ratman's Avatar
Liked: 2350
I believe you misunderstood. The poster means "digital coax" which has an RCA connector. It will pass DD/DTS 5.1
Again... not all TV's will passthough DD/DTS via the optical from an HDMI connected source.
Ratman is offline
post #14 of 21 Old 01-29-2020, 02:36 PM
Liked: 635
You sir are correct,right after I posted that I was like why the F would a modern cable box have old standard rca's.
post #15 of 21 Old 01-29-2020, 02:51 PM
Ratman's Avatar
Liked: 2350
Too quick to answer without reading.
The poster clearly stated "digital audio".
Ratman is offline
post #16 of 21 Old 01-29-2020, 03:59 PM
sivadselim's Avatar
Quoted: 523 Post(s)
Liked: 446
.................right after I posted that I was like why the F would a modern cable box have old standard rca's.
Well, many (most?) do still have R/L analog RCA outputs.
But, as pointed out, the OP is referring to a digital coax output.
post #17 of 21 Old 01-29-2020, 04:36 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 44
No, it’s not a coax output. Box has a coax in. The digital output is one RCA connection labeled digital audio.
post #18 of 21 Old 01-29-2020, 04:40 PM
sivadselim's Avatar
Quoted: 523 Post(s)
Liked: 446
And that is called a digital coax audio output. It outputs the same thing as an optical output.
And, yes, your box has a coax cable F input.
Ratman likes this.
post #19 of 21 Old 01-29-2020, 04:50 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 44
Ok, sorry for my ignorance. When I think coax I think of the cord coming from the wall plate into the Directv box.
So if that connection is like a optical output can I run a cable from that output on my Directv box to my receiver?
Would that deliver 7.1 audio?
post #20 of 21 Old 01-29-2020, 04:54 PM
torii's Avatar
Liked: 2283
this link may help https://www.the-home-cinema-guide.co...tal-audio.html
torii is offline
post #21 of 21 Old 01-29-2020, 11:00 PM
sivadselim's Avatar
Quoted: 523 Post(s)
Liked: 446
Yes, which is what I recommended several posts back. Run a coax cable from your box to one of your AVR's coax inputs. Your box should still output audio via the coax output even though you are using an HDMI connection to the TV for the video.
I don't think so. But, again, I am not sure your DirecTV box would transmit "7.1 audio" even via an HDMI connection. And even if it can, most material is probably still not 7.1; most is only 5.1. You use a setting in your AVR (something like PLIIx) to upconvert 5.1 audio to 7.1 audio.
BTW, you said you don't have a 4K AVR. But does it have HDMI inputs?
